01-28-2020, 10:31 | #62236 (permalink) |
No Life Poster Join Date: Mar 2010 Location: south africa Age: 41
Member: 1269056 Status: Offline Thanks Meter: 1,114 | Kicka 5 plus network lock HERE IS THE LOGS Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.07 Load IDBase v124106 Ok! Operation : SP Unlock [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : VODAFONE : KICKA 4 PLUS | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A0190613447385809A532F736D830 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847346132A5095830D836F7 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x1D2000000 [ 7,28 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 92AC8C1BF01587E8BE8A3E41CD84AFC0 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ID0 : Lock : Locked! | MNC : 512 | CNT : 252 | CODE : 12345678 ID1 : Lock : Not Locked! ID2 : Lock : Not Locked! ID3 : Lock : Not Locked! ID4 : Lock : Not Locked! ID5 : Lock : Not Locked! ID6 : Lock : Not Locked! Direct unlock done! Done! Elapsed: 00:00:23 |
01-28-2020, 11:11 | #62237 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Maxx turbo t102 hang on call done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0E9 117DD6DA7_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
01-28-2020, 11:50 | #62238 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile Infinity Prime F.R.p Reset Done Operation : Reset Settings/Format FS [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM390) MODE : BOOTROM PORT : 390 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E1 BROM : SecMode : SBC+ARB BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : 95C68DC2802971D9378589D011C0C57BBB6C436711DB8B4882 BEB7C17FCED9B9 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0004 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 90014A484147346132A50FB193FC425 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 21786E9596D4B420649D73C95EE21EF8 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
01-28-2020, 12:20 | #62239 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Asus x008 pegasus dead recover done wow great infinity Code: Operation : Write Flash [ v2.07 ] Repartition : Enabled Flash Verify : Enabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Enabled Safe UserData : Disabled Flash Format : Enabled Files :10 [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : logo.bin [FL] : Set : secro.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x8EEE33A0 [ 2.23 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : ASUS : X008 [ ZC5xx ] | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100525831424D4207F42FF4C230BF DAInf: 4 : 2 : 147 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100525831424D4207F42FF4C283BF EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX1BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 15AB41ABDB3ECDDF8D3E6B6D439691BB STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! [FL] : Pre-Flash backup Backup sensetive data [ 10 ] Backup path : Backup\MT6735__15AB41ABDB3ECDDF8D3E6B6D439691BB\ [3] Read : NVRAM [22] Read : NVDATA [2] Read : PROINFO [6] Read : LK [4] Read : PROTECT1 [5] Read : PROTECT2 [0] Read : PRELOADER Backup done! [FL] : Pre-Flash backup passed! SEC_DL : False (CUST) SEC_DL : SECURE USB DL DISABLED SEC_ID : 0x35464646304237304435444533464335 [FL] : Pre-Erase [FL] : Whole Flash Erase enabled! Erase : 0x0000000000000000 : 0x0000000747C00000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : LK Write : BOOT Write : RECOVERY Write : LOGO Write : SECRO Write : TEE1 Write : TEE2 Write : SYSTEM Write : CACHE Write : USERDATA CHK : 0x000483C0 : 0x66FE : LK CHK : 0x008D2530 : 0xDA93 : BOOT CHK : 0x009A9D30 : 0x0EB7 : RECOVERY CHK : 0x00137270 : 0x8590 : LOGO CHK : 0x00021000 : 0x136D : SECRO CHK : 0x0000ECB0 : 0x0A18 : TEE1 CHK : 0x0000ECB0 : 0x0A18 : TEE2 CHK : 0xAF000000 : 0xBF2D : SYSTEM CHK : 0x19000000 : 0x19A5 : CACHE CHK : 0x80000000 : 0xE573 : USERDATA [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:06:01 Reconnect Power/Cable! |
The Following User Says Thank You to kothamamun For This Useful Post: |
01-28-2020, 14:16 | #62240 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A37f QLM Pattren Reset Done With Lose Data With King Infinity CM2 Card found : A19EC787 , v0138 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 21D93333 ID_BLOCK_L : B0B02AD483EF1417F0A5AFB07FCA4A82 ID_BLOCK_L : B0C34DDCD140EA7B9E5932EBF9342229 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 3528 Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
01-28-2020, 15:33 | #62241 (permalink) | |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | First In The World Q Mobile LT690 Read Flash+ Write Flash Hang On Logo DOne Read Flash Quote:
Code: Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2019 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : MRA58K Display ID : J106_A2_S003_AD_LT690_V1.0_20190904 Ver. CodeName : REL Ver. Release : 8.1 Sec. Patch : 2016-07-01 Build Time : 1567581750 Product Brand : android_1 Product Name : LT690 Product Device : LT690 Product Board : sp7731gea Product Manfct : android_1 Board Platform : sc8830 Product Info : LT690 Product Model : LT690 Operation : Flash Firmware [ v2.04 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! FSIMG : prodnv.img CODE : wmodem.bin CODE : wdsp.bin ERASE : WFLASH CODE : modem_wcn.img ERASE : WCNFLASH CODE : boot_logo.bmp CODE : fastboot_logo.bmp CODE : logo2.bin CODE : logo3.bin CODE : logo4.bin CODE : logo5.bin CODE : boot.img FSIMG : system.img FSIMG : persist.img FSIMG : sysinfo.bin FSIMG : cache.img CODE : recovery.img ERASE : MISC FSIMG : userdata.img UBOOT : u-boot.bin UBOOT : u-boot-spl.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:05:46 | |
01-29-2020, 05:47 | #62242 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | imax mX24s password remove and read flash done Code: Operation : Format FileSystem [ v1.05 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1869E7C8B3CD_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:41 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.05 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Read Flash Ok, Size : 4.00 MiB GK975_DPX_C28_2SIM_SC6531EFM_3232_PCB10_QVGA_mENG_BEN_IMAX_nVIB_20180715_1415 Project Version: SC6531EFM_BAR MMI Version: SC6531EFM_BAR BASE_SVN SC6531EFM_BAR 07-15-2018 14:34:59 LOG Version: V1.0.1 Saved to : E:\GK975_DPX_C28_2SIM_SC6531EFM_3232_PCB10_QVGA_mENG_BEN_IMAX_nVIB_20180715_1415.bin Done! Elapsed: 00:01:08 Reconnect Power/Cable! |
01-29-2020, 06:57 | #62243 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Vgotel ismart pattern & frp remove done with cm2 VGOTEL ISMART PATTERN & FRP REMOVE DONE WITH CM2 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC983x eMMC Loader v5.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000ED9F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:51 Reconnect Power/Cable! |
01-29-2020, 07:00 | #62244 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Vgotel ismart pattern & frp remove done with cm2 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC983x eMMC Loader v5.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000ED9F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:51 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Nadeem Waris For This Useful Post: |
01-29-2020, 12:28 | #62246 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Tecno B1f Remove pattern lock done With cm2 Operation : Reset Settings/Format FS [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : LB6 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D323645629E034257663DD3 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464536324D42039E62D33D6657 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : DD69716227EDC119BBE45CE3CE13B109 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
01-29-2020, 13:54 | #62247 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Lenovo a238t format done in diag mode Operation : Identify [ v2.03 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! BuildInfo : LePhone-user 2.3.5 MDroid2.3.5 A238t_S161_140506.20140528 release-keys ModemInfo : Platform Version: MOCORTM_13C_W14.04_P8_Debug Project Version: sc8830_modem BASE Version: TM_BASE_13B_W14.04_P8 HW Version: sc8830_modem CMP_Time : 05-12-2014 22:57:56 SecInfo : IMEI[1] : 864441020819968 IMEI[2] : 864441020819968 WIFIMAC : CC07E48AC520 BT_MAC : CC07E489C520 Done! Elapsed: 00:00:56 Operation : Format FS / Reset Settings [ v2.03 ] Mode : Forced [ Format FS / Fix ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Wipe Ok : UserData Reconnect Power/Cable! Done! Elapsed: 00:00:51 |
01-29-2020, 13:57 | #62248 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Itel p33plus read privacy lock & firmware done Card found : A6936825 , v0138 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.03 Load IDBase v10107 Ok! Operation : Identify [ v2.03 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : W6001-F3103-8.1-OP-V043-20190716 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-07-01 Build Time : 1563257743 Product Model : itel W6001 Product Brand : Itel Product Name : F3103 Product Device : itel-W6001 Product Manfct : itel Product Info : F3103 Product Board : itel-W6001 Board Platform : sp7731e Display ID : W6001-F3103-8.1-OP-V043-20190716 SecInfo : IMEI[1] : XXXXXXXXXXXXXXX IMEI[2] : XXXXXXXXXXXXXXX IMEI[3] : XXXXXXXXXXXXXXX WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF Platform Version: MOCORTM_17C_W18.31.2_P18_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.31.2_P18 HW Version: sc7731e_modem CMP_Time : 05-16-2019 14:49:47 MODEM TAG : MOCORTM_17C_W18.31.2_P18_Debug_FM_BASE_17C_W18.31. 2_P18_sc7731e_modem_pike2_pub UserData : STATE : PLAIN Done! Elapsed: 00:01:25 Operation : Read PrivacyLock [ v2.03 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PASSWORD : 12345678 CONTACTS : 12345678 Reconnect Power/Cable! Done! Elapsed: 00:00:26 Operation : Read FW [ v2.03 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : W6001-F3103-8.1-OP-V043-20190716 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-07-01 Build Time : 1563257743 Product Model : itel W6001 Product Brand : Itel Product Name : F3103 Product Device : itel-W6001 Product Manfct : itel Product Info : F3103 Product Board : itel-W6001 Board Platform : sp7731e Display ID : W6001-F3103-8.1-OP-V043-20190716 VlnrLevel : 0x00 SP7731E__itel__itel_W6001__8.1.0__W6001-F3103-8.1-OP-V043-20190716__OPM2.171019.012__F3103 Read : prodnv.img ExtSparse : Compression ratio : 80% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_w.bin Make : persist.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : modem_wcn.img Read : modem_w.bin Read : deltanv_w.bin Read : gdsp_w.bin Read : pm_sys.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 83% Make : cache.img Read : vendor.img ExtSparse : Compression ratio : 68% Read : cover.bin Read : vbmeta.img Read : chargelogo.bin Read : chargeremind.bin Read : lkcharge.bin Read : sysdumpdb.bin Make : userdata.img Read : u-boot-spl.bin Firmware size : 0x716E3FA0 ( 1.77 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:44:29 |
01-29-2020, 14:00 | #62249 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Itel a16 format & frp reset done Operation : Identify [ v2.03 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : A16-SA331-8.1-OP-V031-20190530 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-05-05 Build Time : 1559190721 Product Model : itel A16 Product Brand : Itel Product Name : SA331 Product Device : itel-A16 Product Manfct : ITEL MOBILE LIMITED Product Info : itel A16 Product Board : sp7731e_1h20 Board Platform : sp7731e Update DataBase ... SecInfo : IMEI[1] : XXXXXXXXXXXXXXX IMEI[2] : XXXXXXXXXXXXXXX IMEI[3] : XXXXXXXXXXXXXXX WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF Platform Version: MOCORTM_17C_W18.31.2_P18_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.31.2_P18 HW Version: sc7731e_modem CMP_Time : 05-16-2019 14:49:47 MODEM TAG : MOCORTM_17C_W18.31.2_P18_Debug_FM_BASE_17C_W18.31. 2_P18_sc7731e_modem_pike2_pub UserData : STATE : PLAIN Done! Elapsed: 00:01:53 Operation : Format FS / Reset Settings [ v2.03 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:32 |
01-29-2020, 14:26 | #62250 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile l7 hang on logo done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 653x NOR v1.3(c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:24 Reconnect Power/Cable! Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 653x NOR v1.3(c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_068 6F53461B7_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
