=== DongleManager [Infinity] v1.74 [3/12/2020 17:54:48] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0109776824881292 === Process started: 3/12/2020 17:54:48 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
reader also change driver ok . error again plz fix this solution always update time this problem other dongol no problem update :(:(:( === DongleManager [Infinity] v1.74 [3/13/2020 17:24:39] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0109776824881292 === Process started: 3/13/2020 17:24:39 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Error upgrading applets: Card returned error - 0000 at 6099/8681 Disconnected |
Follow the instruiction: Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
=== DongleManager [Infinity] v1.72 [20-Mar-20 16:22:34] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 020365721C6A1292 === Process started: 20-Mar-20 16:22:34 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
error update firmware |
hello i have this problem ! how to fix ??? https://i111.fastpic.ru/big/2020/040...5140058f91.png Quote:
Hi, today is 04 Apr but not 24 Mar Why do you post old screensots ? Is it by mistake or do you want to hide something ? |
Hi I have had this problem with Best and Best2 for 7 days. This is a new photo. https://i111.fastpic.ru/big/2020/040...b22699f97c.png Quote:
photo is not requered. You should find file with name fault.bin in BEST or BEST2 folder. Instruction - https://www.infinity-box.com/support/?r=4 Waiting for your result, information and fault.bin file. |
I didn't find the fault.bin file on my computer or in the Best2 folder. Where is the exact location of this file? If you can check using Teamviewer or anydesk? |
waiting |
