01-25-2021, 15:34 | #136 (permalink) |
No Life Poster Join Date: Mar 2010 Location: djerba
Member: 1269161 Status: Offline Thanks Meter: 119 | Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0003296FFF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 35D9296F Firmware version: 0147.02 === Process started: 25/01/2021 10:30:52 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
01-25-2021, 16:07 | #137 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Result ? | |
01-25-2021, 16:08 | #138 (permalink) | |
Please make step-by-step NOW: - reboot PC - update dongle with DongleManager - delete fault.bin file (if any) Before run Infinity CM2MT2 always close boot-helper installation package ! | |
01-25-2021, 16:25 | #139 (permalink) |
Junior Member Join Date: Feb 2009 Location: information
Member: 980481 Status: Offline Sonork: information Thanks Meter: 15 | === DongleManager [Infinity] v1.81 [25/01/2021 17:24:26] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000134811384082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 9FA11348 Firmware version: 0147.02 === Process started: 25/01/2021 17:24:28 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 Disconnected |
The Following User Says Thank You to eslamhero For This Useful Post: |
01-25-2021, 16:29 | #140 (permalink) | |
01-25-2021, 16:50 | #141 (permalink) |
Junior Member Join Date: Jun 2017 Location: Maputo,nampula
Member: 2730213 Status: Offline Thanks Meter: 2 | === DongleManager [Infinity] v1.81 [25.1.2021 17:47:54] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: USB CCID Smart Card Reader 0 HWID: 00010B1221344082 === Process started: 25.1.2021 17:47:54 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
01-25-2021, 17:07 | #142 (permalink) |
Crazy Poster Join Date: Dec 2009 Location: perlas ng silangan
Member: 1189220 Status: Offline Thanks Meter: 22 | please help.. === DongleManager [Infinity] v1.81 [26/01/2021 0:05:49] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0039149587564812 === Process started: 26/01/2021 0:05:49 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
01-25-2021, 17:26 | #143 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Quote:
Hello, Please make step-by-step NOW: - reboot PC - update dongle with DongleManager - delete fault.bin file (if any) | |
01-25-2021, 17:28 | #144 (permalink) |
Insane Poster Join Date: Mar 2017 Location: VIETNAM
Member: 2690714 Status: Offline Thanks Meter: 59 | CM2 Smart-Card misconfiguration! Contact to support! please help me === DongleManager [Infinity] v1.81 [25/01/2021 23:24:51] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000092721CC74082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 16EC9272 Firmware version: 0147.02 === Process started: 25/01/2021 23:24:52 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
01-25-2021, 17:33 | #145 (permalink) | |
Junior Member Join Date: Oct 2015 Location: kebumen
Member: 2467445 Status: Offline Thanks Meter: 14 | Quote:
step : -remove all connected software tool from pc -uninstall cm2 mt2 ver 2.17 -reboot pc -install cm2 mt2 ver 2.18 -install libusb, uncheck "Launch filter installer wizard" -close cm2 setup and libusb setup after finish installation -connect cm2 dongle, update with dongle manager -problem solved, all infinity's software working fine thanks team Last edited by 74mantrihp; 01-25-2021 at 17:38. | |
The Following User Says Thank You to 74mantrihp For This Useful Post: |
01-25-2021, 17:44 | #146 (permalink) | |
01-25-2021, 17:46 | #147 (permalink) | |
This Smart-Card is not an Infinity Smart-Card 1. Disconnect all other Boxes and Dongles from PC 2. Connect ONLY one Infinity Box/Dongle to PC | |
01-25-2021, 17:47 | #148 (permalink) | |
01-25-2021, 18:11 | #149 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1892137 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.81 [25/01/2021 22:29:46] === Box/Dongle type selected: Infinity-Box/Dongle [CM2] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000FF2313114082 Box/Dongle found: Infinity-Box/Dongle [CM2] Reading... Serial No (S/N): 963CFF23 Firmware version: 0147.02 === Process started: 25/01/2021 22:29:47 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 |
01-25-2021, 18:13 | #150 (permalink) | |
