Update it once again now. Result ? |
plz sir solve my problem ==== [5/21/2020 16:14:36] ==== Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.80 [5/21/2020 16:14:39] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00032980FF021982 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 355B2980 Firmware version: 0143.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0143 => Activations: - 00: Infinity-Box/Dongle v0143 - 07: #7 - 0B: #11 - 0E: #14 => Options: - Infinity-Box/Dongle - Infinity SM - hua - avator === DongleManager [Infinity] v1.80 [5/21/2020 16:14:59] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00032980FF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 355B2980 Firmware version: 0143.02 === Process started: 5/21/2020 16:15:03 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 ==== [5/21/2020 23:00:16] ==== Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.80 [5/21/2020 23:00:20] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00032980FF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 355B2980 Firmware version: 0143.02 === Process started: 5/21/2020 23:00:23 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
Please attach here fault.bin file from Infinity CM2MT2 software folder |
Sir do not have fault.bin file but its problem after install 2.10 then uninstall and all folder again setup install same error after we do update firmware this one problem.. |
BEST Dongle Problem My BEST Dongle not working i Tried to update with Dongle manger now i m Facing this Problem kindly help me in this matter here is Log === DongleManager [Infinity] v1.80 [5/22/2020 12:03:39] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0102976910321292 === Process started: 5/22/2020 12:03:39 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 THANKS IN ADVANCE INFINITY TEAM |
After that update dongle firmare with DongleManager to fix "misconfiguration" message |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
INFINITY TEAM My Dongle Alive Back |
please help me === DongleManager [Infinity] v1.80 [5/22/2020 14:37:47] === Box/Dongle type selected: [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00013780162D4082 Box/Dongle found: [BEST] Reading... Serial No (S/N): 623C3780 Firmware version: 0122.02 === Process started: 5/22/2020 14:37:48 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
Fix PC as per instruction - https://www.infinity-box.com/news/?r=3999 After that update dongle firmware with DongleManager to fix "misconfiguration" message |
== DongleManager [Infinity] v1.80 [5/22/2020 17:27:25] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00021E8C00001942 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 9C6C1E8C Firmware version: 0143.02 === Process started: 5/22/2020 17:27:29 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 pls quick solution sn.9C6C1E8C probleem .Server answer:[0031] Dongle identification data damaged. pls quick solution === DongleManager [Infinity] v1.80 [5/22/2020 17:50:42] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00021E8C00001942 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 9C6C1E8C Firmware version: 0143.02 === Process started: 5/22/2020 17:50:46 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
dongle update erroe after 2 month use covid plz help urgent === DongleManager [Infinity] v1.80 [5/23/2020 9:04:22] === Box/Dongle type selected: [BEST] Card-Reader: SCM Microsystems Inc. SCR33x USB Smart Card Reader 0 HWID: 0102827B10321292 === Process started: 5/23/2020 9:04:23 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
