03-13-2012, 10:07 | #15451 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 61
Member: 4813 Status: Offline Thanks Meter: 401 | Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-612_10.0.024_prd.core.C00 PPM : RM-612_10.0.024_prd.rofs2.V01 PPM2 : RM-612_10.0.024_C01_prd.rofs3.fpsx CNT : RM-612_10.0.024_uda_1_001.uda.fpsx APE : RM612_APE_ONLY_ENO_10w20_v0.014.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 10.0.024 Phone version : v 10.0.024 -> Error on SW version check... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\356994040970992_SI M.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0AB0000F30FE0252527D2F1596317883BC98E030 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-612_10.0.024_prd.core.C00 Found 4 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0D39FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:03 Write : Processing RM-612_10.0.024_prd.core.C00 Total 482 [482/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:35 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-612_10.0.024_prd.rofs2.V01 Found 1 areas to erase Erasing area 0x094A0000 - 0x0C49FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-612_10.0.024_prd.rofs2.V01 Total 120 [120/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:09 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-612_10.0.024_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x0C4A0000 - 0x0D39FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-612_10.0.024_C01_prd.rofs3.fpsx Total 5 [5/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-612_10.0.024_uda_1_001.uda.fpsx Found 1 areas to erase Erasing area 0x0D3C0000 - 0x1EF7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-612_10.0.024_uda_1_001.uda.fpsx Total 77 [77/0/0] blocks to write, writing... TIME : Write time : 00:00:07 CNT Write done ===Flashing [APE]=== Erase : Processing RM612_APE_ONLY_ENO_10w20_v0.014.fpsx Found 1 areas to erase Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM612_APE_ONLY_ENO_10w20_v0.014.fpsx Total 15 [15/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:00 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:57 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C6-00 Software Info: V ICPR72_10w17.6 21-06-10 RM-612 (c) Nokia IMEI: 356994040970992 Ape Version: v 10.0.024 Product code: 059B6W6 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:32 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
03-13-2012, 10:37 | #15452 (permalink) |
Insane Poster Join Date: Oct 2009 Location: algeria
Member: 1136177 Status: Offline Sonork: 1613648:gsmcom Thanks Meter: 5 | alcatel 330 FM unlock done COM128 [VCP3] selected module v4.20 Device: Vodafone-330FM Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:2356:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000000:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V31.BIN project-id: MAUI.07A.W07.36.SP1.V31, 00000000 code offset: 00000000 ffs offset/size [01]: 00A00000/00600000 TCL-ID identification version: 766 provider: F330X-2AVDDE1 customization: CH76CE05 customization: XH76CE05 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 00A00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XH76CE05 customization name adjusted flash: 98000300000000:2AEA0000000000 flash: 98000300000000:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000000:2AEA0000000000 flash: 98000300000000:2AEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35608502063716 flash: 98000300000000:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000000:2AEA0000000000 Finalization Done file saved: C:\InfinityBox\MModule\backup_security\Vodafone-330FM_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07 _36_SP1_V31__system_log__00000000_20120313-100058.B0X.bin Finished, time used: 4 min 12 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to gsmcomm For This Useful Post: |
03-13-2012, 11:10 | #15453 (permalink) |
Member: 4813 Status: Offline Thanks Meter: 401 | Core : v1.40 , FlashEngine : v1.23 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-505_22.0.110_prd.core.C00 PPM : RM-505_22.0.110_prd.rofs2.V01 PPM2 : RM-505_22.0.110_C01_prd.rofs3.fpsx CNT : RM505_507_22.0.110_uda_1_001.uda.fpsx APE : RM505_APE_ONLY_ENO_09w23_v0.072.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 22.0.110 Phone version : v 22.0.110 -> Error on SW version check... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\354225030796622_SI M.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1820011844750052AB64FEE989471626E8152594 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-505_22.0.110_prd.core.C00 Found 4 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0AB9FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-505_22.0.110_prd.core.C00 Total 477 [477/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:36 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-505_22.0.110_prd.rofs2.V01 Found 1 areas to erase Erasing area 0x079A0000 - 0x09C9FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-505_22.0.110_prd.rofs2.V01 Total 102 [102/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:08 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-505_22.0.110_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09CA0000 - 0x0AB9FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-505_22.0.110_C01_prd.rofs3.fpsx Total 6 [6/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM505_507_22.0.110_uda_1_001.uda.fpsx Found 1 areas to erase Erasing area 0x0ABA0000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM505_507_22.0.110_uda_1_001.uda.fpsx Total 36 [36/0/0] blocks to write, writing... TIME : Write time : 00:00:03 CNT Write done ===Flashing [APE]=== Erase : Processing RM505_APE_ONLY_ENO_09w23_v0.072.fpsx Found 1 areas to erase Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM505_APE_ONLY_ENO_09w23_v0.072.fpsx Total 16 [16/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:00 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:51 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N97 Software Info: V ICPR72_09w44.18 28-05-10 RM-505 (c) Nokia IMEI: 354225030796622 Ape Version: v 22.0.110 Product code: 0576356 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:26 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
03-13-2012, 11:33 | #15454 (permalink) |
Freak Poster Join Date: Apr 2006 Location: BG Age: 46
Member: 255473 Status: Offline Thanks Meter: 49 | Globul Home TA2322n unlock OK! COM4 [VCP0] selected module v4.13 Device: Globul-TA2322n Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:750A:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2AEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: M910_CJC_EN_PCB01_GPRS_MT6223_S00.M910_H10S08_CALC _CJC_EN.BIN project-id: M910_H10S08_CALC_CJC_EN, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98009600000000:2AEA0000000000 Backup required data Done ====> Patch required data ... .................... lock area found .................... lock area found Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98009600000000:2AEA0000000000 flash: 98009600000000:2AEA0000000000 Write: lock-area-1 flash: 98009600000000:2AEA0000000000 flash: 98009600000000:2AEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 15 sec Remove/Install battery now ! |
The Following User Says Thank You to jordan_antonov For This Useful Post: |
03-13-2012, 13:41 | #15455 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Nokia X2 RM-618 Usb Flash With Rpl Backup By Best Dongle Code: Core : v1.40 , FlashEngine : v1.23 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm618__08.25.mcusw PPM : rm618__08.25.ppm_ms CNT : rm618__08.25.image_ms_0595278_008 Flashing phone now... Check files done... -> Check SW version... FlashFile version : 08.25 Phone version : 08.25 19-05-11 RM-618 (c) Nokia -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBCRT, FullUSB EM0 ID: 00005361 PUBLIC ID: 000000000008704B1841E1B697EE2F6233AFCDC2 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 11.50.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 11.50.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : E9700989029D9E899915F781B1582048E042A738 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 359317042355763 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\359317042355763.rpl ===Flashing [MCU]=== Erase : Processing rm618__08.25.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.25.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [UPDAPP] Total writen 511 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000008 / 00000007 / 00000000 ===Flashing [PPM]=== Erase : Processing rm618__08.25.ppm_ms Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.25.ppm_ms Total writen 112 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000008 / 00000007 / 00000000 ===Flashing [CNT]=== Erase : Processing rm618__08.25.image_ms_0595278_008 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm618__08.25.image_ms_0595278_008 Total writen 390 blocks TIME : Write time : 00:00:04 CNT Write done ADL: Request programm status NAND status : 00000008 / 00000007 / 00000000 ADL: Close_Session Content: 000300000000080000000700000000 ADL: Reboot Flashing done! Total flash time : 00:00:13 Reboot phone now... Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Elapsed: 00:00:35 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Thanks To Best Dongle / Infinity Team |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
03-13-2012, 13:45 | #15456 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Nokia C3 RM-614 Usb Flash With Rpl Backup By Best Dongle Code: Core : v1.40 , FlashEngine : v1.23 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm614__08.71.mcusw PPM : rm614__08.71.ppm_ms CNT : rm614__08.71.image_ms_0598879 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. :( -> Boot fail... Flashing failed... Core : v1.40 , FlashEngine : v1.23 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm614__08.71.mcusw PPM : rm614__08.71.ppm_ms CNT : rm614__08.71.image_ms_0598879 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBCRT, FullUSB EM0 ID: 00005361 PUBLIC ID: 00000000005A4B55B7526295FDBCF592249C6E58 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 11.50.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 11.50.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 356247041313690 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\356247041313690_CRT.rpl ===Flashing [MCU]=== Erase : Processing rm614__08.71.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm614__08.71.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 528 blocks TIME : Write time : 00:00:33 MCU Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [PPM]=== Erase : Processing rm614__08.71.ppm_ms Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm614__08.71.ppm_ms Total writen 108 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [CNT]=== Erase : Processing rm614__08.71.image_ms_0598879 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm614__08.71.image_ms_0598879 Total writen 242 blocks TIME : Write time : 00:00:15 CNT Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Flashing done! Total flash time : 00:00:58 Reboot phone now... Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Elapsed: 00:01:26 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
03-13-2012, 13:48 | #15457 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Nokia x3 Rm-540 Usb Flash By Best Dongle Code: Core : v1.40 , FlashEngine : v1.23 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm540__08.54.mcusw PPM : rm540__08.54.ppm_i CNT : rm540__08.54.image_i_0580821_006 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600000001020C192102054100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1F500010D37254407F34E6DA058F05097256502B ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 11.50.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 11.50.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing rm540__08.54.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm540__08.54.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 124 blocks TIME : Write time : 00:00:31 MCU Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing rm540__08.54.ppm_i Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm540__08.54.ppm_i Total writen 24 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing rm540__08.54.image_i_0580821_006 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm540__08.54.image_i_0580821_006 Total writen 64 blocks TIME : Write time : 00:00:19 CNT Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Flashing done! Total flash time : 00:01:00 Reboot phone now... Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Elapsed: 00:01:46 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
03-13-2012, 13:51 | #15458 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Nokia c2 Rm-721 Usb Flash By Best Dongle Code: Core : v1.40 , FlashEngine : v1.23 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm721__11.20.mcusw PPM : rm721__11.20.ppm_i CNT : rm721__11.20.image_i_059G383_005 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600000001020C192102044100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 0E90000FF1EF1049C735B954DD6E2B55DAD44A2E ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 11.50.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 11.50.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing rm721__11.20.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm721__11.20.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 134 blocks TIME : Write time : 00:00:34 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm721__11.20.ppm_i Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm721__11.20.ppm_i Total writen 26 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm721__11.20.image_i_059G383_005 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm721__11.20.image_i_059G383_005 Total writen 71 blocks TIME : Write time : 00:00:21 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:01:06 Reboot phone now... Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Elapsed: 00:01:58 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
03-13-2012, 13:54 | #15459 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Nokia E51 Rm-244 Usb Flash By Best Dongle Code: Core : v1.40 , FlashEngine : v1.23 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm244_41034001_prd.c00 PPM : rm244_41034001_prd.v08 CNT : rm244_41034001.01U Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101021103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 20800103719C0058D89AE2829387152563E498EA ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! :) TIME : Boot time : 00:00:30 Reopening the connection... Waiting for response: 30 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm244_41034001_prd.c00 Found 2 areas to erase Erasing area 0x00040000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00A00000 - 0x068FFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing rm244_41034001_prd.c00 Total 444 [444/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:10 MCU Write done ===Flashing [PPM]=== Erase : Processing rm244_41034001_prd.v08 Found 1 areas to erase Erasing area 0x04A00000 - 0x068FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm244_41034001_prd.v08 Total 157 [157/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:25 PPM Write done ===Flashing [CNT]=== Erase : Processing rm244_41034001.01U Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm244_41034001.01U Total 30 [30/0/0] blocks to write, writing... TIME : Write time : 00:00:05 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:43 Reboot phone now... Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Elapsed: 00:02:39 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
03-13-2012, 13:57 | #15460 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Nokia 6303i Rm-638 Usb Flash By Best Dongle Code: Core : v1.40 , FlashEngine : v1.21 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm638__10.80.mcusw PPM : rm638__10.80.ppm_i CNT : rm638__10.80.image_i_0594126_010 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600000001020C192102054100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 194003119ABF0D49C2FA0AB1771E1723C3821382 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 11.50.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 11.50.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 108AF4DB7EC8B1B36E9D6A60F7EB2996DC7B2B5D ADL: phone is in flash mode ===Flashing [MCU]=== Erase : Processing rm638__10.80.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm638__10.80.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 126 blocks TIME : Write time : 00:00:32 MCU Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [PPM]=== Erase : Processing rm638__10.80.ppm_i Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm638__10.80.ppm_i Total writen 25 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [CNT]=== Erase : Processing rm638__10.80.image_i_0594126_010 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm638__10.80.image_i_0594126_010 Total writen 99 blocks TIME : Write time : 00:00:30 CNT Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Flashing done! Total flash time : 00:01:13 Reboot phone now... Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Elapsed: 00:01:44 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
03-13-2012, 14:03 | #15461 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Nokia 5130c Rm-495 Usb Flash By Best Dongle Code: Core : v1.40 , FlashEngine : v1.21 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_ms CNT : rm495__07.97.image_ms_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1E2002111FC77D56886F65551F0B90F3308AC6E4 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:40 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:57 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_ms Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:04 Write : Processing rm495__07.97.ppm_ms Total 431 [431/0/0] blocks to write, writing... TIME : Write time : 00:00:21 PPM Write done ===Flashing [CNT]=== Erase : Processing rm495__07.97.image_ms_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:54 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm495__07.97.image_ms_red Total 680 [680/0/0] blocks to write, writing... TIME : Write time : 00:00:35 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:33 Reboot phone now... Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Done! Elapsed: 00:12:57 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
03-13-2012, 14:13 | #15462 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 6303c flashing done card found: S/N --------- registered to: Akramjon Connect phone on selected interface... Core : v1.40 , FlashEngine : v1.23 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_i CNT : rm443__10.12.image_i_bg_ua_matt_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- -> Phone not found.. -> Error while flashing... Core : v1.40 , FlashEngine : v1.23 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_i CNT : rm443__10.12.image_i_bg_ua_matt_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1DB000171EA77D56DEDE90A7FC29E60B10D17A2C CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:08 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm443__10.12.mcusw Found 8 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT Result: 0000 Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT Result: 0000 Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT Result: 0000 Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT Result: 0000 Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:45 Write : Processing rm443__10.12.mcusw Total 1597 [1597/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [ISA+DYNSW] TIME : Write time : 00:01:21 MCU Write done ===Flashing [PPM]=== Erase : Processing rm443__10.12.ppm_i Found 1 areas to erase Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:55 Write : Processing rm443__10.12.ppm_i Total 429 [429/0/0] blocks to write, writing... TIME : Write time : 00:00:22 PPM Write done ===Flashing [CNT]=== Erase : Processing rm443__10.12.image_i_bg_ua_matt_black Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:23 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm443__10.12.image_i_bg_ua_matt_black Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:33 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:21 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 353199038721448 PPM version : V 10.12 08-04-10 RM-443 (c) Nokia I Product code: 0580772 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Elapsed: 00:10:13 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
03-13-2012, 20:03 | #15463 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1725927 Status: Offline Thanks Meter: 24 | COM10 [VCP0] selected module v4.13 Action: "sp-unlock" unlock method: smart fast Model: Verykool-i305 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:BA3E:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: KAAI305FM_SAD_Sp_En_Fr_1.04.C01 Version: KONKA23C_08B_GEMINI_HW 80 byte(s) read imei: 86335200043849 connection Ok 185 byte(s) read reading data... reading data #2... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! |
The Following User Says Thank You to yankee02 For This Useful Post: |
03-14-2012, 07:43 | #15465 (permalink) |
No Life Poster Join Date: May 2007 Location: india
Member: 500302 Status: Offline Thanks Meter: 157 | successfully repaired nokia c50-02 ded set card found: S/N 01F9:0118 registered to: wasi$$$$ Connect phone on selected interface... Core : v1.40 , FlashEngine : v1.23 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm745_081.003_prd.core.fpsx PPM : rm745_081.003_21.01_India_prd.rofs2.fpsx PPM2 : rm745_081.003_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm745_081.003_U000.000_prd.uda.fpsx APE : rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0B20020A9FDA0344096356334C73B28F239D46B4 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.50.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.50.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 5F18D62F8F3D105EEFB6633F44614F8C6DCCA7E8 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357006042016622 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\3570060######_CRT. rpl ===Flashing [MCU]=== Erase : Processing rm745_081.003_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm745_081.003_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 415 blocks TIME : Write time : 00:00:25 MCU Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing rm745_081.003_21.01_India_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm745_081.003_21.01_India_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 129 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm745_081.003_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm745_081.003_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing rm745_081.003_U000.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm745_081.003_U000.000_prd.uda.fpsx Total writen 37 blocks TIME : Write time : 00:00:05 CNT Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [APE]=== Erase : Processing rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 10 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Flashing done! Total flash time : 00:00:47 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C5-00 Software Info: V ICPR82_11w16.3.6 03-10-11 RM-745 (c) Nokia IMEI: 357006042016622 Ape Version: 081.003 Product code: 059F0N3 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:23 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia C5-00 Software ver : V ICPR82_11w16.3.6 03-10-11 RM-745 (c) Nokia IMEI : 35700604###### Ape Ver : 081.003 APE Var : 081.003081.003.21.01081.003.C00.01 APE ADSP: 256 DSP Ver : ICPR82_11w16 APE Test: rm745_APE_ONLY_ENO_11wk02v0 PPM : CNT : Product SN : 26D07ADAA Product code : 059F0N3 Base Prd.code: 059F0H3 Module code : 0204821 Long Prod.SN : 0 Hardware info======= HWID : 6000 Retu : 35 Tahvo : 00 Batery: 4066 mV Camera: CMT BT: APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 3570060###### IMEI spNet : 3A 75 00 06 24 10 66 02 IMEI svNet : 33 75 00 06 24 10 66 12 F8 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
The Following User Says Thank You to Wasim007 For This Useful Post: |
