Old 09-29-2007, 06:32   #1 (permalink)
Member: 368923
Thanks Meter: 85
pinouts for sands A203
hi , anu bodY could pls uplaod the correct pinouts for sands A203
Old 09-29-2007, 09:27   #2 (permalink)
Member: 567351
Thanks Meter: 40
new id?
wow.
infinity have his
Chinese Miracle section..
The Following User Says Thank You to cbz_4383 For This Useful Post:
Old 09-29-2007, 11:53   #3 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Here is the pinout for Hintel
3, 7, 19 - GND
20 - Vcc
9 - RX
13 - TX
Old 09-29-2007, 22:37   #4 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
3, 7, 19 - GND
20 - Vcc
9 - RX
13 - TX
not working, i used onely tx,rx and gnd, should i use vcc?
Old 09-30-2007, 06:32   #5 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Which software do you use?Which box?
Old 09-30-2007, 16:18   #6 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
infinity, chinese soft, why is there other softs!!
Old 09-30-2007, 18:39   #7 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Yes there are so many softs.For example I use Format Fat software for A203,N203 models.
Old 09-30-2007, 20:27   #8 (permalink)
Member: 130995
Thanks Meter: 35,227
For "Format" operation pinout will be the same for any software.
You can use Infinity-Box two "format" options: "complete" and "safe" and bothoptions should be used with the same pinout.
Only "Imei" option can be used with other pinout (ordinary USB data/modem cable and USB drivers).
Old 09-30-2007, 21:42   #9 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
so dificult to find the right pinout, i think format will solve my problem, the phone hang and restart with sim card
where are the chinese? it's ur phone!
Old 10-01-2007, 12:08   #10 (permalink)
kasim's Avatar
Member: 107448
Thanks Meter: 29
Its wrong a203 pinout
no it is not working . tx rx is not correct
Old 10-01-2007, 12:22   #11 (permalink)
cellworld's Avatar
Member: 53457
Thanks Meter: 9
@a203 keypad up left 1 to .... 3 and 4 are tx and rx
@a203 keypad up left 1 to .... 3 and 4 are tx and rx its 100% woring if not work swap rx and tx ok best of luck
best regards
cellworld
Old 10-01-2007, 15:51   #12 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
best regards
cellworld
3 is gnd, what are u saying!!
Old 10-01-2007, 17:28   #13 (permalink)
Member: 130995
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to make detailed description of model,
attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector.
After you have this information prepared, please, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 10-02-2007, 07:21   #14 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
If pinout is wrong always change the places of RX and TX.
Old 10-02-2007, 07:22   #15 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
I agree with you but this soft formats phone when the phone is powered on
Would be great if you could add this option to your software too
pinouts for sands a203 sunnny Infinity-Box 9 11-11-2007 18:00
NEEDED Sands A203 pinouts kasim Infinity-Box 1 09-27-2007 13:37
need pinout for sands A203 ashok_kumar459 Infinity-Box 3 09-24-2007 06:06
sands a203 pinout????????? edy2002gha Infinity-Box 3 09-12-2007 21:16
plz help me pinout for SANDS A203???? black snake Infinity-Box 9 09-11-2007 10:01
Page generated in 0.24272 seconds with 9 queries
