Old 10-27-2010, 17:03   #5911 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
COM5 [VCP1] selected
module v3.25
Action: reset settings ("format ffs")
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:AD03:0002
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: T33+_TS70_TRIPLE_V010
Version: T33+_V1.0_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: ***********
connection Ok
building list...
done
items to clear: 163
warning: wrong packet cs
items cleared: 163 of 163
items remains: 0
Finished, time used: 33 sec
Remove/Install battery now !
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 10-27-2010, 17:04   #5912 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Action: "repair imei"
Phone should be Switched ON !
Connecting, wait...
imei-1: "
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 355705007665503
verification Ok
Finished, time used: 3 sec
Old 10-27-2010, 17:04   #5913 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
module v3.25
Action: read unlock codes
unlock method: read codes
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #1...
1 5 8 9 10 12 13 14 done
178 byte(s) read
166 byte(s) read
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 1122
Finished, time used: 20 sec
Old 10-27-2010, 17:05   #5914 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
COM2 [VCP2] selected
module v1.78
Device: Zong-A136
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20101018-162026.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20101018-162026.B1E.bin
reading eeprom-complete...
file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20101018-162028.B1E.bin
reading additional data...
file saved: i:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20101018-162031.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 30 sec
The Following User Says Thank You to c_ahmad79 For This Useful Post:
Old 10-27-2010, 17:07   #5915 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
COM10 ready
Action: read/check information
Connecting, wait...
Hardware version: AT+ESLP=0
Software version: MT6223, E05"
Software date: MAGCOMM23C
Barcode: F96Z08AGv01.01b03
imei-1: 2000.00.00"
imei-2: MT0123456789012
imei-3: "
Old 10-27-2010, 17:08   #5916 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Connecting, wait...
imei-2: 135790246811220
imei write channel: imei #2 for dual sim/mono CPU
new imei-2: 356404001182983
verification Ok
Old 10-27-2010, 17:09   #5917 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Connecting, wait...
imei-1: 363297002835653
new imei-1: 350077803417306
verification Ok
Old 10-27-2010, 17:09   #5918 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Connecting, wait...
imei-1: 500039174745698
new imei-1: 363297002835653
verification Ok
Finished, time used: 5 sec
Old 10-27-2010, 17:10   #5919 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
ZTE A35 unlock
COM4 [VCP5] selected
module v1.73
Device: ZTE-A35
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
sw version: RID-P108A5V1.0.0B01 WARID-P108A5B01-En-PK01 g3dBV2.0 7 ,3
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-static_20100908-204010.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-security_20100908-204011.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20100908-204013.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A35_lock-area_20100908-204019.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 40 sec
The Following User Says Thank You to asad_nomy7 For This Useful Post:
Old 10-27-2010, 17:10   #5920 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
COM10 ready
Connecting, wait...
imei-1: 135790246811220
new imei-1: 500039174745698
verification Ok
Finished, time used: 7 sec
Old 10-27-2010, 17:14   #5921 (permalink)
shuric's Avatar
Member: 444532
Sonork: 100.1576960
Thanks Meter: 214
Nokia 1661 sp-unlock done.
Read phone info...
Product -
Mcu SW - V 03.70 14-04-09 RH-122 (c) Nokia
Ppm SW - V 03.70 14-04-09 RH-122 (c) Nokia AD
Prd.Code - 0584523
Bpr.Code - 0568809
Prod.Sn - HMD739703
Hw Vers - 1002
Uem - 1328
Upp - 8851
Rfic Ver - 0700
Dsp Vers - ICPR81_09w10_UPP
Lcd Type - WIN:BOHAIv91
NT39121
Cam Prim -
Imei - 356916033132843
Sl Conf - 262-07-00000000000
Sl Prof - 800000000003000-2
Sl Aux - 000B0000
Hw Sig - 6928BE6C78A31E6A
Provider - O2 Deutschland (DCT3 Contract);Germany
Lock info:
Blok 1
L1 - Close; L2 - Close; L3 - Close; L4 - Open; L5 - Open;
Blok 2
L1 - Open; L2 - Open; L3 - Open; L4 - Open; L5 - Open;
Check phone mode...
Phone already in Test mode, skip change...
Read Lock Info
Locked to O2 Deutschland (DCT3 Contract);Germany
Connect to server...
Unlocking...
All done !
Phone disconnected
Port COM4 close
The Following User Says Thank You to shuric For This Useful Post:
Old 10-27-2010, 17:15   #5922 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
Loading file v.02...
C261_6.6.61_Main.34M.bin loaded
C261_6.6.61_LPNA_En_Es_Pt.34P.bin loaded
V176_6.6.61_Flex_90_63_NB09_10Net.34F.bin loaded
C261_0.1.66_Main_E58S.34M.bin loaded
C261_0[1].1.66_LP11_Arabic_Farsi_Urdu_Fr.34P.bin loaded
COM4 [VCP1] selected
"smart write" active
Action: flash
Write: Firmware
Write: Language Pack
Skip: Flex
Skip: Eeprom
Device: C261
Connect...
Press and HOLD Power button...
rom version: 0411
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 0.1.66
HW version: MOTOROLA_E58S
LP ver: LP11_0166
Flex ver: FLEX_90_64_3906
cpu id: 08B6
imei eeprom: 3594160039801352
required SW version: 0.1.66
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35941600398013_20100913-160502.34E.bin
Check Flash-2 Done
Write...
Writing: Firmware
Writing: Language Pack
Write Done
Finished, time used: 467 sec
Old 10-27-2010, 17:19   #5923 (permalink)
shuric's Avatar
Member: 444532
Sonork: 100.1576960
Thanks Meter: 214
Vodafone 225 phone lock reset done.
COM3 [VCP0] selected
module v1.78
Device: Vodafone-225
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
sw version: -DE-P108A2V1.0.0B03 12 27 46 VDF-P108A2B07-De-DE03 g3dBV2.0 04.1
file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-static_20101007-173548.B1E.bin
loading data...
data loaded
file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-security_20101007-173549.B1E.bin
file saved: D:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20101007-173550.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 19 sec
Old 10-27-2010, 17:19   #5924 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Connecting, wait...
imei-1: 449281087134743
new imei-1: 363297002407669
verification Ok
Old 10-27-2010, 17:20   #5925 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
chinese phone code
COM9 [VCP0] selected
module v3.25
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:8B03:000A
status: FF
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: S7700_TS70_ROHM_1IMEI_V013
Version: S7700_V2.0_HW
5 11 done
67 byte(s) read
imei: 35260403057712
connection Ok
178 byte(s) read
166 byte(s) read
Phone lock: On
Network lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 2842
Finished, time used: 11 sec
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.46061 seconds with 10 queries
