GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   Smart-Card/Dongle/Box update problems and solutions (https://forum.gsmhosting.com/vbb/f296/smart-card-dongle-box-update-problems-solutions-2735926/)
ALI@1 05-21-2020 15:32
Originally Posted by InfinityHelp (Post 14095849)
Yes my friend, there is a problem. You must find fault bin file and explain why do you use such tools.
I need InfinityBox BEST2
what should I do now ?
wrcti1 05-21-2020 15:32
hello
i updated my best dongle by dongle manager and failed. dongle manager could read HWID. after unistalling dongle drivers the dongle manager cant identify dongle and dongle blinks. dongle manger shows following message:
"dongle cant be found:
error when listing readers
smart card api error #2148532270
cannot find a smart card reader"
ALI@1 05-21-2020 15:35
Originally Posted by InfinityHelp (Post 14095851)
Much better my friend, much better.
Now update dongle firmware and don't run "internet download accelerator" at the same time with Infinity software.
is okkk
=== DongleManager [Infinity] v1.80 [5/21/2020 19:03:23] ===
Searching...
Card-Reader: FT SCR2000 0
HWID: 00000CDB12534082
Box/Dongle found: [BEST]
Reading...
Serial No (S/N): 4A7F0CDB
Firmware version: 0122.02
=== Process started: 5/21/2020 19:03:27 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication successfull
Service stage 1 confirmed
Securing session...
Session secured ok
Upgrading dongle...
Wait 4-5 minutes ! DO NOT disconnect Box/Dongle !
Applet upgrade ok
Identification Ok. Finalizing...
Finalizing ok
Process completed
=== Process finished: 5/21/2020 19:04:04 ===
=== DongleManager [Infinity] v1.80 [5/21/2020 19:04:04] ===
Box/Dongle type selected: [BEST]
=> Activations:
- 00: Infinity-Box/Dongle v0143
- 03: [BEST] v0122
=> Options:
- Infinity BEST
thank you very much
naderhacker 05-21-2020 15:46
Originally Posted by InfinityHelp (Post 14095842)
No need to "wait 24 or 1984" hours. Server gives one try *after supporter's confirmation). If supporter told "do it" - do it otherwise you can wait several years, server do not allow it anyway
ok , tried to update received the below error
HWID: 0105978224881292
=== Process started: 5/21/2020 16:44:35 ===
Securing session...
Session secured ok
Upgrading dongle...
Card returned error - 0000 at 203/13367
Error upgrading applets:
Disconnected
InfinityHelp 05-21-2020 16:13
Securing session...
Session secured ok
Upgrading dongle...
Disconnected
Do you hve another card-reder or another PC to try ?
naderhacker 05-21-2020 16:22
yes sure , smart card now is in another reader
and i can use other pc
naderhacker 05-21-2020 16:43
thanks all ok
thanks great support
appreciate it:)
mir hassan 05-21-2020 16:48
=== DongleManager [Infinity] v1.80 [5/18/2020 23:41:18] ===
Searching...
HWID: 0000BAD27F634082
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): DCF8BAD2
Firmware version: 0143.02
=== Process started: 5/18/2020 23:41:21 ===
Authentication stage error:
Server answer:[0031] Dongle identification data damaged.
Contact to http://www.infinity-box.com/support/?r=2
Plz help anyone
InfinityHelp 05-21-2020 16:49
Searching...
Reading...
Plz help anyone
What tools do you use to damage dongle ?
wrcti1 05-21-2020 16:53
=== DongleManager [Infinity] v1.80 [5/21/2020 20:12:12] ===
HWID: 0006706C08771292
=== Process started: 5/21/2020 20:12:12 ===
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Contact to infinity box support
InfinityHelp 05-21-2020 17:13
Hello,
Install required Card-Reader Drivers:
- File with Drivers: CardReader_Fetian_FT2K.7z
- File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
Download files - https://www.infinity-box.com/support/?r=6
OR
Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader)
The next steps are:
- run DongleManager
- update Dongle firmware
IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again !
angeldead90 05-21-2020 17:32
Hi, Infinity Team, i hace a problem with my dongle, here is teh log
=== DongleManager [Infinity] v1.80 [21/05/2020 12:29:48] ===
Searching...
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 00037D7100001942
Box/Dongle is not found
Thanks in advance
wrcti1 05-21-2020 17:36
Originally Posted by InfinityHelp (Post 14095919)
Hello,
OR
The next steps are:
- run DongleManager
=== DongleManager [Infinity] v1.80 [5/21/2020 21:01:49] ===
=== Process started: 5/21/2020 21:01:49 ===
Securing session...
Session secured ok
Upgrading dongle...
Card returned error - 0000 at 6700/8848
Disconnected
mophatc 05-21-2020 17:38
InfinityHelp 05-21-2020 17:55
What is your dongle S/N ?
Page generated in 0.25356 seconds with 6 queries
