06-06-2008, 08:52 | #1 (permalink) |
Junior Member Join Date: Dec 2005
Member: 209510 Status: Offline Thanks Meter: 0 | J'ai une problème unlock k550im+w580i sur Setool bonjour j'ai un problème dans unlock k550+w580i Lorsque je Flash le téléphone Ouvert v0.914030/UNI CARD SERIAL: 00070958 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:3549110-----31 CERT:RED FLASH CID:52 COLOR:RED Model:K550im Brand:BOUYGTEL MAPP CXC article: R1KG001 prgCXC1250791_GENERIC_LM MAPP CXC version: R1KG001 Language Package:I_MODE_FRANCE CDA article: CDA102743/608 CDA version: R14A Default article: cxc1250774 Default version: R1KG001 PROVIDER: 208-20 Network LOCKED RESTORATION FILE NOT PRESENT "R1KG001_CXC1250791_GENERIC_LM" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE NOT PRESENT "R1KG001_CXC1250791_GENERIC_LM.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" SECURITY UNITS BACKUP CREATED. Elapsed: 4 secs. SIGNED MODE (USING SERVER). PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! ReadOTP failed, exiting OTP read error ! PROCEDURE WAS STOPPED BY USER Elapsed: 59 secs. |
06-06-2008, 10:58 | #3 (permalink) |
No Life Poster Join Date: Jun 2007 Location: SPAIN
Member: 532853 Status: Offline Thanks Meter: 610 | n oublie pas d activer la seconde case "enable alternative security bypass"et desactiver la derniere . clic go support and download the las version v34 Last edited by mamepap; 06-06-2008 at 11:04. |
06-06-2008, 11:36 | #5 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 50
Member: 59614 Status: Offline Thanks Meter: 11 | on dit j un probleme pas une probleme et le mec n'arrive pas a ecrire en francais qu'est ce il va faire en anglais. c pas un pro c un débutant et merci d'avoir l'aider ce metier me tappe sur les nerfs que des ......................... |
06-06-2008, 11:43 | #6 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Allways here
Member: 476774 Status: Offline Thanks Meter: 399 | Quote:
http://www./showthread.php?t=537090 | |
06-06-2008, 11:49 | #7 (permalink) | |
Member: 532853 Status: Offline Thanks Meter: 610 | Quote:
toi on dit j un probleme ou j ai un probleme au moins G un probleme. excuse me. | |
06-06-2008, 12:23 | #8 (permalink) |
Member: 59614 Status: Offline Thanks Meter: 11 | t vraiment le pire des cons je t'apprends a ecrire sans fautes monsieur regarde bien ce que tu dis parce que j'ai meme pas le temps de voir tes complexes. (j) j'ecris en abriviation parce que peut etre il sait meme lire.et en plus try man to explain in english if u need help i m here.ne sois pas si stupide et ne repond pas parce que tu risque d'etre ridiculiser |
06-06-2008, 12:31 | #11 (permalink) |
Member: 59614 Status: Offline Thanks Meter: 11 | généralement g pas le temps d'ecrire sur le forum juste je passe comme tout le monde mais c la honte de voir des chose pareille et de les encouragé mamepap mampap maman papa...........je m'excuse encore man peut etre un jour nous serons ami et tu auras un peu de savoir vivre bon travaille et garde ton professionallisme pour vousssssssssssssss |
06-06-2008, 15:00 | #12 (permalink) | |
ok merci je ne suis pas la pour des fautes d hortographes ou grammaticales sinon pour poser,repondre et partager de la connaissance. no me empuje a escribir lo que no quiero decir por favor. callate. i will not answer you in this thread. thank you man. | |
06-26-2008, 16:07 | #15 (permalink) |
Member: 59614 Status: Offline Thanks Meter: 11 | on dit de les encourager et non de les encourage avec accent. ya coucou mta3 mam et pap you have to be smart.(not smart-clip),i explain to u any time u choose the power of u re selfish caractere and how u running to show u re self in this forum.i have never attacked someone anywhere but how a person work in this world of software and GSm doesn't know the english or french to have an acces to manipulate programs.if someone misunderstood me or i have been so agressive;i say right now I'M SO SORRY.but the matter stay here how can i give my personnel GSM to a person who doesen't know to write or understand this software.maybe in tunisia we do it and that's why the market is full of..., and i'm so sorry for the word(rubish).and i understand why gouverment stop and close all stores and shops and the person who has the reel capacity to work are victims of.........well i don't care but reallly i find my self in close way and i want to show to all person the gravity of the problem. |
The Following User Says Thank You to phone18 For This Useful Post: |
j'ai un problème avec mon s5230 | omri | 2G Latest Models | 3 | 01-12-2010 19:30 |
plz help me .....how to unlock k550im with seetool | abousalma007 | Sony Ericsson Hardware Repair | 2 | 08-02-2009 01:53 |
probléme unlock w880i ! | wajdi50001 | SETool2 | 3 | 05-10-2009 09:07 |
probléme unlock virgin v-slide | OUSKHMANE | Infinity-Box | 11 | 02-22-2008 15:15 |
help me probléme code GRUNDING 5201RDS GR1001V0134712 | nassim-dz | CAR Electronics | 0 | 08-13-2006 17:05 |
