07-04-2014, 13:17 | #19532 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | registered to: sirnavid nokia x rm -980 flash done!!!!!!!! Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 3DB0D66D Processing : RM980_1.1.2.2_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_1.1.2.2_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_1.1.2.2_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.1.2.2_059T9F2_IMEA_EG_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:03:16 Reboot phone Ok Connect phone on selected interface... |
The Following User Says Thank You to sirnavid2010 For This Useful Post: |
07-05-2014, 06:43 | #19533 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung b219 unlock COM6 [sscdserd0] selected module v2.04 Device: Samsung-SCH-B219 operation: SP-unlock Phone should be Switched ON ! connecting... checking Force mode... Force mode detected... patching in progress.. patching in progress 50%... patching in progress 100%... done... Finished, time used: 9 sec |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
07-06-2014, 11:16 | #19534 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: Live pakistan Age: 46
Member: 1054358 Status: Offline Sonork: 100.1626312 Thanks Meter: 269 | Nokia Asha 200 Rm-761 Flash Done With infinity Best Dongle Quote:
07-06-2014, 11:25 | #19535 (permalink) |
Member: 1054358 Status: Offline Sonork: 100.1626312 Thanks Meter: 269 | Nokia Asha 200 Rm-761 Flash Done Code: card found: S/N +++++++ registered to: umardarz Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm761__12.04.mcusw PPM : rm761__12.04.ppm_mh1 CNT : rm761__12.04.image_mh1_059J5T0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 35+++++++++++ IMEI 2 : 35+++++++++++ PCcode : 059N799 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355+++++++++_XG213 _CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm761__12.04.mcusw Image : rm761__12.04.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:19 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:34 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x6D3B ===Flashing [PPM]=== File : rm761__12.04.ppm_mh1 Image : package_mh1.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00740000 Erasing, wait ... Erase done, time : 00:00:29 Write , Start : 0x41A80000 , Len : 0x005E52FC Flashing , wait ... Region flash done, time : 00:00:07 CRC check passed , 0xDE94 ===Flashing [CNT]=== File : rm761__12.04.image_mh1_059J5T0 Image : package_mh1_059J5T0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:27 Write , Start : 0x421C0000 , Len : 0x01120000 Flashing , wait ... Region flash done, time : 00:00:28 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x0D59 Flashing done! Total flash time : 00:08:43 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 200 Software Info: V 12.04 20-05-13 RM-761 (c) Nokia IMEI: 355+++++++++ PPM version : V 12.04 20-05-13 RM-761 (c) Nokia MH1 Product code: 059N799 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:57 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
07-08-2014, 08:42 | #19536 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | Nokia 220 Phone Lock Done With infinity Best Dongle Thank,s Hard worker and World first solution provider team Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 7 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : ED472CEC4A59E1719F36B6B9915BF615 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Data prepared! First Step Done, Now Re-connect power/cable! Wait for phone... Phone found! [ 7 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : ED472CEC4A59E1719F36B6B9915BF615 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 Code set to default : 12345 Done! |
07-09-2014, 10:05 | #19537 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 225 Reset User Code Done:)(without lost data) Code: Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 290 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 2C8058A7A5524853974793D30937BEE4 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.01.11 00-00-00 RM-1011 IMEI 1 : 352353061046220 IMEI 2 : 352353061046238 XappVer : 00000780 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IJ CNT : PEARL.10.01.11.p3 Product SN : 5B46D5EBH Product code : 059V5V2 Base Prd.code: 059V3X9 Module code : 0206023 Hardware info======= HWID : 1000 LCDVer: TPO Lock info =========== IMEI : 352353061046220 IMEI spNet : 3A 25 53 03 16 40 26 02 Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
07-09-2014, 10:07 | #19538 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | E63 Flash Done :) Code: Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm437_510.21.010_prd.c00 PPM : rm437_510.21.010_prd.v42 CNT : rm437_510.21.010.55U APE : sofie_erase_y_drive.fpsx CNT3 : RM437_ENO_008.07.45_100.71.952.a018.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> Check SW version... FlashFile version : 510.21.010 Phone version : 510.21.010 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\Flashing Softwares\12+Best dongle\InfinityBox\BEST\Backup\Cert\351502049218621_SIM.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0C10010D0B878E52F508E417492CCD99CB48C986 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! :) TIME : Boot time : 00:00:31 Reopening the connection... Waiting for response: 30 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm437_510.21.010_prd.c00 Found 3 areas to erase Erasing area 0x00040000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00A00000 - 0x0759FFFF, NAND, CMT Result: 0000 Erasing area 0x0F1C0000 - 0x0F8BFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partition erase not allowed by loader Partition erase not allowed by loader Partitioning : Ok [7] TIME : Erase time : 00:00:00 Write : Processing rm437_510.21.010_prd.c00 Total 533 [533/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:22 MCU Write done ===Flashing [PPM]=== Erase : Processing rm437_510.21.010_prd.v42 Found 1 areas to erase Erasing area 0x05420000 - 0x0759FFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm437_510.21.010_prd.v42 Total 211 [211/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:34 PPM Write done ===Flashing [CNT]=== Erase : Processing rm437_510.21.010.55U Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm437_510.21.010.55U Total 171 [171/0/0] blocks to write, writing... TIME : Write time : 00:00:28 CNT Write done ===Flashing [APE]=== Erase : Processing sofie_erase_y_drive.fpsx Found 1 areas to erase Erasing area 0x0F020000 - 0x0F1BFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing sofie_erase_y_drive.fpsx No any data for write, skip write APE Write done ===Flashing [CNT3]=== Erase : Processing RM437_ENO_008.07.45_100.71.952.a018.fpsx TIME : Erase time : 00:00:00 Write : Processing RM437_ENO_008.07.45_100.71.952.a018.fpsx Total 16 [16/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:02:28 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E63 Software Info: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia IMEI: 351502049218621 Ape Version: 510.21.010 Product code: 0569943 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:03:28 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
07-09-2014, 10:11 | #19539 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | 105 Flash Done :) Code: Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm908_02.700 PPM : rm908_02.70ij CNT : rm908_nai02.70ij Infineon flashing... -> Infineon XG110 : IMEI Backup Created Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH VEN : 000000EF FLASH DIE : 00006017 FLASH ID : UNKNOW [Not In Base] Boot Done! ===Flashing [MCU]=== File : rm908_02.700 Image : hw_b1_rm908_02.700.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x00221240 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : A59F ===Flashing [PPM]=== File : rm908_02.70ij Image : hw_b1_rm908_02.70ij.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x0018A340 Flashing , wait ... Region flash done Check : 96E9 ===Flashing [CNT]=== File : rm908_nai02.70ij Image : hw_b1_rm908_nai02.70ij.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x000661C0 Flashing , wait ... Region flash done Check : A3FD Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 02.70 22-02-13 RM-908 (c) Nokia IMEI : 358134055111459 PCode : 059R449 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! Connect phone on selected interface... |
07-09-2014, 12:49 | #19540 (permalink) |
Member: 1054358 Status: Offline Sonork: 100.1626312 Thanks Meter: 269 | nokia 301 RM-839 FLASH DONE Code: Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 355516059137725 IMEI 2 : 355516059137733 Phone Product Code : 059T111 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355516059137725_XG618_CRT.rpl ===Flashing [MCU]=== Processing file : rm839__02.33.mcusw Region count : 8 00 : [ PSI ] : psi_flash_unsigned.fls 01 : [ BCore ] : slb_signed.fls 02 : [ Code ] : main_toc_signed.fls 03 : [ Code ] : rm839__02.33.mcusw_signed_mcusw.fls 04 : [ Code ] : swap_signed.fls 05 : [ Cust ] : dynsw.fls 06 : [ Code ] : aeneas_signed.fls 07 : [ Code ] : fota_signed.fls Parse done , flashing now Flash : 00 : psi_flash_unsigned.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x00090000 , Len : 0x00020000 Erase now... Erase done Region Start : 0x00090000 , Data Len : 0x00010FB0 Region Load done Write done psi_flash_unsigned.fls image flash done Flash : 01 : slb_signed.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60000000 , Len : 0x00040000 Erase now... Erase done Region Start : 0x60000000 , Data Len : 0x00040000 Region Load done Write done slb_signed.fls image flash done Flash : 02 : main_toc_signed.fls Sending Sec-Pack SecInfo Area : 0x0002 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60040000 , Len : 0x00000400 Erase now... Erase done Region Start : 0x60040000 , Data Len : 0x00000400 Region Load done Write done main_toc_signed.fls image flash done Flash : 03 : rm839__02.33.mcusw_signed_mcusw.fls Sending Sec-Pack SecInfo Area : 0x0003 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000 Erase now... Erase done Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000 Erase now... Erase done Region Start : 0x62E00000 , Data Len : 0x00F05210 Region Load done Write done rm839__02.33.mcusw_signed_mcusw.fls image flash done Flash : 04 : swap_signed.fls Sending Sec-Pack SecInfo Area : 0x0004 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000 Erase now... Erase done Region Start : 0x80000000 , Data Len : 0x00C1B3CC Region Load done Write done swap_signed.fls image flash done Flash : 05 : dynsw.fls Sending Sec-Pack SecInfo Area : 0x0005 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62080000 , Len : 0x00100000 Erase now... Erase done Region Start : 0x62080000 , Data Len : 0x00044000 Region Load done Write done dynsw.fls image flash done Flash : 06 : aeneas_signed.fls Sending Sec-Pack SecInfo Area : 0x0006 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000 Erase now... Erase done Region Start : 0x63F79C00 , Data Len : 0x00046870 Region Load done Write done aeneas_signed.fls image flash done Flash : 07 : fota_signed.fls Sending Sec-Pack SecInfo Area : 0x0007 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC Erase now... Erase done Region Start : 0x61F00004 , Data Len : 0x00145478 Region Load done Write done fota_signed.fls image flash done ===Flashing [PPM]=== Processing file : rm839__02.33.ppm_m2 Region count : 1 00 : [ Cust ] : package_m2.ppm_ebl_psi.fls Parse done , flashing now Flash : 00 : package_m2.ppm_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000 Erase now... Erase done Region Start : 0x80F00000 , Data Len : 0x00520D30 Region Load done Write done package_m2.ppm_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm839__02.33.image_m2_059Q9B5 Region count : 1 00 : [ Cust ] : package_m2_059Q9B5.image.fls Parse done , flashing now Flash : 00 : package_m2_059Q9B5.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000 Erase now... Erase done Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000 Erase now... Erase done Region Start : 0xA1000000 , Data Len : 0x0193FA00 Region Load done Write done package_m2_059Q9B5.image.fls image flash done Flashing done! Total flash time : 00:00:13 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 301 Dual SIM Software Info: V 02.33 17-05-13 RM-839 (c) Nokia IMEI: 355516059137725 PPM version : V 02.33 17-05-13 RM-839 (c) Nokia M2 Product code: 059T111 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:00:54 Connect phone on selected interface... Last edited by umardarz; 07-09-2014 at 12:58. |
The Following User Says Thank You to umardarz For This Useful Post: |
07-09-2014, 19:36 | #19541 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 364299 Status: Offline Thanks Meter: 53 | tody i flashe samsung e1282T with infinity test softwar spd this phone dead after i formated it with dragon and i try to flashe it with volcano but always cant problem of driver and and and ..... with infinity with filashe file of volcano i flashed it in the first try first try and solry for the log info good work infinity team |
07-10-2014, 05:51 | #19542 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,425 | Nokia E5 Flashing Done ;) Code: Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm632_102.002_prd.core.fpsx PPM : rm632_102.002_27.01_MEA_A_prd.rofs2.fpsx PPM2 : rm632_102.002_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm632_102.002_U010.000_prd.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: 1A10010AD5DE03444507E40DD3779F08617FD96E ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 351663059318659 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351663059318659_CRT.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm632_102.002_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_102.002_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 433 blocks TIME : Write time : 00:00:15 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm632_102.002_27.01_MEA_A_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_102.002_27.01_MEA_A_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 221 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm632_102.002_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_102.002_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 35 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm632_102.002_U010.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_102.002_U010.000_prd.uda.fpsx Total writen 97 blocks TIME : Write time : 00:00:05 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:39 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E5-00 Software Info: V ICPR82_11w16.3.14 16-11-12 RM-632 (c) Nokia IMEI: 351663059318659 Ape Version: 102.002 Product code: 059H8G2 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:52 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
07-10-2014, 12:59 | #19543 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
07-11-2014, 11:21 | #19544 (permalink) |
No Life Poster Join Date: Nov 2005 Location: india Age: 45
Member: 201107 Status: Offline Sonork: 100.1576954 Thanks Meter: 737 | NOKIA N900 MEAMOO FLASHING DONE Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2101 NOLO : 01/0E/14 SWVer: RX-51_2009SE_3.2010.02-8.206.6_PR_206 Device mode : Production mode ========== FW APE version : 3.2010.02-8.206.6 FW PRx release : PR_1.1.1 FW Region info : BRANDED TO CARRIER FW Region ver : 206 ========== Read info Ok Reset all flags... Reset Done Check : Processing RX-51_2009SE_3.2010.02-8.206.6_PR_LEGACY_206_ARM.bin ========== FW APE version : 3.2010.02-8.206.6 FW CMT version : rx51_ICPR82_09w47 FW PRx release : PR_1.1.1 FW Region info : BRANDED TO CARRIER FW Region ver : 206 KERNEL version : 2.6.28-20094803.3+0m5 ========== Check : File Is Ok ! Core : v1.86 , Tablet FlashEngine : v5.2 Press and hold "U" button and insert cable! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2101 NOLO : 01/0E/14 SWVer: RX-51_2009SE_3.2010.02-8.206.6_PR_206 Device mode : Production mode ========== FW APE version : 3.2010.02-8.206.6 FW PRx release : PR_1.1.1 FW Region info : BRANDED TO CARRIER FW Region ver : 206 ========== Read info Ok === SW version Check ==== Skipped!!! Reason : empty initial data ( IF YOU FLASH eMMC ONLY - SKIP this!) === SW version Check ==== ---Processing MCU image--- Processing NOL part File : RX-51_2009SE_3.2010.02-8.206.6_PR_LEGACY_206_ARM.bin Processing : xloader , 1.4.14.4.4+0m5 Processing : secondary , 1.4.14.4.4+0m5 NOL part Ok, boot flash done Processing APE part File : RX-51_2009SE_3.2010.02-8.206.6_PR_LEGACY_206_ARM.bin Processing : kernel , 2.6.28-20094803.3+0m5 Kernel flash Ok Processing APE part File : RX-51_2009SE_3.2010.02-8.206.6_PR_LEGACY_206_ARM.bin Processing : rootfs , RX-51_2009SE_3.2010.02-8.206.6_PR_206 RootFs flash Ok Processing CMT part File : RX-51_2009SE_3.2010.02-8.206.6_PR_LEGACY_206_ARM.bin Processing : cmt-2nd , BB5_09.36 Processing : cmt-algo , BB5_09.36 Processing : cmt-mcusw , rx51_ICPR82_09w47 CMT part prepare Ok, files are sent Program CMT request Ok Switch : OSSO UART+USB Version : RX-51_2009SE_3.2010.02-8.206.6_PR_206 Switch CMT request Ok CMT : Erasing... CMT : Program... CMT : Program Finished! Executing PostFlash : Reset RD Flags Executing PostFlash : Reboot Done! Elapsed: 00:01:43 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok B.R. kalpesh varia |
The Following User Says Thank You to PARMATMA For This Useful Post: |
07-12-2014, 08:36 | #19545 (permalink) |
Member: 1054358 Status: Offline Sonork: 100.1626312 Thanks Meter: 269 | asha 308 contect servic done Code: card found: S/N 3323:0118 registered to: umardarz Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm834__20.52.mcusw PPM : rm834__20.52.ppm_m_a CNT : rm834__20.52.image_m_a_059M6C0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- -> Phone not found.. :( Elapsed: 00:00:29 Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm834__20.52.mcusw PPM : rm834__20.52.ppm_m_a CNT : rm834__20.52.image_m_a_059M6C0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- -> Phone not found.. :( Elapsed: 00:00:29 Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm834__20.52.mcusw PPM : rm834__20.52.ppm_m_a CNT : rm834__20.52.image_m_a_059M6C0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- -> Phone not found.. :( Elapsed: 00:00:29 Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm834__20.52.mcusw PPM : rm834__20.52.ppm_m_a CNT : rm834__20.52.image_m_a_059M6C0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- -> Phone not found.. :( Elapsed: 00:00:29 Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm834__20.52.mcusw PPM : rm834__20.52.ppm_m_a CNT : rm834__20.52.image_m_a_059M6C0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- -> Phone not found.. :( Elapsed: 00:00:29 Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm834__20.52.mcusw PPM : rm834__20.52.ppm_m_a CNT : rm834__20.52.image_m_a_059M6C0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- -> Phone not found.. :( Elapsed: 00:00:29 Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm834__20.52.mcusw PPM : rm834__20.52.ppm_m_a CNT : rm834__20.52.image_m_a_059M6C0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- -> Phone not found.. :( Elapsed: 00:00:29 Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm834__20.52.mcusw PPM : rm834__20.52.ppm_m_a CNT : rm834__20.52.image_m_a_059M6C0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.47_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 351668054495980 IMEI 2 : 351668054495998 PCcode : 059N1K5 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351668054495980_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm834__20.52.mcusw Image : rm834__20.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:00:55 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Region flash done, time : 00:00:37 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xD2A9 ===Flashing [PPM]=== File : rm834__20.52.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:09 Write , Start : 0x41DC0000 , Len : 0x0041B6E4 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xBBFE ===Flashing [CNT]=== File : rm834__20.52.image_m_a_059M6C0 Image : package_m_a_059M6C0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:01:00 Write , Start : 0x424C0000 , Len : 0x00CC0000 Flashing , wait ... Region flash done, time : 00:00:16 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xC996 Flashing done! Total flash time : 00:03:10 Reboot phone now... - > AfterFlash Failed! :( Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Connect phone on selected interface... Elapsed: 00:05:18 Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -------BOOT BREAKED BY USER------- -> Phone not found.. :( Looks like ASIC not supported, or HW failure Supported : RapuYamaVx, RAP3Gv4, BroadComm, RAPIDO, XG213, XG221, XG223, XG618 Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- -> Phone not found.. :( -> Error while booting phone... -> If it NOT XG213/XG618/XG221 phone - Uncheck this option! Reading failed... Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== MMC password not found (not set) NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351668054495980_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - 202 Software ver : V 20.52 27-09-12 RM-834 (c) Nokia IMEI 1 : 351668054495980 IMEI 2 : 351668054495998 XappVer : 00000780 PPM : V 20.52 27-09-12 RM-834 (c) Nokia M_A CNT : Content: m_a_059M6C0 V 20.52 27-09-12 RM-834 (c) Nokia Product SN : 8CDC8FDAH Product code : 059N1K5 Base Prd.code: 059N243 Module code : 0205125 Long Prod.SN : 0 Hardware info======= HWID : 1000 Batery: 4084 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 351668054495980 IMEI spNet : 3A 15 66 08 45 94 95 08 IMEI svNet : 33 15 66 08 45 94 95 18 F4 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 1984CD32FD826B5A Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:08 Phone disconected! Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual File [Ok] : rm838__05.85.mcusw File [Ok] : rm838__05.85.ppm_maa File [Ok] : rm838__05.85.image_maa_059N857 Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049922209A23A105892140800 ASIC ID_E : 00000C2016100040 PUBLIC ID : 40DCB2EDD204B3D649922209A23A105892140800 XGCHIP ID : 40DCB2EDD204B3D6 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Error send Algo Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual File [Ok] : rm838__05.85.mcusw File [Ok] : rm838__05.85.ppm_maa File [Ok] : rm838__05.85.image_maa_059N857 Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049922209A23A105892140800 ASIC ID_E : 00000C2016100040 PUBLIC ID : 40DCB2EDD204B3D649922209A23A105892140800 XGCHIP ID : 40DCB2EDD204B3D6 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 351668054495980 IMEI [2] : 351668054495998 RPL saved : C:\InfinityBox\BEST\Backup\Cert\351668054495980_XG223_SIM.rpl PAPUBkeys : blank (Erased or HW failure) === SW Version Check === - > Can not collect initial info, continue flashing... - > Hope, this version will be ok === SW Version Check === === Flashing MCU === Processing file : rm838__05.85.mcusw Erasing... Writing... Total blocks : 95 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : FAF910DA218D8536CEFBDCE369A8C034160C6A5F] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 94 blocks were writen === Flashing PPM === Processing file : rm838__05.85.ppm_maa Erasing... Writing... Total blocks : 12 File processed Ok, 12 blocks were writen === Flashing CNT === Processing file : rm838__05.85.image_maa_059N857 Erasing... Writing... Total blocks : 82 File processed Ok, 82 blocks were writen Flashing done , total time : 00:00:49 Reboot phone to service mode... Reading Phone Info.... Connected phone - Nokia 308 Software Info: V 05.85 23-10-12 RM-838 (c) Nokia IMEI: 355217050219527 PPM version : V 05.85 23-10-12 RM-838 (c) Nokia MAA Product code: 059N7W1 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 43 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Connect phone on selected interface... |
The Following 2 Users Say Thank You to umardarz For This Useful Post: |
