03-09-2009, 06:32 | #1 (permalink) |
Freak Poster Join Date: Apr 2007 Location: North East, Tripura
Member: 491880 Status: Offline Sonork: 1620586 Thanks Meter: 9 | sigmatel s1 dead plz help GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S1-ML_MR106_004_5S02-MC-C01-RF3198_V1_1_025_080411__Sigmatel-S1_16m_En_Ru_Fr_Th_Vn_Ar.B0M.bin detailed info of phone help: COM4 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4F03:000C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 76657273696F6E3A30320000000000000000000000000000 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:76737200000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... .................................................. ...... can't detect fat record name location error: ffs detection failed: element #1 detecting ffs structure pass 2... .................................................. ...... can't detect fat record name location error: ffs detection failed element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 77 sec Remove/Install battery now ! i am new to infinity. |
03-09-2009, 06:38 | #2 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Try to press power on button Long time (About 1 minute) If phone still is not power up then try to flash the phone with EEPROM file or flash the phone with original firmware. Post result. |
03-09-2009, 06:54 | #3 (permalink) |
Member: 491880 Status: Offline Sonork: 1620586 Thanks Meter: 9 | this area was good before flashing detect standard fat location .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok: element #1 detecting ffs structure pass 2... ..................... detect standard fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 58 sec Remove/Install battery now ! |
03-09-2009, 06:58 | #4 (permalink) |
Member: 491880 Status: Offline Sonork: 1620586 Thanks Meter: 9 | Before flashing COM4 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4F03:000C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S1-ML_MR106_006_5S01-MC-C01-RF3198_V1_0_017_080226.BIN ver. sw 2: FXD-S1-ML_MR106_006_5S01-MC-C01-RF3198_V1.0.017_080226, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ..................... detect standard fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok: element #1 detecting ffs structure pass 2... ..................... detect standard fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 58 sec Remove/Install battery now ! |
sigmatel fxd s90 plz help | shakir hashmi | Infinity-Box | 3 | 04-08-2009 18:29 |
sigmatel s1 dead after flash | bhogpurmail | Infinity-Box | 18 | 09-22-2008 18:40 |
sigmatel s1 dead by format | jitugrover | SpiderMan | 5 | 09-21-2008 14:34 |
sigmatel s1 dead | jitugrover | Chinese Models & Cloned Phones | 2 | 08-08-2008 12:24 |
°°°°((( Plz help, my Smart clip is Dead Plz help )))°°° | xsat2004 | Smart-Clip | 3 | 09-20-2007 13:52 |
