Old 06-20-2018, 13:17   #50296 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 737
read firmware asus zenfone selfie z00ud
Operation : Read Flash [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 610 [MSM8936]
ID_BLOCK_S : 015585B6
ID_BLOCK_E : 11112222
ID_BLOCK_L : 0F6D548069BC6EE02E06CAC33E46A502
ID_BLOCK_L : 6AB1F20E701A8D527565B38950769D50
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Brand     : asus
ProdName  : WW_Z00T
ProdModel : ASUS_Z00TD
Device    : Z00T
AndroidVer: 6.0.1
Manufact. : asus
QLMxCPU   : MSM8916
DevInfo : MSM8916__asus__asus__ANDR_v6.0.1__ASUS_Z00TD__Z00T__WW_Z00T
Reading Flash Content ...
[Read Ok] : gpt_main0.bin
[Read Ok] : sbl1.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : hyp.mbn
[Read Ok] : ddr.bin
[Read Ok] : sec.dat
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : splash.img
[Read Ok] : fs_gc.img
[Read Ok] : misc.img
[Read Ok] : asdf.bin
[Read Ok] : abootdebug.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : persist.img
[Read Ok] : NON-HLOS.bin
[Read Ok] : adf.bin
[Read Ok] : apd.bin
[Read Ok] : cache.img
[Read Ok] : system.img
[Read Ok] : userdata.img
[Read Ok] : gpt_backup0.bin
Android Info saved!
Read finished!
Configuration : MSM8936 / eMMC
Firmware Size : 3349 MiB
Done!
Elapsed: 00:05:13
Reconnect Power/Cable!
Old 06-20-2018, 13:18   #50297 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile I6 Metal 1 V2 SPD77xx Pattren Reset Done With King Infinity CM2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 191 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:21
Old 06-20-2018, 13:54   #50298 (permalink)
Member: 931121
Thanks Meter: 100
walton mm11 read code done by infinity box
Card found : S/N : 64C1CE3F , v0137
Operation : Check / Read Info [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 9 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 82FDDC19BFB6590CE0CB371D654EC599
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Done!
Elapsed: 00:00:02
Operation : Read UserCode [ v1.58 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 74369
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:03
Old 06-20-2018, 14:11   #50299 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Arrow Redmi 5a frp removed
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 425 [MSM8917]
ID_BLOCK_S : A11BBE24
ID_BLOCK_L : 3A67E4C26A79AFF283D56322B624D4FB
ID_BLOCK_L : E51369C80F2E38F6E178998CEB638FF2
Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GD6BMB
Boot Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:37
Old 06-20-2018, 14:13   #50300 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Yu pattern lock removed
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 19D7FE5D
ID_BLOCK_L : 6A9AF00EA935222D1A4F818E4910A0A8
ID_BLOCK_L : B2C14FDED342EC799C5B3CF5FF36202B
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:21
Old 06-20-2018, 14:14   #50301 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Arrow Redmi y1 lite flashing done
Operation : Flash [ v1.16 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 5474245D
ID_BLOCK_L : F1BE2D09B3B26639582CBCEB7FEF2F20
ID_BLOCK_L : 3CB8B211A4F79F4F089330334CBA665B
Pickup loader from firmware package
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE63MB
Boot Ok!
Flash Chain : 51
Flashing now
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : devcfg.mbn
Flashing : adspso.bin
Flashing : splash.img
Flashing : emmc_appsboot.mbn
Flashing : boot.img
Flashing : recovery.img
Flashing : system.img
Flashing : cache.img
Flashing : config.bin
Flashing : mdtp.img
Flashing : cmnlib.mbn
Flashing : cmnlib64.mbn
Flashing : keymaster.mbn
Flashing : cust.img
Flashing : userdata.img
Flashing : gpt_main0.bin
Flashing : gpt_backup0.bin
Flash sequence completed!
Applying patches for storage # 0
Records : 26
Patch sequence completed!
BootConfig set to 0x00
Flashing done!
Done!
Elapsed: 00:02:54
Old 06-20-2018, 14:16   #50302 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Intex aqua lions x1 frp removed
Start  at : [6/20/2018 / 5:26:17 PM]
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A0190613447410068A4325B208110
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GA
[eMMC] : FLASH_CID : 90014A484147346132A468001081925B
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID    : 0xFA6E6E938BA622A4546AD8EFB8F43E3D
INT RAM    : 0x00020000
EXT RAM    : 0x80000000 [2 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:12
Old 06-20-2018, 14:19   #50303 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Lightbulb HI-TECH Amaze S305 READ FLASH DONE
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID    : 0xFA6E6E93048EDA5C6AF22AA6CAC8667D
EXT RAM    : 0x10000000 [256 MiB]
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
[Read Ok] : preloader_hexing72_cwet_lca.bin
[Read Ok] : lk.bin
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : usrdata.img
[ScatCFG] : MT6572 / V1.1.1 / hexing72_cwet_lca / NAND
FW Size : 256 MiB
Brand     : alps
ProdName  : Amaze S305
ProdModel : Amaze S305
Device    : hexing72_cwet_lca
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : Amaze_S305
Android Info saved
Scatter saved to : C:\Users\Vijay\Downloads\MT6572_NAND_alps__Amaze S305__hexing72_cwet_lca__4.4.2__Amaze_S305
Done!
Elapsed: 00:02:26
Old 06-20-2018, 14:34   #50304 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Nokia 112
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm837__03.51.mcusw
PPM : rm837__03.51.ppm_m2
CNT : rm837__03.51.image_m2_059P7C1
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.50_M1S1
Speed accepted, use 6.500.000
FLASHID : EC001230
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 355485054206085
IMEI 2 : 355485054206093
PCcode : 059P7C1
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\355485054206085_XG 213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
===Flashing [MCU]===
File : rm837__03.51.mcusw
Image : rm837__03.51.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:02
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01940000
Erasing, wait ...
Erase done, time : 00:00:51
Write , Start : 0x40280000 , Len : 0x018C0000
Flashing , wait ...
Region flash done, time : 00:00:35
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0x87F4
===Flashing [PPM]===
File : rm837__03.51.ppm_m2
Image : package_m2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41BC0000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:06
Write , Start : 0x41BC0000 , Len : 0x0030F7C0
Flashing , wait ...
Region flash done, time : 00:00:03
CRC check passed , 0x46E6
===Flashing [CNT]===
File : rm837__03.51.image_m2_059P7C1
Image : package_m2_059P7C1.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:01:23
Write , Start : 0x421C0000 , Len : 0x00EE0000
Flashing , wait ...
Region flash done, time : 00:00:20
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:01
No write data, skip
CRC check passed , 0x2559
Flashing done!
Total flash time : 00:03:27
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia 112
Software Info: V 03.51 06-08-13 RM-837 (c) Nokia
IMEI: 355485054206085
PPM version : V 03.51 06-08-13 RM-837 (c) Nokia M2
Product code: 059P7C1
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 58 certs
Certificates found, skip upload ...
AfterFlash operations done ;D
Done!
Connect phone on selected interface...
Elapsed: 00:04:29
Old 06-20-2018, 14:51   #50305 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 1,274
Alcatel 5022D Read Pattern done
Card found : S/N : 07EDXXXX , v0136
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Running DA ver.4.2 on BBID : 0x9C
eMMC Flash : 150100513732534D420001BE6AE23307
[eMMC] : FLASH_INF : [SAMSUNG] , BMS27
[eMMC] : FLASH_CID : 150100513732534D420001BE6AE23307
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x7FBB5333425FD65CD43A13E16293E6BC
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : TCL
ProdName : 5022D
ProdModel : 5022D
Device : PLAY-5
AndroidVer: 5.1
MTKxCPU : MT6580
MTKxPRJ : ALPS.L1.MP6.V2_AUS6580.WE.L_P81
Done!
Elapsed: 00:00:20
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 635241789
Done!
Elapsed: 00:00:24
The Following User Says Thank You to gile@gile For This Useful Post:
Old 06-20-2018, 15:30   #50306 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 737
ASUS ZENFONE LIVE ZB501KL (ASUS A007) enable adb and reset frp
Operation : Reset FRP [ v1.03 ]
Mode : Remove ASUS GENERIC FRP
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
ADB activated!
- > Info : Wait till device boot, make offline setup until device show message about protection
- > Info : Re-connect cable, make "FRP Reset" in ADB tab!
Done!
Elapsed: 00:00:07
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Device not found! Check cable, drivers and conection!
Connect Ok!
Error : Fail to init secure handshake!
Check cable, connection, drivers and AUTH dialog on device screen!
Connect Ok!
Device : WW_Phone
Model  : ASUS_A007
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:07
The Following 2 Users Say Thank You to sky73 For This Useful Post:
Old 06-20-2018, 16:16   #50307 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,421
BLU STUDIO 5.0 LTE READ FIRMWARE & RESET USERLOCK DONES
Operation : Identify [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 08FE6DDF
ID_BLOCK_L : E41C76802FBBA0A39CF1030CCB961E2E
ID_BLOCK_L : D5A816B9BA25951EB302578C86690744
Boot Ok!
Brand     : BLU
ProdName  : STUDIO5.0LTE
ProdModel : BLU STUDIO 5.0 LTE
Device    : msm8916_32
AndroidVer: 4.4.4
Manufact. : BLU
SysPatch  : KTU84P
DevComTime: 18/06/2015 10:57:31
QLMxCPU   : MSM8916
QLMxPRJ   : BLU_Z030Q_V09_GENERIC_20150618-1857
USERData : NORMAL
GCSec    : NORMAL
Done!
Elapsed: 00:00:23
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Brand     : BLU
Device    : msm8916_32
AndroidVer: 4.4.4
Manufact. : BLU
QLMxCPU   : MSM8916
DevInfo : MSM8916__BLU__BLU__ANDR_v4.4.4__BLU_STUDIO_5.0_LTE__msm8916_32__STUDIO5.0LTE__BLU_Z030Q_V09_GENERIC_20150618-1857
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : hyp.mbn
[Read Ok] : sec.dat
[Read Ok] : gpt_main2.bin
[Read Ok] : cdt.mbn
[Read Ok] : gpt_backup2.bin
Android Info saved!
Read finished!
Configuration : MSM8916 / eMMC
Firmware Size : 1091 MiB
Done!
Elapsed: 00:03:12
Operation : Reset UserLocks [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Direct access : Ok!
Processing step #1
Processing step #2
Processing step #3
Processing step #4
Processing step #5
Processing step #6
Processing step #7
UserLocks reset passed!
1. Power On phone, wait 30-50 second, press and hold PowerOn button until device restart!
2. To disable/remove fingerprints enter in Settings -> FingerPrint, set any password, remove fingerprints
3. In some cases require reboot phone twice or wait up to 5 minutes!
Done!
Elapsed: 00:00:56
The Following User Says Thank You to Kirumira For This Useful Post:
Old 06-20-2018, 17:00   #50308 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,421
Lenovo K50-T5 DL IMAGE FAILED & UPGRADE TO ADROID 6.0 DONE
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6752
BB_CPU_NME : [MediaTek] MT6732|MT6752_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8F
eMMC Flash : 150100523832314D42007E1BC2CEA22F
[eMMC] : FLASH_INF : [SAMSUNG] , BM128
[eMMC] : FLASH_CID : 150100523832314D42007E1BC2CEA22F
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID    : 0x0E03E514EC136C91BE71CAC5BC2BD126
SOC VERIFY : C1
Boot Ok!
Brand     : Lenovo
ProdName  : full_aio_otfp
ProdModel : Lenovo K50-T5
Device    : aio_otfp
AndroidVer: 5.0
MTKxCPU   : MT6752
MTKxPRJ   : K50-T5_USR_ST1511_5.444.1_1503111505_MP6V3_CN
SECURITY :
IMEI_SW [1] : 3XXXXXXXXXXX
IMEI_SW [2] : 35XXXXXXXXXXXX
BTMAC Addr  : A03299FD3C68
WiFi MAC    : 5427580F3C68
MODEM :
BaseBand  : MT6752_S00_K50T5_LTG_V21_1_ltg_n
EXTRA :
LCD [0] : nt35595_fhd_dsi_cmd_truly_nt50358
LCD Res : 1920x1080
TOUCH [0] : GT9XX_hotknot
CAM [0] : ov13850sunny_mipi_raw
CAM [1] : ov13850ofilm_mipi_raw
CAM [2] : ov5670_mipi_raw
MODEM : aio_5m_ltg_dsds aio_5m_lwg_dsds
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:17
Operation : Fix DL Errors [ v1.58 ]
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6752
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
DA DLFix Passed!
Done!
Elapsed: 00:00:11
Scatter Load Ok , BaseBand : MT6752 , Project : aio_5m , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : Lenovo
Device Model   : K50-t5
Device CPU     : MT6752
Device IntName : aio_otfp
Device Version : 6.0
Device Compile : 15/03/2016 01:06:25
Device Project : K50-t5_USR_S422_1603150849_mp1V2.39_ROW
Device ExtInfo : Lenovo K50-t5
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6752
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6752 , Project : aio_5m , Storage : EMMC
Setting : AFF verify :  Enabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 4059 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001C80000-0x0000000006320000
Erase : 0x0000000008800000-0x000000039A580000
Flash Pre-Erase Done, time used : 00:00:08
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_aio_5m.bin
Preloader Sent , Init passed
PartCount : 0013
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:08:39
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : SECRO
Verify Passed : LOGO
Verify Passed : TEE1
Verify Passed : TEE2
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:10
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:09:31
Old 06-20-2018, 17:09   #50309 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Thumbs up Intex_elyt_dual flashing done
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : INTEX_ELYT_DUAL_V09_INDIAN_1205_1801_user_lockV06.pac
CRVersion  : BP_R1.0.0
PacCPUinfo : sp9850ka_2c20
PacVersion : INTEX_ELYT_DUAL_V09_INDIAN_1205_1801_user_lockV06
File : fdl1-sign.bin
File : fdl2-sign.bin
File : ltenvitem.bin
File : prodnv.img
File : u-boot-spl-16k-sign.bin
File : ltemodem.bin
File : ltedsp.bin
File : ltegdsp.bin
File : pmsys.bin
File : wcnmodem.bin
File : boot.img
File : recovery.img
File : sysinfo.img
File : system.img
File : userdata.img
File : logo.bmp
File : logo.bmp
File : cache.img
File : tos-sign.bin
File : sml-sign.bin
File : u-boot-sign.bin
File : persist.img
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x1D records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID   : SPLLOADER
Current File : u-boot-spl-16k-sign.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_LTE
Current File : ltemodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_LTE_LTE
Current File : ltedsp.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_LTE_GGE
Current File : ltegdsp.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DFS
Current File : pmsys.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : wcnmodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSINFO
Current File : sysinfo.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : logo.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH_LTE
Current Part : l_runtimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : TRUSTOS
Current File : tos-sign.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : SML
Current File : sml-sign.bin
Flashing now ...
[FlashProc] : Ok!
Current ID   : UBOOTLOADER
Current File : u-boot-sign.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : PERSIST
Current File : persist.img
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:05:05
Old 06-20-2018, 17:10   #50310 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Arrow Samsung b310 dead set
Set mode to : SPD6530_SAMSUNG
Start  at : [6/20/2018 / 8:52:11 PM]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
Phone found! [ 33 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2    Boot Ok
CPU ID : 6530 , FDLStat : 00C0
[0] Flash DIE : 00C8 0060 0017 0000
[0] Flash VEN : GigaDevice , GD25LQ64
[0] Flash CAP : 00800000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:25
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.64059 seconds with 11 queries
