08-21-2012, 09:09 | #16816 (permalink) |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | C7 lbf data read USB 100% Code: Reading Phone Info.... Connected phone - Nokia C7-00 Software ver : V 92PS1_10w36.3 27-09-10 RM-675 (c) Nokia IMEI : 356252044182431 Ape Ver : 012.004 APE Var : 012.004.00.01012.004.11.01012.004.204.06 APE ADSP: 256 DSP Ver : TB92PS1_10w36 APE Test: rm675_ENO_v_0.0414 PPM : CNT : Product SN : 143A127AA Product code : 059D046 Base Prd.code: 0595319 Module code : 0204505 Long Prod.SN : 0 Hardware info======= HWID : 6027 Retu : 40 Tahvo : 00 Batery: 4071 mV APE BT: HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1936. APE HW: 256 Lock info =========== IMEI : 356252044182431 IMEI spNet : 3A 65 52 02 44 81 42 03 IMEI svNet : 33 65 52 02 44 81 42 03 F3 Conf key : 8000000000000000 Provider key : 2140700000000000 Country : Spain Operator : movistar Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Phone Imei: 356252044182431 Checking locks... Conf key : 8000000000000000 Provider key : 2140700000000000 Country : Spain Operator : movistar Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL3 (15 digit) phone detected... - > Power Off phone, dissconnect it and connect Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 06A000047BD403447AD12A3D242B4BE9CA49E7A1 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 06A000047BD403447AD12A3D242B4BE9CA49E7A1 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 006800EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Wait, reconneting... rap= 06A000047BD403447AD12A3D242B4BE9CA49E7A1 hash= 916F75217F32081248B15C38DFC8E81B key= C2F1ECE16E17BC6B27460185827BB9C9BAAF6E8A Key file updated... Check RSA started... Check RSA ok Create Log file for local calculation... File d:\InfinityBox\BEST\Local_calc\356252044182431.bcl created - Ok File d:\InfinityBox\BEST\Local_calc\ighashgpu_356252044182431.bat created - Ok File d:\InfinityBox\BEST\Local_calc\oclHashcat_356252044182431_32.bat created - Ok File d:\InfinityBox\BEST\Local_calc\oclHashcat_356252044182431_64.bat created - Ok Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to hugmax For This Useful Post: |
08-21-2012, 12:02 | #16817 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | registered to: nadoui Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 7230 Software ver : V 10.81 28-02-11 RM-604 (c) Nokia IMEI : 358258042603607 DSP Ver : SPR91_10.80c PPM : V 10.81 28-02-11 RM-598 (c) Nokia C CNT : Content: SFR FR v2 sl V 10.81 28-02-11 RM-604 (c) Nokia Product SN : 23C4DCFAH Product code : 0597985 Base Prd.code: 059D6Z5 Module code : 0204859 Long Prod.SN : 0 Hardware info======= HWID : 1002 Retu : 40 Tahvo : 00 Batery: 3853 mV CMT BT: 1673-46038 LCDVer: SEIKO Lock info =========== IMEI : 358258042603607 IMEI spNet : 3A 85 52 08 24 06 63 00 IMEI svNet : 33 85 52 08 24 06 63 60 F6 Conf key : 8000000000000000 Provider key : 2081000000000000 Country : France Operator : F SFR Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Using F-bus count... Sending code 376149378599640 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Done! |
The Following User Says Thank You to Nadoui For This Useful Post: |
08-22-2012, 07:45 | #16818 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | card found: S/N C0B4:0118 registered to: Akramjon Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL not support backup mode, rpl reading impossible SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox\BEST\Backup\Cert\352448056652444_SI M.rpl Elapsed: 00:00:01 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v1.50 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm813__14.53.mcusw PPM : rm813__14.53.ppm_i1 CNT : rm813__14.53.image_i1_059K7W5_010 Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 0C500000FFFB7C40ACCE17D90DE2D97D13AC7A57 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 352448056652444 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox\BEST\Backup\Cert\352448056652444.rp l ===Flashing [MCU]=== Erase : Processing rm813__14.53.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm813__14.53.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ISA+EXTDRV] Total writen 274 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [PPM]=== Erase : Processing rm813__14.53.ppm_i1 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm813__14.53.ppm_i1 Total writen 48 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [CNT]=== Erase : Processing rm813__14.53.image_i1_059K7W5_010 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing rm813__14.53.image_i1_059K7W5_010 Total writen 203 blocks TIME : Write time : 00:00:03 CNT Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Flashing done! Total flash time : 00:00:13 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 302 Software Info: V 14.53 20-03-12 RM-813 (c) Nokia IMEI: 352448056652444 PPM version : V 14.53 20-03-12 RM-813 (c) Nokia I1 Product code: 059L1B5 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... Error When resetting FullFactory ... Error When setting User Data defaults ... Error When resetting Product Tune ... Error When resetting SW upgrade Default ... AfterFlash operations done ;D Done! Elapsed: 00:00:44 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-22-2012, 07:50 | #16819 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | card found: S/N C0B4:0118 registered to: Akramjon Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0AB0011314880052DFC666DD4D10C693F9EDCF7D ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done Boot error... Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO If RAPIDO - use dead mode for read rpl/force local SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox\BEST\Backup\Cert\358253038046457_SI M.rpl Phone disconected! Connect phone on selected interface... Core : v1.50 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-504_40.0.003_prd.core.C00 PPM : RM-504_40.0.003_prd.rofs2.V05 PPM2 : RM-504_40.0.003_C01_prd.rofs3.fpsx CNT : RM-504_32.0.007_001_000_U002.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error Try again... -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC -> Boot fail... Flashing failed... Core : v1.50 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-504_40.0.003_prd.core.C00 PPM : RM-504_40.0.003_prd.rofs2.V05 PPM2 : RM-504_40.0.003_C01_prd.rofs3.fpsx CNT : RM-504_32.0.007_001_000_U002.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0AB0011314880052DFC666DD4D10C693F9EDCF7D ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-504_40.0.003_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-504_40.0.003_prd.core.C00 Total 444 [444/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:31 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-504_40.0.003_prd.rofs2.V05 Found 1 areas to erase Erasing area 0x07360000 - 0x0935FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-504_40.0.003_prd.rofs2.V05 Total 111 [111/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:08 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-504_40.0.003_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09360000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-504_40.0.003_C01_prd.rofs3.fpsx Total 23 [23/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:01 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-504_32.0.007_001_000_U002.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-504_32.0.007_001_000_U002.uda.fpsx Total 10 [10/0/0] blocks to write, writing... TIME : Write time : 00:00:00 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:43 Reboot phone now... - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:02:45 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in RfInactive mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:16 |
08-22-2012, 07:52 | #16820 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | card found: S/N C0B4:0118 registered to: Akramjon Connect phone on selected interface... Connect phone on selected interface... Core : v1.50 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-356_60.0.003_prd.core.C00 PPM : RM-356_60.0.003_prd.rofs2.V05 PPM2 : RM-356_60.0.003_C01_prd.rofs3.fpsx CNT : RM-356_60.0.001_026_000_U01.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0F100107DC8A00522AA41EDC86E7D5500BABE286 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-356_60.0.003_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.003_prd.core.C00 Total 510 [510/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:34 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-356_60.0.003_prd.rofs2.V05 Found 1 areas to erase Erasing area 0x07180000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.003_prd.rofs2.V05 Total 116 [116/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:08 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-356_60.0.003_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.003_C01_prd.rofs3.fpsx Total 11 [11/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-356_60.0.001_026_000_U01.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.001_026_000_U01.uda.fpsx Total 29 [29/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:47 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software Info: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia IMEI: 358279038435572 Ape Version: V 60.0.003 Product code: 0588615 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:12 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
08-22-2012, 07:53 | #16821 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | card found: S/N C0B4:0118 registered to: Akramjon Connect phone on selected interface... Core : v1.50 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_i CNT : rm443__10.12.image_i_bg_ua_matt_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 2490000FB9337F5676241D56D4ADF98874BBA177 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:08 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm443__10.12.mcusw Found 8 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT Result: 0000 Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT Result: 0000 Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT Result: 0000 Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT Result: 0000 Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:38 Write : Processing rm443__10.12.mcusw Total 1597 [1597/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [ISA+DYNSW] TIME : Write time : 00:01:15 MCU Write done ===Flashing [PPM]=== Erase : Processing rm443__10.12.ppm_i Found 1 areas to erase Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:14 Write : Processing rm443__10.12.ppm_i Total 429 [429/0/0] blocks to write, writing... TIME : Write time : 00:00:20 PPM Write done ===Flashing [CNT]=== Erase : Processing rm443__10.12.image_i_bg_ua_matt_black Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:28 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm443__10.12.image_i_bg_ua_matt_black Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:31 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:28 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303c Software Info: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 353199033230866 PPM version : V 10.12 08-04-10 RM-443 (c) Nokia I Product code: 0583420 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:12:24 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-22-2012, 07:53 | #16822 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | card found: S/N C0B4:0118 registered to: Akramjon Connect phone on selected interface... Core : v1.50 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_i CNT : rm443__10.12.image_i_bg_ua_matt_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0960000AFC157E56A4BF621C07A0EA691AE43F84 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:08 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm443__10.12.mcusw Found 8 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT Result: 0000 Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT Result: 0000 Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT Result: 0000 Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT Result: 0000 Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:17 Write : Processing rm443__10.12.mcusw Total 1597 [1597/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [ISA+DYNSW] TIME : Write time : 00:01:07 MCU Write done ===Flashing [PPM]=== Erase : Processing rm443__10.12.ppm_i Found 1 areas to erase Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:58 Write : Processing rm443__10.12.ppm_i Total 429 [429/0/0] blocks to write, writing... TIME : Write time : 00:00:18 PPM Write done ===Flashing [CNT]=== Erase : Processing rm443__10.12.image_i_bg_ua_matt_black Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:41 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm443__10.12.image_i_bg_ua_matt_black Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:28 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:51 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 353199039995546 PPM version : V 10.12 08-04-10 RM-443 (c) Nokia I Product code: 0569490 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:11:29 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to Namangan For This Useful Post: |
08-22-2012, 07:54 | #16823 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | card found: S/N C0B4:0118 registered to: Akramjon Connect phone on selected interface... UFS S/N 72218 boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0D40000EF15A6C560C9BC00E7F18CD7FFC024EF4 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 220C00EC , CMT , NOR CMT Flash ID : 220C00EC < SAMSUNG [SEC] => K5G1257ATM FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 3D744C60D026865F8B384F71E83AA7A06FC12277D2 Transmission mode : Dual (Ddr, TX2) Boot Done! PrReq : NOR , 00 Init Service mode... Wait... Init Service Mode Failed, can't proceed checking... Connect phone on selected interface... Core : v1.50 , FlashEngine : v1.7 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm249__05.20.mcusw PPM : rm249__05.20.ppm_f CNT : rm249__05.20.image_f Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0D40000EF15A6C560C9BC00E7F18CD7FFC024EF4 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 220C00EC , CMT , NOR CMT Flash ID : 220C00EC < SAMSUNG [SEC] => K5G1257ATM FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 3D744C60D026865F8B384F71E83AA7A06FC12277D2 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 357685012373095 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! Init Service mode... Wait... Init Service Mode Failed! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\InfinityBox\BEST\Backup\Cert\357685012373095_CR T.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 0D40000EF15A6C560C9BC00E7F18CD7FFC024EF4 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 220C00EC , CMT , NOR CMT Flash ID : 220C00EC < SAMSUNG [SEC] => K5G1257ATM FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 3D744C60D026865F8B384F71E83AA7A06FC12277D2 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm249__05.20.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x01000000 - 0x0111FFFF CMT , NOR , Area : 0x00140000 - 0x00FFFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:09 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm249__05.20.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1026 blocks TIME : Write time : 00:01:47 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm249__05.20.ppm_f Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01120000 - 0x0177FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:13 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm249__05.20.ppm_f Total writen 309 blocks TIME : Write time : 00:00:32 PrReq : NOR , 00 ConvertImage: Processing rm249__05.20.image_f ConvertImage: Page Size is 64K, converting... ConvertImage: File converted Transmission mode : Dual (Ddr, TX2) Erase : Processing rm249__05.20.image_f_128 Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01780000 - 0x018FFFFF CMT , NOR , Area : 0x01900000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:45 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm249__05.20.image_f_128 Total writen 608 blocks TIME : Write time : 00:01:04 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Error Software Info: V 05.20 19-12-07 RM-249 (c) Nokia IMEI: 357685012373095 Product code: 0553130 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-22-2012, 07:54 | #16824 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | card found: S/N C0B4:0118 registered to: Akramjon Connect phone on selected interface... Core : v1.50 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm443__10.12.mcusw PPM : rm443__10.12.ppm_i CNT : rm443__10.12.image_i_bg_ua_matt_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0CF0000EB819685061117C2FB886FB7654406C3E CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:08 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm443__10.12.mcusw Found 8 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT Result: 0000 Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT Result: 0000 Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT Result: 0000 Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT Result: 0000 Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:01 Write : Processing rm443__10.12.mcusw Total 1597 [1597/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [ISA+DYNSW] TIME : Write time : 00:01:02 MCU Write done ===Flashing [PPM]=== Erase : Processing rm443__10.12.ppm_i Found 1 areas to erase Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:02 Write : Processing rm443__10.12.ppm_i Total 429 [429/0/0] blocks to write, writing... TIME : Write time : 00:00:17 PPM Write done ===Flashing [CNT]=== Erase : Processing rm443__10.12.image_i_bg_ua_matt_black Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:50 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm443__10.12.image_i_bg_ua_matt_black Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:25 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:39 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 358256034087755 PPM version : V 10.12 08-04-10 RM-443 (c) Nokia I Product code: 0577406 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Elapsed: 00:11:02 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-22-2012, 15:03 | #16825 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 503 | OT-105X UNLOCKED SUCCESFULY; module v4.37 Device: Alcatel-105X, 105A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:5E54:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 66E provider: 105X-2BRGKE9 customization: CM66CW40 customization: XM66CW40 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM66CW40 customization name adjusted flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... max address is too big, should be recalculated: 0827D124->0827C91C ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 8C22F60000000D:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 8C22F60000000D:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-105X,105A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201208 22-165513.B0X.bin Finished, time used: 2 min 6 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
08-23-2012, 14:40 | #16826 (permalink) |
No Life Poster Join Date: May 2005 Location: Pakistan,Peshawar
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | Nokia 7020 flashing done Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 7020 Software ver : V 05.41 29-01-10 RM-497 (c) Nokia IMEI : 351989041126383 PPM : V 05.41 29-01-10 RM-497 (c) Nokia MEC CNT : Content: meac_0579353 V 05.41 29-01-10 RM-497 (c) Nokia Product SN : HGC258214 Product code : 0579353 Base Prd.code: 0570540 Module code : 0204040 Long Prod.SN : 0 Hardware info======= HWID : 1000 Batery: 3739 mV CMT BT: 2.31-SP2.26 LCDVer: SEIKO Lock info =========== IMEI : 351989041126383 IMEI spNet : 3A 15 89 09 14 21 36 08 IMEI svNet : 33 15 89 09 14 21 36 28 F1 Conf key : 8000000000000002 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm497__08.14.mcusw PPM : rm497__08.14.ppm_f CNT : rm497__08.14_004.image_f_cellcom_il_999b3 Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3763 mV -> Batery voltage less, than 3,8V (3763mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005331 PUBLIC ID: 3F05AEFE03B11C9F3001D8AACEC73F9A3F0AC23A ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 57B0CD145768F65CDF89F47F1FAE61BF16EF7DD7 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 351989041126383 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\351989041126383.rp l ===Flashing [MCU]=== Erase : Processing rm497__08.14.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm497__08.14.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [GENIO_INIT] Total writen 458 blocks TIME : Write time : 00:00:06 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm497__08.14.ppm_f Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm497__08.14.ppm_f Total writen 114 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm497__08.14_004.image_f_cellcom_il_999b3 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm497__08.14_004.image_f_cellcom_il_999b3 Total writen 237 blocks TIME : Write time : 00:00:03 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:12 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 7020 Software Info: V 08.14 29-07-10 RM-497 (c) Nokia IMEI: 351989041126383 PPM version : V 08.14 29-07-10 RM-497 (c) Nokia F Product code: 0579353 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 35 certs Data exist, skip certificate repair... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:07 Connect phone on selected interface... GSM007 |
The Following User Says Thank You to ***GSM007*** For This Useful Post: |
08-23-2012, 14:45 | #16827 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,218 | C1-01 Flash. Code: Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - C1-01 Software ver : V 05.45 22-06-11 RM-607 (c) Nokia IMEI : 351662057363956 PPM : V 05.45 22-06-11 RM-607 (c) Nokia M_A CNT : Content: m_a_0596377 V 05.45 22-06-11 RM-607 (c) Nokia Product SN : F613C50AI Product code : 0596377 Base Prd.code: 0585582 Module code : 0204427 Long Prod.SN : 0 Hardware info======= HWID : 2001 Batery: 3853 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 351662057363956 IMEI spNet : 3A 15 66 02 75 63 93 05 IMEI svNet : 33 15 66 02 75 63 93 15 F6 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : AECE3942E8A41BA9 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created INFINEON : SuperDongle not exist (It is Ok) SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Reading PM from field 0 to 400 Field [4] 10 Record(s) Record 1: 800 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 18: 80 byte(s) readed - Ok Record 19: 4 byte(s) readed - Ok Record 26: 132 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [8] 11 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 7: 4 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 9: 8 byte(s) readed - Ok Record 10: 32 byte(s) readed - Ok Record 11: 4 byte(s) readed - Ok Record 12: 4 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 241 byte(s) readed - Ok Field [13] 167 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 1 byte(s) readed - Ok Record 3: 2 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 2 byte(s) readed - Ok Record 9: 1 byte(s) readed - Ok Record 10: 1 byte(s) readed - Ok Record 11: 48 byte(s) readed - Ok Record 12: 4 byte(s) readed - Ok Record 13: 1 byte(s) readed - Ok Record 14: 1 byte(s) readed - Ok Record 15: 886 byte(s) readed - Ok Record 16: 2 byte(s) readed - Ok Record 17: 1 byte(s) readed - Ok Record 18: 1 byte(s) readed - Ok Record 19: 8 byte(s) readed - Ok Record 20: 1 byte(s) readed - Ok Record 21: 1 byte(s) readed - Ok Record 22: 1 byte(s) readed - Ok Record 23: 1 byte(s) readed - Ok Record 24: 1 byte(s) readed - Ok Record 25: 2 byte(s) readed - Ok Record 26: 1 byte(s) readed - Ok Record 27: 1 byte(s) readed - Ok Record 28: 1 byte(s) readed - Ok Record 29: 1 byte(s) readed - Ok Record 30: 1 byte(s) readed - Ok Record 31: 1 byte(s) readed - Ok Record 32: 1 byte(s) readed - Ok Record 33: 1 byte(s) readed - Ok Record 34: 1 byte(s) readed - Ok Record 35: 1 byte(s) readed - Ok Record 36: 1 byte(s) readed - Ok Record 37: 4 byte(s) readed - Ok Record 38: 1 byte(s) readed - Ok Record 39: 1 byte(s) readed - Ok Record 40: 1 byte(s) readed - Ok Record 41: 1 byte(s) readed - Ok Record 42: 4 byte(s) readed - Ok Record 43: 4 byte(s) readed - Ok Record 44: 1 byte(s) readed - Ok Record 45: 4 byte(s) readed - Ok Record 46: 4 byte(s) readed - Ok Record 47: 1 byte(s) readed - Ok Record 48: 4 byte(s) readed - Ok Record 49: 1 byte(s) readed - Ok Record 50: 1 byte(s) readed - Ok Record 51: 1 byte(s) readed - Ok Record 52: 2 byte(s) readed - Ok Record 53: 4 byte(s) readed - Ok Record 54: 4 byte(s) readed - Ok Record 55: 1 byte(s) readed - Ok Record 56: 1 byte(s) readed - Ok Record 57: 1 byte(s) readed - Ok Record 58: 2 byte(s) readed - Ok Record 59: 1 byte(s) readed - Ok Record 60: 4 byte(s) readed - Ok Record 61: 4 byte(s) readed - Ok Record 62: 1 byte(s) readed - Ok Record 63: 4 byte(s) readed - Ok Record 64: 4 byte(s) readed - Ok Record 65: 1 byte(s) readed - Ok Record 66: 4 byte(s) readed - Ok Record 67: 4 byte(s) readed - Ok Record 68: 1 byte(s) readed - Ok Record 69: 1 byte(s) readed - Ok Record 70: 1 byte(s) readed - Ok Record 71: 4 byte(s) readed - Ok Record 72: 4 byte(s) readed - Ok Record 73: 1 byte(s) readed - Ok Record 74: 4 byte(s) readed - Ok Record 75: 2 byte(s) readed - Ok Record 76: 2 byte(s) readed - Ok Record 77: 2 byte(s) readed - Ok Record 78: 1 byte(s) readed - Ok Record 79: 1 byte(s) readed - Ok Record 80: 1 byte(s) readed - Ok Record 81: 1 byte(s) readed - Ok Record 82: 1 byte(s) readed - Ok Record 83: 2 byte(s) readed - Ok Record 84: 1 byte(s) readed - Ok Record 85: 4 byte(s) readed - Ok Record 86: 4 byte(s) readed - Ok Record 87: 2 byte(s) readed - Ok Record 88: 1 byte(s) readed - Ok Record 89: 4 byte(s) readed - Ok Record 90: 4 byte(s) readed - Ok Record 91: 2 byte(s) readed - Ok Record 92: 1 byte(s) readed - Ok Record 93: 4 byte(s) readed - Ok Record 94: 4 byte(s) readed - Ok Record 95: 2 byte(s) readed - Ok Record 96: 1 byte(s) readed - Ok Record 97: 4 byte(s) readed - Ok Record 98: 4 byte(s) readed - Ok Record 99: 2 byte(s) readed - Ok Record 100: 4 byte(s) readed - Ok Record 101: 2 byte(s) readed - Ok Record 102: 1 byte(s) readed - Ok Record 103: 4 byte(s) readed - Ok Record 104: 4 byte(s) readed - Ok Record 105: 4 byte(s) readed - Ok Record 106: 4 byte(s) readed - Ok Record 107: 4 byte(s) readed - Ok Record 108: 2 byte(s) readed - Ok Record 109: 4 byte(s) readed - Ok Record 110: 4 byte(s) readed - Ok Record 111: 4 byte(s) readed - Ok Record 112: 2 byte(s) readed - Ok Record 113: 4 byte(s) readed - Ok Record 114: 4 byte(s) readed - Ok Record 115: 1 byte(s) readed - Ok Record 116: 1 byte(s) readed - Ok Record 117: 1 byte(s) readed - Ok Record 118: 4 byte(s) readed - Ok Record 119: 4 byte(s) readed - Ok Record 120: 1 byte(s) readed - Ok Record 121: 1 byte(s) readed - Ok Record 122: 1 byte(s) readed - Ok Record 123: 8 byte(s) readed - Ok Record 124: 1 byte(s) readed - Ok Record 125: 1 byte(s) readed - Ok Record 126: 1 byte(s) readed - Ok Record 127: 1 byte(s) readed - Ok Record 128: 1 byte(s) readed - Ok Record 129: 4 byte(s) readed - Ok Record 130: 4 byte(s) readed - Ok Record 131: 1 byte(s) readed - Ok Record 132: 1 byte(s) readed - Ok Record 133: 2 byte(s) readed - Ok Record 134: 1 byte(s) readed - Ok Record 135: 2 byte(s) readed - Ok Record 136: 1 byte(s) readed - Ok Record 137: 1 byte(s) readed - Ok Record 138: 4 byte(s) readed - Ok Record 139: 4 byte(s) readed - Ok Record 140: 1 byte(s) readed - Ok Record 141: 1 byte(s) readed - Ok Record 142: 1 byte(s) readed - Ok Record 143: 1 byte(s) readed - Ok Record 144: 4 byte(s) readed - Ok Record 145: 8 byte(s) readed - Ok Record 146: 4 byte(s) readed - Ok Record 147: 4 byte(s) readed - Ok Record 148: 1 byte(s) readed - Ok Record 149: 1 byte(s) readed - Ok Record 150: 1 byte(s) readed - Ok Record 151: 1 byte(s) readed - Ok Record 152: 1 byte(s) readed - Ok Record 153: 1 byte(s) readed - Ok Record 154: 1 byte(s) readed - Ok Record 155: 1 byte(s) readed - Ok Record 156: 1 byte(s) readed - Ok Record 157: 1 byte(s) readed - Ok Record 158: 1 byte(s) readed - Ok Record 159: 2 byte(s) readed - Ok Record 160: 2 byte(s) readed - Ok Record 161: 1 byte(s) readed - Ok Record 162: 1 byte(s) readed - Ok Record 163: 1 byte(s) readed - Ok Record 164: 1 byte(s) readed - Ok Record 165: 1 byte(s) readed - Ok Record 166: 1 byte(s) readed - Ok Field [42] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [54] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 7 Record(s) Record 0: 21 byte(s) readed - Ok Record 1: 89 byte(s) readed - Ok Record 2: 69 byte(s) readed - Ok Record 3: 70 byte(s) readed - Ok Record 24: 88 byte(s) readed - Ok Record 25: 136 byte(s) readed - Ok Record 26: 12 byte(s) readed - Ok Field [116] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [117] 3 Record(s) Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 16: 62 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 944 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [163] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [218] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [238] 1 Record(s) Record 1: 1 byte(s) readed - Ok Field [239] 5 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 5089 byte(s) readed - Ok Record 2: 5089 byte(s) readed - Ok Record 3: 5089 byte(s) readed - Ok Record 4: 5089 byte(s) readed - Ok Field [301] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [308] 8 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 15 byte(s) readed - Ok Field [355] 1 Record(s) Record 0: 2886 byte(s) readed - Ok Field [364] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [365] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [373] 1 Record(s) Record 0: 44 byte(s) readed - Ok Field [374] 1 Record(s) Record 0: 4 byte(s) readed - Ok Field [383] 103 Record(s) Record 1: 256 byte(s) readed - Ok Record 3: 256 byte(s) readed - Ok Record 4: 256 byte(s) readed - Ok Record 5: 256 byte(s) readed - Ok Record 6: 256 byte(s) readed - Ok Record 7: 256 byte(s) readed - Ok Record 8: 256 byte(s) readed - Ok Record 9: 256 byte(s) readed - Ok Record 10: 256 byte(s) readed - Ok Record 11: 256 byte(s) readed - Ok Record 12: 256 byte(s) readed - Ok Record 13: 256 byte(s) readed - Ok Record 14: 256 byte(s) readed - Ok Record 15: 256 byte(s) readed - Ok Record 16: 256 byte(s) readed - Ok Record 17: 256 byte(s) readed - Ok Record 18: 256 byte(s) readed - Ok Record 19: 256 byte(s) readed - Ok Record 20: 256 byte(s) readed - Ok Record 21: 256 byte(s) readed - Ok Record 22: 256 byte(s) readed - Ok Record 23: 256 byte(s) readed - Ok Record 24: 256 byte(s) readed - Ok Record 25: 256 byte(s) readed - Ok Record 26: 256 byte(s) readed - Ok Record 27: 256 byte(s) readed - Ok Record 28: 256 byte(s) readed - Ok Record 29: 256 byte(s) readed - Ok Record 30: 256 byte(s) readed - Ok Record 31: 256 byte(s) readed - Ok Record 32: 256 byte(s) readed - Ok Record 33: 256 byte(s) readed - Ok Record 34: 256 byte(s) readed - Ok Record 35: 256 byte(s) readed - Ok Record 36: 256 byte(s) readed - Ok Record 37: 256 byte(s) readed - Ok Record 38: 256 byte(s) readed - Ok Record 39: 256 byte(s) readed - Ok Record 40: 256 byte(s) readed - Ok Record 41: 256 byte(s) readed - Ok Record 42: 256 byte(s) readed - Ok Record 43: 256 byte(s) readed - Ok Record 44: 256 byte(s) readed - Ok Record 45: 256 byte(s) readed - Ok Record 46: 256 byte(s) readed - Ok Record 47: 256 byte(s) readed - Ok Record 48: 256 byte(s) readed - Ok Record 49: 256 byte(s) readed - Ok Record 50: 256 byte(s) readed - Ok Record 51: 256 byte(s) readed - Ok Record 52: 256 byte(s) readed - Ok Record 53: 256 byte(s) readed - Ok Record 54: 256 byte(s) readed - Ok Record 55: 256 byte(s) readed - Ok Record 56: 256 byte(s) readed - Ok Record 57: 256 byte(s) readed - Ok Record 58: 256 byte(s) readed - Ok Record 59: 256 byte(s) readed - Ok Record 60: 256 byte(s) readed - Ok Record 61: 256 byte(s) readed - Ok Record 62: 256 byte(s) readed - Ok Record 63: 256 byte(s) readed - Ok Record 64: 256 byte(s) readed - Ok Record 65: 256 byte(s) readed - Ok Record 66: 256 byte(s) readed - Ok Record 67: 256 byte(s) readed - Ok Record 68: 256 byte(s) readed - Ok Record 69: 256 byte(s) readed - Ok Record 70: 256 byte(s) readed - Ok Record 71: 256 byte(s) readed - Ok Record 72: 256 byte(s) readed - Ok Record 73: 256 byte(s) readed - Ok Record 74: 256 byte(s) readed - Ok Record 75: 256 byte(s) readed - Ok Record 76: 256 byte(s) readed - Ok Record 77: 256 byte(s) readed - Ok Record 78: 256 byte(s) readed - Ok Record 79: 256 byte(s) readed - Ok Record 80: 256 byte(s) readed - Ok Record 81: 256 byte(s) readed - Ok Record 82: 256 byte(s) readed - Ok Record 83: 256 byte(s) readed - Ok Record 84: 256 byte(s) readed - Ok Record 85: 256 byte(s) readed - Ok Record 86: 256 byte(s) readed - Ok Record 87: 256 byte(s) readed - Ok Record 88: 256 byte(s) readed - Ok Record 89: 256 byte(s) readed - Ok Record 90: 256 byte(s) readed - Ok Record 91: 256 byte(s) readed - Ok Record 92: 256 byte(s) readed - Ok Record 93: 256 byte(s) readed - Ok Record 94: 256 byte(s) readed - Ok Record 95: 256 byte(s) readed - Ok Record 96: 256 byte(s) readed - Ok Record 97: 256 byte(s) readed - Ok Record 98: 256 byte(s) readed - Ok Record 99: 256 byte(s) readed - Ok Record 100: 256 byte(s) readed - Ok Record 101: 256 byte(s) readed - Ok Record 102: 256 byte(s) readed - Ok Record 103: 256 byte(s) readed - Ok Record 104: 256 byte(s) readed - Ok Field [390] 147 Record(s) Record 0: 256 byte(s) readed - Ok Record 1: 256 byte(s) readed - Ok Record 2: 256 byte(s) readed - Ok Record 3: 256 byte(s) readed - Ok Record 4: 256 byte(s) readed - Ok Record 5: 256 byte(s) readed - Ok Record 6: 256 byte(s) readed - Ok Record 7: 256 byte(s) readed - Ok Record 8: 256 byte(s) readed - Ok Record 9: 256 byte(s) readed - Ok Record 10: 256 byte(s) readed - Ok Record 11: 256 byte(s) readed - Ok Record 12: 256 byte(s) readed - Ok Record 13: 256 byte(s) readed - Ok Record 14: 256 byte(s) readed - Ok Record 15: 256 byte(s) readed - Ok Record 16: 256 byte(s) readed - Ok Record 17: 256 byte(s) readed - Ok Record 18: 256 byte(s) readed - Ok Record 19: 256 byte(s) readed - Ok Record 20: 256 byte(s) readed - Ok Record 21: 256 byte(s) readed - Ok Record 22: 256 byte(s) readed - Ok Record 23: 256 byte(s) readed - Ok Record 24: 256 byte(s) readed - Ok Record 25: 256 byte(s) readed - Ok Record 26: 256 byte(s) readed - Ok Record 27: 256 byte(s) readed - Ok Record 28: 256 byte(s) readed - Ok Record 29: 256 byte(s) readed - Ok Record 30: 256 byte(s) readed - Ok Record 31: 256 byte(s) readed - Ok Record 32: 256 byte(s) readed - Ok Record 33: 256 byte(s) readed - Ok Record 34: 256 byte(s) readed - Ok Record 35: 256 byte(s) readed - Ok Record 36: 256 byte(s) readed - Ok Record 37: 256 byte(s) readed - Ok Record 38: 256 byte(s) readed - Ok Record 39: 256 byte(s) readed - Ok Record 40: 256 byte(s) readed - Ok Record 41: 256 byte(s) readed - Ok Record 42: 256 byte(s) readed - Ok Record 43: 256 byte(s) readed - Ok Record 44: 256 byte(s) readed - Ok Record 45: 256 byte(s) readed - Ok Record 46: 256 byte(s) readed - Ok Record 47: 256 byte(s) readed - Ok Record 48: 256 byte(s) readed - Ok Record 49: 256 byte(s) readed - Ok Record 50: 256 byte(s) readed - Ok Record 51: 256 byte(s) readed - Ok Record 52: 256 byte(s) readed - Ok Record 53: 256 byte(s) readed - Ok Record 54: 256 byte(s) readed - Ok Record 55: 256 byte(s) readed - Ok Record 56: 256 byte(s) readed - Ok Record 57: 256 byte(s) readed - Ok Record 58: 256 byte(s) readed - Ok Record 59: 256 byte(s) readed - Ok Record 60: 256 byte(s) readed - Ok Record 61: 256 byte(s) readed - Ok Record 62: 256 byte(s) readed - Ok Record 63: 256 byte(s) readed - Ok Record 64: 256 byte(s) readed - Ok Record 65: 256 byte(s) readed - Ok Record 66: 256 byte(s) readed - Ok Record 67: 256 byte(s) readed - Ok Record 68: 256 byte(s) readed - Ok Record 69: 256 byte(s) readed - Ok Record 70: 256 byte(s) readed - Ok Record 71: 256 byte(s) readed - Ok Record 72: 256 byte(s) readed - Ok Record 73: 256 byte(s) readed - Ok Record 74: 256 byte(s) readed - Ok Record 75: 256 byte(s) readed - Ok Record 76: 256 byte(s) readed - Ok Record 77: 256 byte(s) readed - Ok Record 78: 256 byte(s) readed - Ok Record 79: 256 byte(s) readed - Ok Record 80: 256 byte(s) readed - Ok Record 81: 256 byte(s) readed - Ok Record 82: 256 byte(s) readed - Ok Record 83: 256 byte(s) readed - Ok Record 84: 256 byte(s) readed - Ok Record 85: 256 byte(s) readed - Ok Record 86: 256 byte(s) readed - Ok Record 87: 256 byte(s) readed - Ok Record 88: 256 byte(s) readed - Ok Record 89: 256 byte(s) readed - Ok Record 90: 256 byte(s) readed - Ok Record 91: 256 byte(s) readed - Ok Record 92: 256 byte(s) readed - Ok Record 93: 256 byte(s) readed - Ok Record 94: 256 byte(s) readed - Ok Record 95: 256 byte(s) readed - Ok Record 96: 256 byte(s) readed - Ok Record 97: 256 byte(s) readed - Ok Record 98: 256 byte(s) readed - Ok Record 99: 256 byte(s) readed - Ok Record 100: 256 byte(s) readed - Ok Record 101: 256 byte(s) readed - Ok Record 102: 256 byte(s) readed - Ok Record 103: 256 byte(s) readed - Ok Record 104: 256 byte(s) readed - Ok Record 105: 256 byte(s) readed - Ok Record 106: 256 byte(s) readed - Ok Record 107: 256 byte(s) readed - Ok Record 108: 256 byte(s) readed - Ok Record 109: 256 byte(s) readed - Ok Record 110: 256 byte(s) readed - Ok Record 111: 256 byte(s) readed - Ok Record 112: 256 byte(s) readed - Ok Record 113: 256 byte(s) readed - Ok Record 114: 256 byte(s) readed - Ok Record 115: 256 byte(s) readed - Ok Record 116: 256 byte(s) readed - Ok Record 117: 256 byte(s) readed - Ok Record 118: 256 byte(s) readed - Ok Record 119: 256 byte(s) readed - Ok Record 120: 256 byte(s) readed - Ok Record 121: 256 byte(s) readed - Ok Record 122: 256 byte(s) readed - Ok Record 123: 256 byte(s) readed - Ok Record 124: 256 byte(s) readed - Ok Record 125: 256 byte(s) readed - Ok Record 126: 256 byte(s) readed - Ok Record 127: 256 byte(s) readed - Ok Record 128: 256 byte(s) readed - Ok Record 129: 256 byte(s) readed - Ok Record 130: 256 byte(s) readed - Ok Record 131: 256 byte(s) readed - Ok Record 132: 256 byte(s) readed - Ok Record 133: 256 byte(s) readed - Ok Record 134: 256 byte(s) readed - Ok Record 135: 256 byte(s) readed - Ok Record 136: 256 byte(s) readed - Ok Record 137: 256 byte(s) readed - Ok Record 138: 256 byte(s) readed - Ok Record 139: 256 byte(s) readed - Ok Record 140: 256 byte(s) readed - Ok Record 141: 256 byte(s) readed - Ok Record 142: 256 byte(s) readed - Ok Record 143: 256 byte(s) readed - Ok Record 144: 256 byte(s) readed - Ok Record 145: 256 byte(s) readed - Ok Record 146: 256 byte(s) readed - Ok Field [391] 141 Record(s) Record 0: 256 byte(s) readed - Ok Record 2: 256 byte(s) readed - Ok Record 3: 256 byte(s) readed - Ok Record 4: 256 byte(s) readed - Ok Record 5: 256 byte(s) readed - Ok Record 6: 256 byte(s) readed - Ok Record 7: 256 byte(s) readed - Ok Record 8: 256 byte(s) readed - Ok Record 9: 256 byte(s) readed - Ok Record 10: 256 byte(s) readed - Ok Record 11: 256 byte(s) readed - Ok Record 12: 256 byte(s) readed - Ok Record 13: 256 byte(s) readed - Ok Record 14: 256 byte(s) readed - Ok Record 15: 256 byte(s) readed - Ok Record 16: 256 byte(s) readed - Ok Record 17: 256 byte(s) readed - Ok Record 18: 256 byte(s) readed - Ok Record 19: 256 byte(s) readed - Ok Record 20: 256 byte(s) readed - Ok Record 21: 256 byte(s) readed - Ok Record 22: 256 byte(s) readed - Ok Record 23: 256 byte(s) readed - Ok Record 24: 256 byte(s) readed - Ok Record 25: 256 byte(s) readed - Ok Record 26: 256 byte(s) readed - Ok Record 27: 256 byte(s) readed - Ok Record 28: 256 byte(s) readed - Ok Record 29: 256 byte(s) readed - Ok Record 30: 256 byte(s) readed - Ok Record 31: 256 byte(s) readed - Ok Record 32: 256 byte(s) readed - Ok Record 33: 256 byte(s) readed - Ok Record 34: 256 byte(s) readed - Ok Record 35: 256 byte(s) readed - Ok Record 36: 256 byte(s) readed - Ok Record 37: 256 byte(s) readed - Ok Record 38: 256 byte(s) readed - Ok Record 39: 256 byte(s) readed - Ok Record 40: 256 byte(s) readed - Ok Record 41: 256 byte(s) readed - Ok Record 42: 256 byte(s) readed - Ok Record 43: 256 byte(s) readed - Ok Record 44: 256 byte(s) readed - Ok Record 45: 256 byte(s) readed - Ok Record 46: 256 byte(s) readed - Ok Record 47: 256 byte(s) readed - Ok Record 48: 256 byte(s) readed - Ok Record 49: 256 byte(s) readed - Ok Record 50: 256 byte(s) readed - Ok Record 51: 256 byte(s) readed - Ok Record 52: 256 byte(s) readed - Ok Record 53: 256 byte(s) readed - Ok Record 54: 256 byte(s) readed - Ok Record 55: 256 byte(s) readed - Ok Record 56: 256 byte(s) readed - Ok Record 57: 256 byte(s) readed - Ok Record 58: 256 byte(s) readed - Ok Record 59: 256 byte(s) readed - Ok Record 60: 256 byte(s) readed - Ok Record 61: 256 byte(s) readed - Ok Record 62: 256 byte(s) readed - Ok Record 63: 256 byte(s) readed - Ok Record 64: 256 byte(s) readed - Ok Record 65: 256 byte(s) readed - Ok Record 66: 256 byte(s) readed - Ok Record 67: 256 byte(s) readed - Ok Record 68: 256 byte(s) readed - Ok Record 69: 256 byte(s) readed - Ok Record 70: 256 byte(s) readed - Ok Record 71: 256 byte(s) readed - Ok Record 72: 256 byte(s) readed - Ok Record 73: 256 byte(s) readed - Ok Record 74: 256 byte(s) readed - Ok Record 75: 256 byte(s) readed - Ok Record 76: 256 byte(s) readed - Ok Record 77: 256 byte(s) readed - Ok Record 78: 256 byte(s) readed - Ok Record 79: 256 byte(s) readed - Ok Record 80: 256 byte(s) readed - Ok Record 81: 256 byte(s) readed - Ok Record 82: 256 byte(s) readed - Ok Record 83: 256 byte(s) readed - Ok Record 84: 256 byte(s) readed - Ok Record 85: 256 byte(s) readed - Ok Record 86: 256 byte(s) readed - Ok Record 87: 256 byte(s) readed - Ok Record 88: 256 byte(s) readed - Ok Record 89: 256 byte(s) readed - Ok Record 90: 256 byte(s) readed - Ok Record 91: 256 byte(s) readed - Ok Record 92: 256 byte(s) readed - Ok Record 93: 256 byte(s) readed - Ok Record 94: 256 byte(s) readed - Ok Record 95: 256 byte(s) readed - Ok Record 96: 256 byte(s) readed - Ok Record 97: 256 byte(s) readed - Ok Record 98: 256 byte(s) readed - Ok Record 99: 256 byte(s) readed - Ok Record 100: 256 byte(s) readed - Ok Record 101: 256 byte(s) readed - Ok Record 102: 256 byte(s) readed - Ok Record 103: 256 byte(s) readed - Ok Record 104: 256 byte(s) readed - Ok Record 105: 256 byte(s) readed - Ok Record 106: 256 byte(s) readed - Ok Record 107: 256 byte(s) readed - Ok Record 108: 256 byte(s) readed - Ok Record 109: 256 byte(s) readed - Ok Record 110: 256 byte(s) readed - Ok Record 111: 256 byte(s) readed - Ok Record 112: 256 byte(s) readed - Ok Record 113: 256 byte(s) readed - Ok Record 114: 256 byte(s) readed - Ok Record 115: 256 byte(s) readed - Ok Record 116: 256 byte(s) readed - Ok Record 117: 256 byte(s) readed - Ok Record 118: 256 byte(s) readed - Ok Record 119: 256 byte(s) readed - Ok Record 120: 256 byte(s) readed - Ok Record 121: 256 byte(s) readed - Ok Record 122: 256 byte(s) readed - Ok Record 123: 256 byte(s) readed - Ok Record 124: 256 byte(s) readed - Ok Record 125: 256 byte(s) readed - Ok Record 126: 256 byte(s) readed - Ok Record 127: 256 byte(s) readed - Ok Record 128: 256 byte(s) readed - Ok Record 129: 256 byte(s) readed - Ok Record 130: 256 byte(s) readed - Ok Record 131: 256 byte(s) readed - Ok Record 132: 256 byte(s) readed - Ok Record 133: 256 byte(s) readed - Ok Record 134: 256 byte(s) readed - Ok Record 135: 256 byte(s) readed - Ok Record 136: 256 byte(s) readed - Ok Record 137: 256 byte(s) readed - Ok Record 138: 256 byte(s) readed - Ok Record 139: 256 byte(s) readed - Ok Record 140: 256 byte(s) readed - Ok Record 141: 256 byte(s) readed - Ok Saved as D:\Infinitybox\BEST\Backup\RM-607 C1-01_351662057363956_0_400.pm Done! Elapsed: 00:00:07 Core : v1.50 , FlashEngine : v1.7 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__04.40.mcusw PPM : rm607__04.40.ppm_ml CNT : rm607__04.40.image_ml_0595605 Flashing phone now... Check files done... -> Check SW version... FlashFile version : 04.40 Phone version : 05.45 22-06-11 RM-607 (c) Nokia -> Check SW version : Downgrade try -> Downgrade enabled by user request Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... ok Reboot.... Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_2.3_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 351662057363956 PCcode : 0596377 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... RPL saved : D:\Infinitybox\BEST\Backup\Cert\351662057363956_XG213.rpl ===Flashing [MCU]=== File : rm607__04.40.mcusw Image : rm607__04.40.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:49 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:35 ===Flashing [PPM]=== File : rm607__04.40.ppm_ml Image : package_ml.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:07 Write , Start : 0x41C00000 , Len : 0x0031B6D8 Flashing , wait ... Region flash done, time : 00:00:03 ===Flashing [CNT]=== File : rm607__04.40.image_ml_0595605 Image : package_ml_0595605.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:06 Write , Start : 0x42200000 , Len : 0x00C20000 Flashing , wait ... Region flash done, time : 00:00:16 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip Flashing done! Total flash time : 00:03:07 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 04.40 23-02-11 RM-607 (c) Nokia IMEI: 351662057363956 PPM version : V 04.40 23-02-11 RM-607 (c) Nokia ML Product code: 0596377 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:09 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - C1-01 Software ver : V 04.40 23-02-11 RM-607 (c) Nokia IMEI : 351662057363956 PPM : V 04.40 23-02-11 RM-607 (c) Nokia ML CNT : Content: ml_0595605 V 04.40 23-02-11 RM-607 (c) Nokia Product SN : F613C50AI Product code : 0596377 Base Prd.code: 0585582 Module code : 0204427 Long Prod.SN : 0 Hardware info======= HWID : 2001 Batery: 3853 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 351662057363956 IMEI spNet : 3A 15 66 02 75 63 93 05 IMEI svNet : 33 15 66 02 75 63 93 15 F1 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : AECE3942E8A41BA9 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created INFINEON : SuperDongle not exist (It is Ok) SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to mbiborna For This Useful Post: |
08-23-2012, 15:03 | #16828 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd : Custom 2nd boot Ok, 01 2nd ready, AA Sending Algo ALG : Custom Algo sent Ok BL : Quantum_Bootloader_2.5_M1S1 Boot done! Reading CCC Reading HWC Reading NPC IMEI : 357913042958580 PCcode : 059G896 SL3 Simlock read (XGOLD) ... ok NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.51\Backup\Cert\35 7913042958580_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading User code... User Code is: 45800 Done! Resetting User Code to default (12345)... Clear data : Ok Result: 12345 Done! |
08-23-2012, 15:27 | #16829 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | card found: S/N C0B4:0118 registered to: Akramjon Connect phone on selected interface... Core : v1.50 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm640__07.15.mcusw PPM : rm640__07.15.ppm_i CNT : rm640__07.15.image_i_0599369_008 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 10700108A09C0344E9DCF2978C838099EDDC099E ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00300098 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 5AA09885C97BF3B0F6783A6337506F9394F346EF ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358299045256837 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\InfinityBox\BEST\Backup\Cert\358299045256837_CR T.rpl ===Flashing [MCU]=== Erase : Processing rm640__07.15.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm640__07.15.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 264 blocks TIME : Write time : 00:00:04 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm640__07.15.ppm_i Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm640__07.15.ppm_i Total writen 62 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm640__07.15.image_i_0599369_008 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing rm640__07.15.image_i_0599369_008 Total writen 294 blocks TIME : Write time : 00:00:05 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:16 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C3-01 Software Info: V 07.15 07-10-11 RM-640 (c) Nokia IMEI: 358299045256837 PPM version : V 07.15 07-10-11 RM-640 (c) Nokia I Product code: 0599538 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... Error When resetting FullFactory ... Error When setting User Data defaults ... Error When resetting Product Tune ... Error When resetting SW upgrade Default ... AfterFlash operations done ;D Done! Elapsed: 00:01:23 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-23-2012, 15:28 | #16830 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | card found: S/N C0B4:0118 registered to: Akramjon Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600000001020C192102054100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 2870020D3CFF5540BFDD0552DBD123C83111BD63 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 108AF4DB7EC8B1B36E9D6A60F7EB2996DC7B2B5D ADL: Reading certificates... Reading NPC certificate... IMEI : 356235045372739 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! ADL: Reading certificates done! ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... Swap data collected to 0593956.pc RPL saved : D:\InfinityBox\BEST\Backup\Cert\356235045372739.rp l All done, Disconnecting Elapsed: 00:00:21 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v1.50 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm638__10.80.mcusw PPM : rm638__10.80.ppm_e CNT : rm638__10.80.image_e_0593988_010 Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600000001020C192102054100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 2870020D3CFF5540BFDD0552DBD123C83111BD63 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 108AF4DB7EC8B1B36E9D6A60F7EB2996DC7B2B5D ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 356235045372739 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox\BEST\Backup\Cert\356235045372739_2n d.rpl ===Flashing [MCU]=== Erase : Processing rm638__10.80.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm638__10.80.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 126 blocks TIME : Write time : 00:00:32 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm638__10.80.ppm_e Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm638__10.80.ppm_e Total writen 25 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm638__10.80.image_e_0593988_010 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm638__10.80.image_e_0593988_010 Total writen 97 blocks TIME : Write time : 00:00:29 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:01:11 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303i classic Software Info: V 10.80 21-01-11 RM-638 (c) Nokia IMEI: 356235045372739 PPM version : V 10.80 21-01-11 RM-638 (c) Nokia E Product code: 0593956 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:36 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
