12-25-2010, 10:07 | #7486 (permalink) |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | card found: S/n.st. team registered to: marvz_TG Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... -> Flash Files are NOT selected! You can Select: S40 : Any, but MCU need present in filelist S60 : Any, but CORE/MCU need present in filelist S60 APE : MCU+PPM, MCU+PPM+CNT Phone found! Series 40 Device detected! read info... - Ok BackUp UserData : [PhoneBook] Generation mode : [S40] Reading Phonebook... 71 phonebook records are found! VCF Records saved to : BEST\Phones_Data\IMEI\ Saved to: C:\INFINITY BEST\RM-635 Nokia 2690_358260030035875.S4pb Done... Backup Certificates now... Backup CRT308 data... CRT308 Backup Created... Check communication with phone.... ADL not support backup mode, rpl reading impossible SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\INFINITY BEST\Backup\Cert\358260030035875_SIM.rpl Elapsed: 00:00:00 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 2690 Software ver : V 09.65 04-12-09 RM-635 (c) Nokia IMEI : 358260030035875 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_09w26 APE Test: PPM : V 09.65 04-12-09 RM-635 (c) Nokia T CNT : Z[\^`bcdefghijkl Product SN : ITD501442 Product code : 0592095 Base Prd.code: 0589255 Module code : 0204458 Long Prod.SN : 0 Hardware info======= HWID : 3000 Retu : 16 Tahvo : 22 Batery: 5104 mV Camera: CMT BT: 2.31-SP2.26 APE BT: APE HW: LCDVer: SUEZ RF ic : Lock info =========== IMEI : 358260030035875 IMEI spNet : 3A 85 62 00 03 30 85 07 IMEI svNet : 33 85 62 00 03 30 85 57 F2 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created... User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Selected FlashSettings : Manual Check FlashFiles, Please, wait... -> Flash Files are NOT selected! You can Select: S40 : Any, but MCU need present in filelist S60 : Any, but CORE/MCU need present in filelist S60 APE : MCU+PPM, MCU+PPM+CNT Selected FlashSettings : Manual Check FlashFiles, Please, wait... -> Flash Files are NOT selected! You can Select: S40 : Any, but MCU need present in filelist S60 : Any, but CORE/MCU need present in filelist S60 APE : MCU+PPM, MCU+PPM+CNT Phone disconected! Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... -> Flash Files are NOT selected! You can Select: S40 : Any, but MCU need present in filelist S60 : Any, but CORE/MCU need present in filelist S60 APE : MCU+PPM, MCU+PPM+CNT Selected FlashSettings : Manual Check FlashFiles, Please, wait... -> Flash Files are NOT selected! You can Select: S40 : Any, but MCU need present in filelist S60 : Any, but CORE/MCU need present in filelist S60 APE : MCU+PPM, MCU+PPM+CNT Selected FlashSettings : Manual Check FlashFiles, Please, wait... -> Flash Files are NOT selected! You can Select: S40 : Any, but MCU need present in filelist S60 : Any, but CORE/MCU need present in filelist S60 APE : MCU+PPM, MCU+PPM+CNT Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm635__09.65.mcusw PPM : rm635__09.65.ppm_aa CNT : rm635__09.65.image_aa_blue Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! [BB5 FLASH]: GetFirstBlock Failed, Aborting -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm635__09.65.mcusw PPM : rm635__09.65.ppm_aa CNT : rm635__09.65.image_aa_blue Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! [BB5 FLASH]: GetFirstBlock Failed, Aborting -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm635__09.65.mcusw PPM : rm635__09.65.ppm_aa CNT : rm635__09.65.image_aa_blue Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! [BB5 FLASH]: GetFirstBlock Failed, Aborting -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm635__09.65.mcusw PPM : rm635__09.65.ppm_aa CNT : rm635__09.65.image_aa_blue Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! [BB5 FLASH]: GetFirstBlock Failed, Aborting -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm635__09.65.mcusw PPM : rm635__09.65.ppm_aa CNT : rm635__09.65.image_aa_blue Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! [BB5 FLASH]: GetFirstBlock Failed, Aborting -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm635__09.65.mcusw PPM : rm635__09.65.ppm_aa CNT : rm635__09.65.image_aa_blue Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 0DA00010789546504B57A18CC755D1A286FE84BB CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm635__09.65.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:03 Write : Processing rm635__09.65.mcusw Total 1161 [1161/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:53 MCU Write done ===Flashing [PPM]=== Erase : Processing rm635__09.65.ppm_aa Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:50 Write : Processing rm635__09.65.ppm_aa Total 202 [202/0/0] blocks to write, writing... TIME : Write time : 00:00:09 PPM Write done ===Flashing [CNT]=== Checking content info... Check Image : Content size is 128k, use direct write mode Erase : Processing rm635__09.65.image_aa_blue Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:11 Write : Processing rm635__09.65.image_aa_blue Total 416 [416/0/0] blocks to write, writing... TIME : Write time : 00:00:19 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:28 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2690 Software Info: V 09.65 04-12-09 RM-635 (c) Nokia IMEI: 358260030035875 PPM version : V 09.65 04-12-09 RM-635 (c) Nokia AA Product code: 0592095 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:10:07 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following 2 Users Say Thank You to MARVZ_TG For This Useful Post: |
12-25-2010, 10:10 | #7487 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | f285 done check version... ZTF285MRV05.01 ZTF285MRV05.01 ZTE F285 version 5.01 selected.. OFFLINE... sending command... ESN(hex) : 80EC8CF1 sending spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 5 sec |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
12-25-2010, 11:30 | #7488 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | Action: read/check information Code: Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: FUTRON25_08B_HW Software version: F118_YG_INTEX_GG_V2. Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 025080920000158 imei-2: 025080920000158 imei-3: 025080920000158 Finished, time used: 4 sec Remove/Install battery now ! Code: Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 025080920000158 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 350724305842255 verification Ok Finished, time used: 9 sec Remove/Install battery now ! |
The Following User Says Thank You to KK Mobile For This Useful Post: |
12-25-2010, 11:30 | #7489 (permalink) |
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | Action: "repair imei" Code: Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 025080920000158 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 500039173097455 verification Ok Finished, time used: 3 sec Remove/Install battery now ! |
12-25-2010, 12:14 | #7490 (permalink) |
Freak Poster Join Date: Dec 2009 Location: India
Member: 1191805 Status: Offline Thanks Meter: 58 | AirTel Cordless FGD8900 SpUnlock This is my First Phone to Unlock With My INFinity Cimbo Box. II purchase This GREAT BOX B4 10 Days.... Thank You Infinity TEam. You Are Great Here Is log.... COM5 [VCP1] selected module v3.62 Device: Airtel-Cordless-FGD8900 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" Warning ! After unlock process finished make this: 1. be sure that there is NO any SIM card in phone 2. press phone "Power" button and power-On phone 3. press phone "Power" button and power-Off phone 4. NOTE ! SIM card can be blocked during first power-On so use SIM card that you ready to move to trash w/o problems ! 5. now you can power-On phone with SIM card Do you understand instruction and want to continue ? unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00380000/00080000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... ................ ................ done warning: can not detect firmware version if software freez: make "Find firmware version (slow process)" unchecked and repeat operation. detecting firmware build... ...... done detecting product-id... ................ done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Airtel-Cordless-FGD8900__ffs... file saved: C:\Program Files\InfinityBox\MModule\Airtel-Cordless-FGD8900__ffs_20101225-163201.B0E.bin flash: 01227E220A2201:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ...... required data found flash: 01227E220A2201:18E59F00000000 flash: 01227E220A2201:18E59F00000000 Write: area 1 (pass 1) required data found flash: 01227E220A2201:18E59F00000000 flash: 01227E220A2201:18E59F00000000 Write: area 1 (pass 2) .......... area 1 patch applied Ok Special operation Done ====> Write ... flash: 01227E220A2201:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 29 sec Remove/Install battery now ! |
The Following User Says Thank You to mick12 For This Useful Post: |
12-25-2010, 12:42 | #7491 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | QSC6010-RD3540 QSC6010-RD3540 LG RD3540 selected.. erasing... done.... Finished, time used: 19 sec |
12-25-2010, 12:56 | #7492 (permalink) |
No Life Poster Join Date: Dec 2007 Location: INDIA
Member: 665989 Status: Offline Sonork: 100.1597348 Thanks Meter: 552 | Lg rd-6100 RD610F04Jan 17 2008 LG RD-6100 version 4 compile Jan 17 2008 selected.. offline.. downloading mode.. sending command.. sending command.. patching in progress 30%.. patching in progress 60%.. patching in progress 90%.. Done... Phones should be restarting now... Finished, time used: 31 sec |
The Following 2 Users Say Thank You to ABDUL RAJA For This Useful Post: |
12-25-2010, 13:00 | #7493 (permalink) |
Member: 665989 Status: Offline Sonork: 100.1597348 Thanks Meter: 552 | Lg-3600 COM40 [LGSIDIAG1] selected module v1.41 Device: LG-3600 operation: SP-unlock Phone should be Switched ON ! connecting... RD360F04 LG RD-3600 version 4 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 23 sec |
12-25-2010, 13:02 | #7494 (permalink) |
Member: 665989 Status: Offline Sonork: 100.1597348 Thanks Meter: 552 | Lg-3610 COM40 [LGSIDIAG1] selected module v1.41 Device: LG-3610 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 23 sec |
The Following User Says Thank You to ABDUL RAJA For This Useful Post: |
12-25-2010, 13:40 | #7495 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v1.78 Device: SFR-111 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: SFR-P108A2FMV1.0.0B03 04.12.00 18.26.11 08.02.00 Aug 28 2008 SFR Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-static_20101225-173910.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-security_20101225-173910.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_eeprom-complete_20101225-173912.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\SFR-111_lock-area_20101225-173915.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 34 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
12-25-2010, 13:50 | #7496 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM6 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware D386_PCB01_GSM_MT6223_S00.SW_V00_05_YIDALONG_4m_En _Hi.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:737C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #01 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #02 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST M28W320CT T 4Mb otp offset: 003F0000 detecting chip #03 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #04 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #05 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #06 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #07 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #08 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #09 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #0A in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #0B in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #0C in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #0D in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #0E in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 detecting chip #0F in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 error: no any expected answer : wrong answer after chip cfi request flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST M28W320CT T 4Mb otp offset: 003F0000 number of flash chip/regions detected: 10/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00011B98, retry... warning: wrong cs at 0x00011B98, retry... read error recovered search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 30.11.2010): D386_PCB01_GSM_MT6223_S00.SW_V00_01_YIDALONG.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: D386_PCB01_GSM_MT6223_S00.SW_V00_01_YIDALONG.BIN project-id: D386.SW.V00.01.YIDALONG, 00000000 code offset: 00000000 ffs offset/size [02]: 003B0000/00050000 rom info structure: [standard] type (07) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 2088BAFFFFFFFF:2088BA00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 17 sec Remove/Install battery now ! |
12-25-2010, 15:17 | #7497 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Côte d'Ivoire_Ghana_Nigeria Age: 40
Member: 846968 Status: Offline Sonork: 100.1613167 Thanks Meter: 139 | unlock done MI 205 e from Ghana lock on Tigo COM3 [VCP0] selected module v1.78 Device: ZTE-225FM Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\ZTE-225FM_eeprom-static_20101225-113457.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\ZTE-225FM_eeprom-security_20101225-113459.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\ZTE-225FM_eeprom-complete_20101225-113506.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\ZTE-225FM_lock-area_20101225-113519.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 1 min 1 sec Remove/Install battery now ! |
The Following User Says Thank You to Maik_TechService For This Useful Post: |
12-25-2010, 15:25 | #7498 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Rawalpindi,Pakistan Age: 45
Member: 133099 Status: Offline Sonork: 100.1582860 Thanks Meter: 18 | 2730 DONE in two hours jobs in progress: 0 jobs done: 1 Unlock procedure started... Server version: 0.140 There are 63 free slots on the server. Looking for jobs...You have no current jobs. Archived jobs: 356057035530740: Code: #pw+789889407333840+7# Using F-bus count... Sending code 789889407333840 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Done! Phone disconected! |
The Following 3 Users Say Thank You to G*Mughal*G For This Useful Post: |
12-25-2010, 15:34 | #7499 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | samsung b-159 unlock done COM24 [sacumdm0] selected module v1.41 Device: Samsung-SCH-B159 operation: DE-26 boot unlock (Force mode) Phone should be Switched ON ! connecting... samsung b159 boot mode... Patching in progress... patching done... Wait reconnecting for restart... Done... Phones should be restart now if not take out the battery... Finished, time used: 21 sec COM2 [VCP0] selected module v1.41 Device: Samsung-SCH-B159 operation: UART unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1/1 done step-1/2 done step-1/3 done step-1/4 done step-1/5 done step-2 done step-3 done operation finished Finished, time used: 24 sec |
The Following 2 Users Say Thank You to JINDALGSM™ For This Useful Post: |
12-25-2010, 15:37 | #7500 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | samsung b-159 unlock 2nd done COM24 [sacumdm0] selected module v1.41 Device: Samsung-SCH-B159 operation: DE-26 boot unlock (Force mode) Phone should be Switched ON ! connecting... samsung b159 boot mode... Patching in progress... patching done... Wait reconnecting for restart... Done... Phones should be restart now if not take out the battery... Finished, time used: 21 sec COM2 [VCP0] selected module v1.41 Device: Samsung-SCH-B159 operation: UART unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1/1 done step-1/2 done step-1/3 done step-1/4 done step-1/5 done step-2 done step-3 done operation finished Finished, time used: 24 sec |
