09-02-2015, 12:38 | #24871 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2406517 Status: Offline Sonork: 100.1641481 Thanks Meter: 38 | Q mobile e4 read code done Phone found! [ 35 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 87939F225252EBFBCD2DB65A9E473C51 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Read ExtData Sorting ExtData Reading UserCode Active : No , Code : 5555 PLock|MobTrack : Not active Done! BR GSM BOSS:coo l: |
09-02-2015, 12:40 | #24872 (permalink) |
Member: 2406517 Status: Offline Sonork: 100.1641481 Thanks Meter: 38 | Q mobile r850 read code done . Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 35 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 562E2923FCC020C287223EC41477BD4B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E [0] : FLASH_DIE : 00C2 0025 0037 0000 [0] : FLASH_LEN : 0x00800000 SDS : 0x007FE000 , 0x00002000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! BR GSM BOSS |
09-02-2015, 12:43 | #24873 (permalink) |
Member: 2406517 Status: Offline Sonork: 100.1641481 Thanks Meter: 38 | Q mobile x80 read flash done Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D420170C1D66571D9 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D420170C1D66571D9 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : w1401_q_mobile ProdModel : QMobile X80 Device : w1401_q_mobile AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : QMobileX80_MP_10_13 [Read Ok] : preloader_w1401_q_mobile.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / w1401_q_mobile / EMMC FW Size : 755 MiB Scatter saved to : C:\Documents and Settings\maanarman\Desktop\MT6572__QMobile__QMobil e X80__w1401_q_mobile__4.4.2__QMobileX80_MP_10_13\ All done! Done! BR GSM BOSS |
09-02-2015, 13:05 | #24874 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | nokia 225 Code: Verify files ... MAUI : RM-1011_ROM_eMP_10.01.11 VIVA : RM-1011_VIVA_eMP_10.01.11 LANG : RM-1011_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 JMPT : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 43 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : CCA624B2C5C57973067555D781A36E4A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_10.01.11 SecureDecrypt : RM-1011_VIVA_eMP_10.01.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 SecureDecrypt : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : PEARL.20.10.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_10.01.11 Write : RM-1011_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1011_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1011_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1011_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:49 Reboot phone Ok |
09-02-2015, 13:06 | #24875 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | nokia 108 flashing Code: Verify files ... MAUI : RM-944_ROM_eMP_12.06.11 VIVA : RM-944_VIVA_eMP_12.06.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 JMPT : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 43 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : EA5102B2BAE47C824BC3543E4CE9271F BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.12.06.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_12.06.11 SecureDecrypt : RM-944_VIVA_eMP_12.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 OVRLP : 000069B900000001 PHPID : Bree.12.06.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001B000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_12.06.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 Write : RM-944_VIVA_eMP_12.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_12.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_12.06.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:00:56 Reboot phone Ok |
09-02-2015, 13:16 | #24876 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | karbon a52 format done read info Code: Operation : Check / Read Info [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. NAND : Structure detect done [30/76] [AP] : Initial info read Ok! Done! Elapsed: 00:01:02 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
09-02-2015, 13:23 | #24877 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile_X25_4.4.2 Read Pattern Lock Read Just 00:20" Successful, Done .:: BY ::. ..::: Chinese Miracle-2 MTK:::.. Code:
The Following 3 Users Say Thank You to kabul For This Useful Post: |
09-02-2015, 13:33 | #24878 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | nokia 202 flash Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm834__20.52.mcusw PPM : rm834__20.52.ppm_m_a CNT : rm834__20.52.image_m_a_059M6C0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.47_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 352853057071900 IMEI 2 : 352853057071918 PCcode : 059M692 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352853057071900_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm834__20.52.mcusw Image : rm834__20.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:00:54 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Region flash done, time : 00:00:46 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xD2A9 ===Flashing [PPM]=== File : rm834__20.52.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41DC0000 , Len : 0x0041B6E4 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0xBBFE ===Flashing [CNT]=== File : rm834__20.52.image_m_a_059M6C0 Image : package_m_a_059M6C0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:01:13 Write , Start : 0x424C0000 , Len : 0x00CC0000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xC996 Flashing done! Total flash time : 00:03:35 Reboot phone now... Reading Phone Info.... Connected phone - 202 Software Info: V 20.52 27-09-12 RM-834 (c) Nokia IMEI: 352853057071900 PPM version : V 20.52 27-09-12 RM-834 (c) Nokia M_A Product code: 059M692 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... ===== WARNING ===== Battery voltage is can be not enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:31 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
09-02-2015, 14:26 | #24879 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Intex Aqua Life2 Patterlock Remove Done Read Info Code: Operation : Check/Read Info [ v1.03 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 com7Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/SC7731 loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : v120_kew_281 Model Brand : Intex Model Device: v120_kew_281 AndrVersion : 4.4.2 BaseBand CPU: V120_KEW_281 CompileDate : 1429495480 Project Ver : KOT49H 14B_test-keys Model Ext : Aqua Life II Elapsed: 00:00:27 Reconnect Power/Cable! Code: Operation : Format File System [ v1.03 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 0A Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/SC7731 loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000B53FB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:24 Reconnect Power/Cable! Code: Operation : Read NV [ v1.03 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 rt (Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/SC7731 loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Read NVM Part #1 Part Ok Read NVM Part #2 Part Ok Saved to : C:\Users\Desktop\CX_SPDNV Intex Aqua Life2.spdnv |
The Following 2 Users Say Thank You to ishant For This Useful Post: |
09-02-2015, 14:27 | #24880 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Pakistan TDM
Member: 1330570 Status: Offline Sonork: 100.1611533 Thanks Meter: 408 | Vgo Tel V2 successfully flash Operation : Flash [ v1.28 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E355530304D024705809780C1 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00U5 [eMMC] : FLASH_CID : 1501004E355530304D024705809780C1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : konka72_i120_emmc_j , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x00000000E5C20000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_konka72_i120_emmc_jb3.b Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:01:08 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:28 Update RomInfo done Done! Elapsed: 00:02:00 Reconnect Power/Cable! |
09-02-2015, 14:35 | #24881 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Qmobile E990 Code: Elapsed: 00:01:14 Reconnect Power/Cable! Operation : Flash [ v1.28 ] ======= Flash Files set for flashing : [ MCU ] : WBG2306QM_0201_PCB01_gprs_MT6260_S00.2306QM_0201_V0674.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 22 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 41D83F62BF750AFD0AF3C22AD2998D5E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : DONE NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_BLANK_FLASH SDS : 0x00000000 , 0x00000000 File_Info : WBG2306QM_0201_PCB01_gprs_MT6260_S00.2306QM_0201_V0674.bin FileVersion : 2306QM_0201_V0674 Flash now Erase region , wait ... Write data , wait ... Write : WBG2306QM_0201_PCB01_gprs_MT6260_S00.2306QM_0201_V0674.bin Done! Elapsed: 00:01:36 Reconnect Power/Cable! |
09-02-2015, 15:11 | #24882 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | XIAOMI__2013023 Read Flash Done Code: Operation : Read Flash [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 140 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 5300014534304D45B45328470D31E5AA DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034472853B4AAE5310D [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : Xiaomi ProdName : 2013023 ProdModel : 2013023 Device : HM2013023 AndroidVer: 4.2.2 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.31 Saved to : L:\Mi Phone\bin\MT6589__XIAOMI__2013023__HM2013023__ALPS.JB2.MP.V1.31__Android_4.2.2__20140702_032519.ispff Done! Elapsed: 00:16:51 Reconnect Power/Cable! |
09-02-2015, 15:31 | #24883 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia x201 Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm709__08.65.mcusw PPM : rm709__08.65.ppm_ma3 CNT : rm709__08.65_004.image_ma3_ctv_pk_deep_9g8p4 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000E02E63C458CF437FFB08F82EC259BD ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09 ADL: phone is in flash mode === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm709__08.65.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm709__08.65.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 504 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000002 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm709__08.65.ppm_ma3 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm709__08.65.ppm_ma3 Total writen 105 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm709__08.65_004.image_ma3_ctv_pk_deep_9g8p4 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm709__08.65_004.image_ma3_ctv_pk_deep_9g8p4 Total writen 563 blocks TIME : Write time : 00:00:05 CNT Write done ADL: Request programm status NAND status : 00000002 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000020000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:14 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 39 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:00:57 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
09-02-2015, 15:33 | #24884 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Spice QT-75 hang at logo repaired by Format- Quote:
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
09-02-2015, 15:35 | #24885 (permalink) |
No Life Poster Join Date: Apr 2011 Location: india
Member: 1566457 Status: Offline Thanks Meter: 189 | Micromax A104 Unknoun BaseBand Done by CM2 Micromax A104 Unknoun BaseBand Done i write A104 same nv file with other tool after writing BaseBand ok when i restart mobile prob. still same. then i use cm2 my prob. solve now. thanks to pradeep_kushwah for help |
The Following 2 Users Say Thank You to khandudecool01 For This Useful Post: |
