03-01-2008, 19:19 | #1 (permalink) |
Registered User Join Date: Jul 2003 Age: 43
Member: 34599 Status: Offline Thanks Meter: 12 | problem read speadtrum cpu with v1.6 i have problem to read speadtrum cpu with my infinity pin finder v1.6. i try to read pin out for my cect Y767 speadtrum cpu with 24 pin. i,m use kbl 1x24(l24a): software version: 1.06 cable type: 1x24 (L24A) platform: SPD: Spreadtrum searching adapter at COM7... adapter found, version: 2000 pins: 24, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now (not required but recommended) ! detecting pins... failed to detect pins time required: 30 sec Power Off ! i try about 15 times and still can"ot find pin out. but with other cpu like mtk is ok.. already check phone conector its ok. pls another solution? mtk cpu log: Power Off ! software version: 1.05 searching adapter at COM7... adapter found, version: 2000 pins: 12 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... error: boot initialization step-2 failed: D2 CPU: MT6226 result: Rx:7 Tx:6 time required: 54 sec Power On ! |
03-01-2008, 21:28 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Some phones don't have Rx/Tx on bottom connector, try to open phone and see testpoints with RX and TX marks. What is your phone CPU chip name ? Post here full text from CPU chip. |
03-02-2008, 19:21 | #3 (permalink) |
Member: 34599 Status: Offline Thanks Meter: 12 | br.. cpu chip name is spreadtrum. ill try about 15 times and still can't find rx/tx . where is the problem? its to read speadtrum cpu and mtk cpu same way?or another way? for mtk cpu no problem to find rx/tx. another question: how to find rx/tx for phone with spreadtrum cpu if the phone dont have rx/tx in bottom conector with rx/tx finder infinity. thx |
03-02-2008, 21:56 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It's supported CPU type so if Rx/Tx exist on bottom connector it should be found. How to find if not Rx/Tx is no exist on connector: some phones don't have Rx/Tx on bottom connector, try to open phone and see testpoints with RX and TX marks on phone PCB. |
03-03-2008, 02:44 | #7 (permalink) |
Member: 34599 Status: Offline Thanks Meter: 12 | hello.. i know this very clear br.. (How to find if not Rx/Tx is no exist on connector: some phones don't have Rx/Tx on bottom connector, try to open phone and see testpoints with RX and TX marks on phone PCB.) many phone with mtk cpu ill do with this way. another question: I have 1 cable from infi rx/tx package with output use cable with 10 different colour. which cable colour for rx,tx and grd?cause i want to try use rx/tx on pcb. my question clear enough?my english not to good. br. |
03-03-2008, 10:57 | #11 (permalink) |
Freak Poster Join Date: Mar 2005 Location: india Age: 55
Member: 125424 Status: Offline Thanks Meter: 21 | software version: 1.06 cable type: 2x6 (L12B) platform: NXP: OM6357EL4 searching adapter at COM9... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 20 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... result: Rx:2 Tx:8 time required: 10 sec Power On ! HOW REPAIER platform: NXP: OM6357EL4 pls.help |
03-03-2008, 12:43 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello mr. amarjeet! currently only MT62xx MCU is supported for pinout search & software operation. other MCU types is supported only for pinout search |
03-03-2008, 13:34 | #13 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Quote:
Pin founded, micrale not connecting software version: 1.06 cable type: 1x18 (L18A) platform: SPD: Spreadtrum searching adapter at COM6... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now (not required but recommended) ! detecting pins... Rx:12 result: Rx:12 Tx:13 time required: 54 sec Power On ! Mr InfinityHelp please update ChineseMiracle | |
03-03-2008, 20:07 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello guys! @IkaMazini: currently only pinout search option is added. No support for this MCU in Chinese miracle software @andr3_jc: if you want to use just tx/rx/gnd wires that disconnect pinout finder and use unibox rj45 port. pin 2, 3 is data lines, pin 8 gnd. |
Z3X PROBLEM READ IPHONE 6225 WITH MTK_tool FOR CHINA EDITOR | dbarakov | Z3X-Team Products | 4 | 05-28-2010 00:15 |
when u add other speadtrum cpu _? | osom | Chinese Cocktail | 1 | 09-22-2008 15:34 |
how to speadtrum cpu pinfinder and 1. and 2. cpu imei writer | turkcellgsm | VE-KING | 2 | 08-02-2008 08:59 |
W200 CID53 problem after TP unlock with DB3.6 | cevil | DreamBox | 11 | 07-08-2008 07:00 |
when will support speadtrum cpu TV MOBILE? | zonetrichur | Chinese Cocktail | 3 | 06-01-2008 16:00 |
