Hi!Please help sir. === DongleManager [Infinity] v1.75 [10.05.2020 13:28:39] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0002806818201292 === Process started: 10.05.2020 13:28:39 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
it is best dongle i add cm2 activation 24.02.2020 my serial number B6858068 |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
Hi!Please help sir. Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.78 [11.05.2020 13:35:49] === Searching... Card-Reader: FT SCR2000 0 HWID: 01039D5E1C6A1292 Box/Dongle is not found === DongleManager [Infinity] v1.78 [11.05.2020 13:35:55] === Searching... Card-Reader: FT SCR2000 0 HWID: 01039D5E1C6A1292 Select Token Type: instead of Autodetect === DongleManager [Infinity] v1.78 [11.05.2020 13:36:04] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 01039D5E1C6A1292 === Process started: 11.05.2020 13:36:05 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 now result |
I HAVE SAME PROBLEM === DongleManager [Infinity] v1.80 [16/05/2020 14:20:47] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0200735F1DCF1292 === Process started: 16/05/2020 14:20:47 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 Disconnected https://www.up-00.com/i/00173/bv58jmefp7pt.png |
My dongel not found after update dongel is not connected |
please follow the procedure from my prvious post. What is your results ? |
Please read an instruction carefully ! Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) OR Use another PC The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
Hello, === DongleManager [Infinity] v1.80 [5/17/2020 13:45:49] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00011D7713E64082 === Process started: 5/17/2020 13:45:49 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
Thanks work 100% i change pc |
Try once again now |
Thank you === DongleManager [Infinity] v1.80 [5/17/2020 19:38:09] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00011D7713E64082 === Process started: 5/17/2020 19:38:09 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed === Process finished: 5/17/2020 19:38:29 === === DongleManager [Infinity] v1.80 [5/17/2020 19:38:29] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00011D7713E64082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 7F411D77 Firmware version: 0137.02 => Activations: - 00: Infinity-Box/Dongle v0137 - 07: #7 => Options: - Infinity-Box/Dongle - Infinity SM |
