10-09-2014, 16:18 | #19876 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | Nokia 220 Flashing done via BEST TOOL Code: Connect phone on selected interface... Core : v1.97 , MTKx FlashEngine : v5.0 Verify files ... MAUI : RM-969_ROM_eMP_13.00.11 VIVA : RM-969_VIVA_eMP_13.00.11 LANG : RM-969_LANG_PACK_ROM_EI_eMP_13.00.11 CUST : RM-969_CUSTPACK_ROM_EI_EURO_RU_eMP_13.00.11 JMPT : RM-969_JUMP_TABLE_EI_EURO_RU_eMP_13.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 36 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : CE7E3B91F5C4D27E79298BC25BAE9C4C BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_13.00.11 SecureDecrypt : RM-969_VIVA_eMP_13.00.11 SecureDecrypt : RM-969_LANG_PACK_ROM_EI_eMP_13.00.11 SecureDecrypt : RM-969_CUSTPACK_ROM_EI_EURO_RU_eMP_13.00.11 SecureDecrypt : RM-969_JUMP_TABLE_EI_EURO_RU_eMP_13.00.11 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 OVRLP : 00004DF900000001 [ERROR] : DA_CBR_NOT_FOUND DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_13.00.11 Write : RM-969_LANG_PACK_ROM_EI_eMP_13.00.11 Write : RM-969_CUSTPACK_ROM_EI_EURO_RU_eMP_13.00.11 Write : RM-969_JUMP_TABLE_EI_EURO_RU_eMP_13.00.11 Write : RM-969_VIVA_eMP_13.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-969_ROM_eMP_13.00.11 [VERIFY] DONE : RM-969_LANG_PACK_ROM_EI_eMP_13.00.11 [VERIFY] DONE : RM-969_CUSTPACK_ROM_EI_EURO_RU_eMP_13.00.11 [VERIFY] DONE : RM-969_JUMP_TABLE_EI_EURO_RU_eMP_13.00.11 [VERIFY] DONE : RM-969_VIVA_eMP_13.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:45 Reboot phone Ok |
The Following User Says Thank You to UzUnlocker For This Useful Post: |
10-09-2014, 16:25 | #19877 (permalink) | |
Member: 1043909 Status: Online Thanks Meter: 60,933 | Quote:
Thanks a lot, but I can not download firmware file well. shared.com always push me to download some kind of downloader.exe instead of firmware file | |
10-09-2014, 17:29 | #19878 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Bulawayo zimbabwe
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Nokia x dual sim flashed card found: S/N 86D4:0122 registered to: onelemutero Connect phone on selected interface... Core : v1.97 , NXP FlashEngine : v3.4 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_11.1.1_059T9F6_IMEA_SA_variant.img Ok, Set : RM980_11.1.1_boot.img Ok, Set : RM980_11.1.1_cache.img Ok, Set : RM980_11.1.1_emmc_appsboot.mbn Ok, Set : RM980_11.1.1_emmc_appsboothd.mbn Ok, Set : RM980_11.1.1_fat.bin Ok, Set : RM980_11.1.1_oemsbl.mbn Ok, Set : RM980_11.1.1_oemsblhd.mbn Ok, Set : RM980_11.1.1_persist.img Ok, Set : RM980_11.1.1_preload.img Ok, Set : RM980_11.1.1_qcsbl.mbn Ok, Set : RM980_11.1.1_qcsblhd_cfgdata.mbn Ok, Set : RM980_11.1.1_recovery.img Ok, Set : RM980_11.1.1_system.img Ok, Set : RM980_11.1.1_udisk.bin Ok, Set : RM980_11.1.1_userdata.img File HW revision is : HW Revision V1 Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Or 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v1.97 , NXP FlashEngine : v3.4 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_11.1.1_059T9F6_IMEA_SA_variant.img Ok, Set : RM980_11.1.1_boot.img Ok, Set : RM980_11.1.1_cache.img Ok, Set : RM980_11.1.1_emmc_appsboot.mbn Ok, Set : RM980_11.1.1_emmc_appsboothd.mbn Ok, Set : RM980_11.1.1_fat.bin Ok, Set : RM980_11.1.1_oemsbl.mbn Ok, Set : RM980_11.1.1_oemsblhd.mbn Ok, Set : RM980_11.1.1_persist.img Ok, Set : RM980_11.1.1_preload.img Ok, Set : RM980_11.1.1_qcsbl.mbn Ok, Set : RM980_11.1.1_qcsblhd_cfgdata.mbn Ok, Set : RM980_11.1.1_recovery.img Ok, Set : RM980_11.1.1_system.img Ok, Set : RM980_11.1.1_udisk.bin Ok, Set : RM980_11.1.1_userdata.img File HW revision is : HW Revision V1 Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Or 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 53C7D4EE Processing : RM980_11.1.1_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_11.1.1_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_11.1.1_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_059T9F6_IMEA_SA_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:04:37 Reboot phone Ok Connect phone on selected interface... Phone found! Nokia X Platform Phone detected (ADB) Read info... Ok |
The Following User Says Thank You to onz For This Useful Post: |
10-10-2014, 05:22 | #19879 (permalink) | |
No Life Poster Join Date: Feb 2012 Location: india (rajasthan) Age: 33
Member: 1719279 Status: Offline Thanks Meter: 140 | Quote:
here is good media fire link samsung e1200i flash file https://forum.gsmhosting.com/vbb/****************************/?iehhswe9fp21844 | |
The Following User Says Thank You to jitendramobile. For This Useful Post: |
10-10-2014, 06:15 | #19880 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | samsung b310e simlock done .... read flash done .... Code: Reconnect Power/Cable! Operation : Read FullFlash [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 47 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Read Flash Content Read Ok , collect info Platform : MOCOR_W13.09_FP_R5.0.2_Debug sc6500_samsung_PitonDS_SWA ExtInfo : LevelofLock 00000000 00000000 Project : SC6500_SAMSUNG HWInfo : SC6500_EiderVEDS Compile : 05-15-2014 17:09:38 Set FileInfo : Model Vendor : samsung Model Name : samsung b310e ExtInfo Data : indian Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6530_00800000_MOCOR_W13.09_FP_R5.0.2_Debug_sc6500_samsung_PitonDS_SWA_05152014170938_indian__samsung-samsung b310e.bin Done! Elapsed: 00:01:27 Reconnect Power/Cable! Code: Reconnect Power/Cable! Operation : Read FullFlash [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 47 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Read Flash Content Read Ok , collect info Platform : MOCOR_W13.09_FP_R5.0.2_Debug sc6500_samsung_PitonDS_SWA ExtInfo : LevelofLock 00000000 00000000 Project : SC6500_SAMSUNG HWInfo : SC6500_EiderVEDS Compile : 05-15-2014 17:09:38 Set FileInfo : Model Vendor : samsung Model Name : samsung b310e ExtInfo Data : indian Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6530_00800000_MOCOR_W13.09_FP_R5.0.2_Debug_sc6500_samsung_PitonDS_SWA_05152014170938_indian__samsung-samsung b310e.bin Done! Elapsed: 00:01:27 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to @@@___@@@ For This Useful Post: |
10-10-2014, 06:40 | #19881 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Micromax x282 Format success Quote:
Wbr Azeem | |
The Following 2 Users Say Thank You to .::AZEEM::. For This Useful Post: |
10-10-2014, 12:02 | #19882 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Symphony B32i Hang logo Done Code: ======= Flash Files set for flashing : [ MCU ] : FARSIGHTED50M_11B_PCB01_GSM_MT6250_S00.SYMPHONY_B32I_SOFTWARE_V1_3.BIN.BIN 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 217 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : B1E73D51F39A6D888661A7C99C5115CF BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x002FE000 , 0x00002000 File_Info : FARSIGHTED50M_11B_PCB01_gsm_MT6250_S00.SYMPHONY_B32I_SOFTWARE_V1_3.bin FileVersion : Symphony_B32i_Software_V1.3 Flash now Erase region , wait ... Write data , wait ... Write : FARSIGHTED50M_11B_PCB01_GSM_MT6250_S00.SYMPHONY_B32I_SOFTWARE_V1_3.BIN.BIN Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
The Following User Says Thank You to mbiborna For This Useful Post: |
10-10-2014, 17:48 | #19883 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Canada
Member: 119464 Status: Offline Thanks Meter: 288 | N8 rm-596 done by BEST. Code: Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_025.008_79.92_prd.core.fpsx PPM : RM-596_025.008_31.01_NAM_79.92_prd.rofs2.fpsx PPM2 : RM-596_025.008_269.05_default_79.92.2011.37_01_prd.rofs3.fpsx CNT : RM-596_025.008_269.05_default_79.92.2011.37_01.uda.fpsx APE : RM596_APE_ONLY_ENO_11w15_v0.148.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 2580021519A70344EC99A1EFF9DF2ED9C7BE4CCF ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 355944042102939 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355944042102939_CRT.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-596_025.008_79.92_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_025.008_79.92_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 514 blocks TIME : Write time : 00:00:22 MCU Write done ADL: Request programm status NAND status : 00000005 / 00000005 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-596_025.008_31.01_NAM_79.92_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_025.008_31.01_NAM_79.92_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 201 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000005 / 00000005 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-596_025.008_269.05_default_79.92.2011.37_01_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_025.008_269.05_default_79.92.2011.37_01_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000005 / 00000005 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-596_025.008_269.05_default_79.92.2011.37_01.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_025.008_269.05_default_79.92.2011.37_01.uda.fpsx Total writen 366 blocks TIME : Write time : 00:00:14 CNT Write done ADL: Request programm status NAND status : 00000005 / 00000005 / 00000000 ===Flashing [APE]=== Erase : Processing RM596_APE_ONLY_ENO_11w15_v0.148.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM596_APE_ONLY_ENO_11w15_v0.148.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 18 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000005 / 00000005 / 00000000 ADL: Close_Session Content: 000300000000050000000500000000 ADL: Reboot Flashing done! Total flash time : 00:00:50 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N8-00 Software Info: V 92_11w37.1 21-11-11 RM-596 (c) Nokia IMEI: 355944042102939 Ape Version: 025.008 Product code: 059D391 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Battery voltage is enough for start AfterFlash operations done ;D Done! |
The Following User Says Thank You to rasgula For This Useful Post: |
10-10-2014, 19:13 | #19884 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Nokia n8-00 rm_596 flashing done NOKIA N8-00 RM_596 FLASHING DONE Code: card found: S/N XXXXXXX registered to: fokal2008 Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_025.008_79.92_prd.core.fpsx PPM : RM-596_025.008_31.01_NAM_79.92_prd.rofs2.fpsx PPM2 : 4F33EA4C_RM-596_025.008_269.05_default_79.92.2011.37_01_prd.rofs3.fpsx CNT : 6C5BD7F9_RM-596_025.008_269.05_default_79.92.2011.37_01.uda.fpsx APE : RM596_APE_ONLY_ENO_11w15_v0.148.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 1C900214B6A40344AE5850CF14E612B76F56D3C8 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 352684048321116 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352684048321116_CRT.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-596_025.008_79.92_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_025.008_79.92_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 514 blocks TIME : Write time : 00:00:20 MCU Write done ADL: Request programm status NAND status : 00000007 / 00000005 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-596_025.008_31.01_NAM_79.92_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_025.008_31.01_NAM_79.92_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 201 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000007 / 00000005 / 00000000 ===Flashing [PPM2]=== Erase : Processing 4F33EA4C_RM-596_025.008_269.05_default_79.92.2011.37_01_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing 4F33EA4C_RM-596_025.008_269.05_default_79.92.2011.37_01_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000007 / 00000005 / 00000000 ===Flashing [CNT]=== Erase : Processing 6C5BD7F9_RM-596_025.008_269.05_default_79.92.2011.37_01.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing 6C5BD7F9_RM-596_025.008_269.05_default_79.92.2011.37_01.uda.fpsx Total writen 366 blocks TIME : Write time : 00:00:12 CNT Write done ADL: Request programm status NAND status : 00000007 / 00000005 / 00000000 ===Flashing [APE]=== Erase : Processing RM596_APE_ONLY_ENO_11w15_v0.148.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM596_APE_ONLY_ENO_11w15_v0.148.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 18 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000007 / 00000005 / 00000000 ADL: Close_Session Content: 000300000000070000000500000000 ADL: Reboot Flashing done! Total flash time : 00:00:45 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N8-00 Software Info: V 92_11w37.1 21-11-11 RM-596 (c) Nokia IMEI: 352684048321116 Ape Version: 025.008 Product code: 059C3H1 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:33 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Resetting selected items... Operating mode is OK, no need change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:01 Phone disconected! |
The Following User Says Thank You to fokal2008 For This Useful Post: |
10-11-2014, 07:07 | #19885 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | voice v30 format voice v30 format Code: Operation : Format FileSystem [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D433034475810B48443D0F9 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 4 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
10-11-2014, 07:25 | #19886 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Rangamati, Bangladesh Age: 40
Member: 1089621 Status: Offline Sonork: kk Thanks Meter: 62 | Nokia X2-02 Done ===Flashing [MCU]=== File : rm694__11.79.mcusw Image : rm694__11.79.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01980000 Erasing, wait ... Erase done, time : 00:02:09 Write , Start : 0x40280000 , Len : 0x01900000 Flashing , wait ... Region flash done, time : 00:00:29 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x7D76 ===Flashing [PPM]=== File : rm694__11.79.ppm_bg Image : package_bg.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:21 Write , Start : 0x41C00000 , Len : 0x0051758C Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0xF425 ===Flashing [CNT]=== File : rm694__11.79.image_bg_059D1P7 Image : package_bg_059D1P7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:03:25 Write , Start : 0x42300000 , Len : 0x00D60000 Flashing , wait ... Region flash done, time : 00:00:15 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0x6434 Flashing done! Total flash time : 00:07:03 Reboot phone now... Reading Phone Info.... Connected phone - X2-02 Software Info: V 11.79 15-08-12 RM-694 (c) Nokia IMEI: 353295055290380 PPM version : V 11.79 15-08-12 RM-694 (c) Nokia BG Product code: 059D197 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 43 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
The Following User Says Thank You to konok.kk For This Useful Post: |
10-11-2014, 07:42 | #19887 (permalink) |
Member: 1089621 Status: Offline Sonork: kk Thanks Meter: 62 | Nokia 3110c Flash Done Files Set for Flashing : MCU : rm237__07.30.mcusw PPM : rm237__07.30.ppm_c CNT : rm237__07.30.image_c_tr Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006010C192101001101 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 2300020F3B768B56D7CABC9D055CE7ED30B4B9A9 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm237__07.30.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:19 Write : Processing rm237__07.30.mcusw Total 945 [945/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:00:44 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.30.ppm_c Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:38 Write : Processing rm237__07.30.ppm_c Total 240 [240/0/0] blocks to write, writing... TIME : Write time : 00:00:11 PPM Write done ===Flashing [CNT]=== Erase : Processing rm237__07.30.image_c_tr Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:53 Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm237__07.30.image_c_tr ConvertImage: Page Size is 64K, converting... ConvertImage: File converted Loader len: 253888, CHK: 17DB ADL -> Sending loader... Reset connection... ADL : Check data ADL : Data accepted Write : Processing rm237__07.30.image_c_tr_128 Total 240 [240/0/0] blocks to write, writing... TIME : Write time : 00:00:11 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:05:59 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: 355220037247058 PPM version : V 07.30 07-05-09 RM-237 (c) Nokia. C Product code: Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 0 certs Uploading User Certificates... Uploaded 26 certs! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
10-11-2014, 07:51 | #19888 (permalink) |
Member: 1089621 Status: Offline Sonork: kk Thanks Meter: 62 | Nokia x3-00 Flash Done ===Flashing [MCU]=== Erase : Processing rm540__11.00.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm540__11.00.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 124 blocks TIME : Write time : 00:00:34 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm540__11.00.ppm_mr1 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm540__11.00.ppm_mr1 Total writen 24 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm540__11.00.image_mr1_0581089_007 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm540__11.00.image_mr1_0581089_007 Total writen 67 blocks TIME : Write time : 00:00:22 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:01:06 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X3-00 Software Info: V 11.00 17-03-11 RM-540 (c) Nokia IMEI: 351536045033873 PPM version : V 11.00 17-03-11 RM-540 (c) Nokia MR1 Product code: 0581095 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 34 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
10-11-2014, 08:41 | #19889 (permalink) |
Member: 1089621 Status: Offline Sonork: kk Thanks Meter: 62 | Nokia 6303c Flash Done ===Flashing [MCU]=== Erase : Processing rm443__10.12.mcusw Found 8 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x0005FFFF, NOR, CMT Result: 0000 Erasing area 0x00060000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x0015FFFF, NOR, CMT Result: 0000 Erasing area 0x00160000 - 0x0023FFFF, NOR, CMT Result: 0000 Erasing area 0x01740000 - 0x0191FFFF, NOR, CMT Result: 0000 Erasing area 0x00240000 - 0x0173FFFF, NOR, CMT Result: 0000 Erasing area 0x022E0000 - 0x0261FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:38 Write : Processing rm443__10.12.mcusw Total 1597 [1597/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [ISA+DYNSW] TIME : Write time : 00:01:01 MCU Write done ===Flashing [PPM]=== Erase : Processing rm443__10.12.ppm_i Found 1 areas to erase Erasing area 0x01920000 - 0x022DFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:54 Write : Processing rm443__10.12.ppm_i Total 429 [429/0/0] blocks to write, writing... TIME : Write time : 00:00:16 PPM Write done ===Flashing [CNT]=== Erase : Processing rm443__10.12.image_i_matt_black Found 2 areas to erase Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT Result: 0000 Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:23 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm443__10.12.image_i_matt_black Total 640 [640/0/0] blocks to write, writing... TIME : Write time : 00:00:24 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:08:40 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303 classic Software Info: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 358281038659078 PPM version : V 10.12 08-04-10 RM-443 (c) Nokia I Product code: 0569171 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 34 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
10-11-2014, 09:01 | #19890 (permalink) |
Member: 1089621 Status: Offline Sonork: kk Thanks Meter: 62 | Nokia 112 Flash Done ===Flashing [MCU]=== File : rm837__03.51.mcusw Image : rm837__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:15 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:29 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x87F4 ===Flashing [PPM]=== File : rm837__03.51.ppm_s2 Image : package_s2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:21 Write , Start : 0x41BC0000 , Len : 0x003F0468 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xD886 ===Flashing [CNT]=== File : rm837__03.51.image_s2_059P4W0 Image : package_s2_059P4W0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:06 Write , Start : 0x421C0000 , Len : 0x00EE0000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x9ED2 Flashing done! Total flash time : 00:07:54 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 112 Software Info: V 03.51 06-08-13 RM-837 (c) Nokia IMEI: 354623058917288 PPM version : V 03.51 06-08-13 RM-837 (c) Nokia S2 Product code: 059P4N3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
