06-10-2017, 06:58 | #42796 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | QMobile i5i Write Factory Firmware Done :) Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A14E8E9155 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A14E8E9155 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D66CC398FCDB81B1917C45B45 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : QMobile i5i ProdModel : QMobile i5i Device : QMobile i5i AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A14E8E9155 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A14E8E9155 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D66CC398FCDB81B1917C45B45 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB [eMMC] : CID : 90014A4834473164040500A14E8E9155 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! All Done! Done! Elapsed: 00:00:50 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6582 , Project : s4300ap , Storage : EMMC Files found : 13 , Set to Flash : 12 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A14E8E9155 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A14E8E9155 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D66CC398FCDB81B1917C45B45 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s4300ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3824 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4300ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:02:51 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:50 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:01 Reconnect Power/Cable! |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
06-10-2017, 07:17 | #42797 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | videocon z40 lite plus flash done Code: Set mode to : SP SC77xx [Model Select] Loading : Videocon_Z40Lite+_V3.0_07052015.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : Videocon_Z40Lite+_V3.0_07052015 FastCheck : 0x00261FD75D Loading files ... File : fdl1.bin File : fdl2.bin File : h610_sp019_cc1bom_nvitem_W14.39_20150331.bin File : nvitem_wcn_MOCORTM_SC7715_14A_W14.39.bin File : u-boot-spl-16k.bin File : SC7702_sc7715_modem_MOCORTM_SC7715_14A_W14.39.bin File : DSP_DM_G2_SC7715_MOCORTM_SC7715_14A_W14.39.bin File : SC8800G_sc7715_wcn_modem_zerocopy_MOCORTM_SC7715_14A_W14.39.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo_normal.bmp File : logo_fastboot.bmp File : prodnv.img File : cache.img File : u-boot.bin File : SC77xx.xml Load Ok! Operation : Check/Read Info [ v1.26 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 63 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : scx15_sp7715eacuccspecAplus_UUI Model Brand : Videocon Model Device: scx15_sp7715ea AndrVersion : 4.4.2 BaseBand CPU: SCX15_SP7715EA CompileDate : 5/7/2015 10:59:45 AM Project Ver : Videocon_Z40Lite+_V3.0_07052015 Model Ext : Videocon_Z40Lite+ ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:33 Reconnect Power/Cable! Operation : Read NV [ v1.26 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 63 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read GSM NV Read WCN NV Read Ok , 0xC01F Saved to : W:\spd nv\videocon z40 lite plua and 4.4.2.spdnv Elapsed: 00:01:03 Reconnect Power/Cable! Operation : Flash [ v1.26 ] ======= Flash Files set for flashing : [ MCU ] : Videocon_Z40Lite+_V3.0_07052015.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : Videocon_Z40Lite+_V3.0_07052015 File : fdl1.bin File : fdl2.bin File : h610_sp019_cc1bom_nvitem_W14.39_20150331.bin File : nvitem_wcn_MOCORTM_SC7715_14A_W14.39.bin File : u-boot-spl-16k.bin File : SC7702_sc7715_modem_MOCORTM_SC7715_14A_W14.39.bin File : DSP_DM_G2_SC7715_MOCORTM_SC7715_14A_W14.39.bin File : SC8800G_sc7715_wcn_modem_zerocopy_MOCORTM_SC7715_14A_W14.39.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo_normal.bmp File : logo_fastboot.bmp File : prodnv.img File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 63 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x18 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7715_modem_MOCORTM_SC7715_14A_W14.39.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2_SC7715_MOCORTM_SC7715_14A_W14.39.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_sc7715_wcn_modem_zerocopy_MOCORTM_SC7715_14A_W14.39.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo_normal.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : logo_fastboot.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASESD Current Part : internalsd [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:03:05 Reconnect Power/Cable! |
The Following User Says Thank You to rehmani For This Useful Post: |
06-10-2017, 07:23 | #42798 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X30 MT6572 Dead Set Recover Done By Flashing With Infinity CM2 Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110140E700D0221D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110140E700D0221D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F39587F0B9F0617B5D595B00E5B1 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : Unknown (not supported or without battery) BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4050ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:02 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:46 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:12 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post: |
06-10-2017, 08:15 | #42799 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile T50 SPD7715 NAND Pattren Reset Done With Great Infinity CM2 Set mode to : SP [SC7715] NAND [Generic] Operation : Format File System / Reset Settings [ v1.26 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
06-10-2017, 08:31 | #42800 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | Code: Operation : Read PatternLock [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 01E635F5 ID_BLOCK_I : 008110E1 ID_BLOCK_L : F272689641ADDAD5B2E76976B1880840 ID_BLOCK_L : BDD07ED1C24DFD768B6A2FE4EE011F3C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 85479 Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
The Following User Says Thank You to sky73 For This Useful Post: |
06-10-2017, 08:55 | #42801 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Zte r221 COM3 [VCP0] selected module v4.48 Device: ZTE-R221_8mb Checking data, wait... Operation: SP-unlock unlock method: read codes interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! BaseBand chip version: MT6223, E08 ECO version: DSP firmware version: 2000.00.00 DSP patch version: 1.0 S/W version: E-WGD-R9DM-P109A17V1.0.0B09 H/W board version: ZTENJ23D_09A_HW Melody version Melody V0.0 Version: E-WGD-R9DM-P109A17V1.0.0B09 ==================== New firmware found (v4.48, database date: 27.03.2014): E-WGD-R9DM-P109A17V1.0.0B09 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read imei #1: 868533009219115F7810 imei #2: 868533009219115F8710 192 byte(s) read 38 byte(s) read Phone lock: On Phone code: 24680 180 byte(s) read 972 byte(s) read lock[1] code: + 133137091335 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Shutdown... done Finished, time used: 1 min 23 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to ibrajinja For This Useful Post: |
06-10-2017, 10:25 | #42802 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Samsung Clone G530H NAND Format Done Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xE6C52A7D9F78628A8C3BBDB49F3B51E2 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
06-10-2017, 10:39 | #42803 (permalink) |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Brand : alps ProdName : Aqua Star Power ProdModel : Aqua Star Power Device : Star_Power MTKxCPU : MT6582 MTKxPRJ : 2014-9-12 16:01:00 write flash done Scatter Load Ok , BaseBand : MT6582 , Project : konka82_i256_kk , Storage : EMMC Files found : 12 , Set to Flash : 11 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : alps Device Model : Star_Power Device CPU : MT6582 Device IntName : Aqua Star Power Device Version : 4.4.2 Device Compile : 8/27/2014 10:34:28 AM Device Project : 2014-08-27 18:34:28 Device ExtInfo : Aqua Star Power Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501005137585341420104FAC43D7121 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX7 [eMMC] : FLASH_CID : 1501005137585341420104FAC43D7121 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB662A14ED80CE46636CBB5406398385A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : konka82_i256_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3620 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000001CEA80000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_konka82_i256_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:10 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:46 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:15 Reconnect Power/Cable! |
The Following User Says Thank You to diesel6 For This Useful Post: |
06-10-2017, 10:51 | #42804 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile Ultra2 SPD6531 In comming Call Not Show Done Only Formate With Infinity CM2 Card found: S/N : A19EC787 , v0136 Chinese Miracle II [SPD module] v 1.26 Set mode to : SPD6531 Operation : Format File System / Reset Settings [ v1.26 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
06-10-2017, 11:43 | #42805 (permalink) |
The Following 2 Users Say Thank You to rehmani For This Useful Post: |
06-10-2017, 12:06 | #42806 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | iball o obuddy format done Code: Set mode to : SP [SC773x] eMMC [Generic] Operation : Check/Read Info [ v1.26 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : v211_ytk_231 Model Brand : iBall Model Device: v211_ytk_231 AndrVersion : 4.4.2 BaseBand CPU: V211_YTK_231 CompileDate : 7/9/2015 10:07:22 AM Project Ver : KOT49H 14B_test-keys Model Ext : Andi 4.5 O'Buddy ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:24 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.26 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001193FB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
06-10-2017, 12:28 | #42807 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | videocon z45 amaze format done Code: Set mode to : SP [SC773x] eMMC [Generic] Operation : Check/Read Info [ v1.26 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : scx35_sp7731gea_lm_fs031_project Model Brand : Z45 Amaze Model Device: scx35_sp7731gea_lm_fs031 AndrVersion : 5.1 BaseBand CPU: SP7731GEA_LM_FS031 CompileDate : 6/6/2016 1:36:46 AM Project Ver : Videocon_Z45Amaze_S453_91_V1.0_LL_20160606 Model Ext : Z45 Amaze ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:25 Operation : Format File System / Reset Settings [ v1.26 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : Size : 0x000000015CAF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:27 Reconnect Power/Cable! Reconnect Power/Cable! |
06-10-2017, 12:38 | #42808 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | LG G3 LS990 Flashing ToT FIle Done Code: Infinity-Box LG Service Tool [ LGS ] v1.03 Loading firmware ... FType : TOT file BB_Gen : QLM Model : LGLS990 Version : LS990ZV8 SWInfo : user File [0] : PrimaryGPT File [1] : modem File [2] : sbl1 File [3] : dbi File [4] : aboot File [5] : rpm File [6] : tz File [7] : boot File [8] : persist File [9] : recovery File [10] : rct File [11] : misc File [12] : laf File [13] : factory File [14] : system File [15] : system File [16] : system File [17] : system File [18] : system File [19] : system File [20] : system File [21] : system File [22] : system File [23] : system File [24] : system File [25] : system File [26] : system File [27] : system File [28] : system File [29] : system File [30] : system File [31] : system File [32] : system File [33] : system File [34] : system File [35] : system File [36] : system File [37] : system File [38] : system File [39] : system File [40] : system File [41] : system File [42] : cache File [43] : cache File [44] : cache File [45] : cache File [46] : cache File [47] : cache File [48] : cache File [49] : cache File [50] : userdata File [51] : userdata File [52] : userdata File [53] : userdata File [54] : userdata File [55] : userdata File [56] : userdata File [57] : userdata File [58] : userdata File [59] : userdata File [60] : userdata File [61] : userdata File [62] : userdata File [63] : userdata File [64] : userdata File [65] : userdata File [66] : userdata File [67] : userdata File [68] : userdata File [69] : userdata File [70] : userdata File [71] : userdata File [72] : userdata File [73] : userdata File [74] : userdata File [75] : userdata File [76] : userdata File [77] : userdata File [78] : userdata File [79] : userdata File [80] : userdata File [81] : userdata File [82] : userdata File [83] : userdata File [84] : userdata File [85] : userdata File [86] : userdata File [87] : userdata File [88] : userdata File [89] : userdata File [90] : userdata File [91] : userdata File [92] : userdata File [93] : userdata File [94] : userdata File [95] : userdata File [96] : userdata File [97] : userdata File [98] : userdata File [99] : userdata File [100] : userdata File [101] : userdata File [102] : userdata File [103] : userdata File [104] : userdata File [105] : userdata File [106] : userdata File [107] : userdata File [108] : userdata File [109] : userdata File [110] : userdata File [111] : userdata File [112] : userdata File [113] : userdata File [114] : userdata File [115] : userdata File [116] : userdata File [117] : userdata File [118] : userdata File [119] : userdata File [120] : userdata File [121] : userdata File [122] : userdata File [123] : userdata File [124] : userdata File [125] : userdata File [126] : userdata File [127] : userdata File [128] : userdata File [129] : userdata File [130] : userdata File [131] : userdata File [132] : userdata File [133] : userdata File [134] : userdata File [135] : userdata File [136] : userdata File [137] : userdata File [138] : userdata File [139] : userdata File [140] : userdata File [141] : userdata File [142] : userdata File [143] : userdata File [144] : userdata File [145] : userdata File [146] : userdata File [147] : userdata File [148] : BackupGPT Load Ok! Code: Operation : Flash [ v1.03 ] Forced Flash : Disabled Factory Reset : Enabled 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x00 Boot done! [INFO] : Low Battery level ignored by user request! Loading firmware Load ok! Checking compatibility Checking passed! Prepare device Prepare Passed! Secure prepare skipped! Start flashing device Flash : PrimaryGPT Flash : modem Flash : sbl1 Flash : dbi Flash : aboot Flash : rpm Flash : tz Flash : boot Flash : persist Flash : recovery Flash : rct Flash : misc Flash : laf Flash : factory Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : cache Flash : cache Flash : cache Flash : cache Flash : cache Flash : cache Flash : cache Flash : cache Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : BackupGPT Processing Post-Flashing tune Flash done! Reconnect Power/Cable! Done! Elapsed: 00:02:40 |
06-10-2017, 14:02 | #42809 (permalink) |
Freak Poster Join Date: Aug 2016 Location: out of world
Member: 2609423 Status: Offline Sonork: 1660954:2007 Thanks Meter: 360 | lg Model LG-H630D factory mode 2 error solved Infinity-Box LG Service Tool [ LGS ] v1.03 Loading firmware ... FType : KDZ file BB_Gen : QLM Model : LG-H630D Version : H630D10f SWInfo : user File [0] : PrimaryGPT_0.bin File [1] : sbl1_1024.bin File [2] : tz_2048.bin File [3] : hyp_3072.bin File [4] : rpm_4096.bin File [5] : aboot_5120.bin File [6] : sbl1bak_12288.bin File [7] : tzbak_13312.bin File [8] : hypbak_14336.bin File [9] : rpmbak_15360.bin File [10] : abootbak_16384.bin File [11] : persist_53248.bin File [12] : laf_93184.bin File [13] : boot_142336.bin File [14] : recovery_191488.bin File [15] : rct_262144.bin File [16] : cust_279552.bin File [17] : factory_484352.bin File [18] : modem_697344.bin File [19] : system_828416.bin File [20] : system_1091848.bin File [21] : system_1095800.bin File [22] : system_1356656.bin File [23] : system_1616136.bin File [24] : system_1620088.bin File [25] : system_1880944.bin File [26] : system_2140424.bin File [27] : system_2144376.bin File [28] : system_2405232.bin File [29] : system_2664712.bin File [30] : system_2668664.bin File [31] : system_2929520.bin File [32] : system_3189000.bin File [33] : system_3192952.bin File [34] : system_3453808.bin File [35] : system_3715952.bin File [36] : system_3978096.bin File [37] : system_4240240.bin File [38] : system_4502384.bin File [39] : system_4764528.bin File [40] : system_5026672.bin File [41] : system_5284864.bin File [42] : system_5547008.bin File [43] : system_5809152.bin File [44] : system_5812416.bin File [45] : BackupGPT_15268864.bin Load Ok! Operation : Flash [ v1.03 ] Forced Flash : Disabled Factory Reset : Enabled 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Device not found! Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.03 ] Forced Flash : Disabled Factory Reset : Enabled 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x00 Boot done! [INFO] : Low Battery level ignored by user request! Loading firmware Load ok! Checking compatibility Checking passed! Prepare device Prepare Passed! Secure prepare skipped! Start flashing device Flash : PrimaryGPT_0.bin Flash : sbl1_1024.bin Flash : tz_2048.bin Flash : hyp_3072.bin Flash : rpm_4096.bin Flash : aboot_5120.bin Flash : sbl1bak_12288.bin Flash : tzbak_13312.bin Flash : hypbak_14336.bin Flash : rpmbak_15360.bin Flash : abootbak_16384.bin Flash : persist_53248.bin Flash : laf_93184.bin Flash : boot_142336.bin Flash : recovery_191488.bin Flash : rct_262144.bin Flash : cust_279552.bin Flash : factory_484352.bin Flash : modem_697344.bin Flash : system_828416.bin Flash : system_1091848.bin Flash : system_1095800.bin Flash : system_1356656.bin Flash : system_1616136.bin Flash : system_1620088.bin Flash : system_1880944.bin Flash : system_2140424.bin Flash : system_2144376.bin Flash : system_2405232.bin Flash : system_2664712.bin Flash : system_2668664.bin Flash : system_2929520.bin Flash : system_3189000.bin Flash : system_3192952.bin Flash : system_3453808.bin Flash : system_3715952.bin Flash : system_3978096.bin Flash : system_4240240.bin Flash : system_4502384.bin Flash : system_4764528.bin Flash : system_5026672.bin Flash : system_5284864.bin Flash : system_5547008.bin Flash : system_5809152.bin Flash : system_5812416.bin Flash : BackupGPT_15268864.bin Processing Post-Flashing tune Flash done! Reconnect Power/Cable! Done! Elapsed: 00:03:22 |
The Following 2 Users Say Thank You to applebricks For This Useful Post: |
06-10-2017, 18:25 | #42810 (permalink) |
Freak Poster Join Date: Jun 2013 Location: india tirupur tamilnadu
Member: 1962832 Status: Offline Thanks Meter: 199 | Lava a77 frp remove done world first Best Regards a1mobiletirupur * Always Follow Forum RulesHere * Use Only Thanks Button * Use Search Button Before make a Thread |
The Following 2 Users Say Thank You to a1mobiletirupur For This Useful Post: |
