02-21-2008, 18:30 | #7 (permalink) |
Freak Poster Join Date: Jul 2006 Location: aghbala Age: 40
Member: 312667 Status: Offline Sonork: 1000.2 Thanks Meter: 61 | after unlock method: standard phone no Power her log COM5 [VCP7] selected Device: Modelabs V-Slide Virgin Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6219:8A01]... CPU: MT6219 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20080221-131702.B0E.bin flash: 01227E22212200:29EA0000000000 Identification Done Manipulation... detection procedure, wait... error: phone is not locked or unknown eeprom Manipulation Fail Finished, time used: 250 sec Remove/Install battery now ! Loading file v.02... backup_eeprom_20080221-123803.B0E.bin loaded COM5 [VCP7] selected Device: Modelabs V-Slide Virgin Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6219:8A01]... CPU: MT6219 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... Area: Eeprom/ffs flash: 01227E22212200:29EA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished Write Done Finished, time used: 152 sec Remove/Install battery now ! COM5 [VCP7] selected Device: Modelabs V-Slide Virgin Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6219:8A01]... CPU: MT6219 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20080221-132459.B0E.bin flash: 01227E22212200:29EA0000000000 Identification Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... detecting additional parameters... .................................................. .............. error: additional parameters detection failed Finalization Done Write... flash: 01227E22212200:A6BDF700000000 Write: eeprom error: error# 0000AFE4 And the problem is that the firmware not in support |
02-22-2008, 09:49 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. You must charge battery with external power supply 2. You must press and HOLD phone "Power" button long time (30-40 sec) to make phone powered-on after unlock. if you still want to flash phone you can download files easily from Infinity-Box support area. \flashfiles\Modelabs\V-Slide |
02-22-2008, 10:14 | #11 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Setif ALGERIA Age: 44
Member: 80990 Status: Offline Sonork: 100.1583974 Thanks Meter: 312 | And this is a full flash i hope that can help you (full flash + eeprom): http://rapidshare.com/files/93898427...irgin.rar.html |
problème problem مشكل samsung F480 please help me | jerada379 | Samsung Hardware Repair | 4 | 07-11-2009 08:21 |
probléme unlock w880i ! | wajdi50001 | SETool2 | 3 | 05-10-2009 09:07 |
Virgin V-Slide | bachirDraria | Infinity-Box | 2 | 08-03-2008 12:11 |
J'ai une problème unlock k550im+w580i sur Setool | tomtom111 | SETool2 | 14 | 06-26-2008 16:07 |
help me probléme code GRUNDING 5201RDS GR1001V0134712 | nassim-dz | CAR Electronics | 0 | 08-13-2006 17:05 |
