05-03-2015, 10:40 | #22036 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | qmobile b500 read flash Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 21 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 8AC304D3ECE0B0A510F4DCFB723CF54A BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Reading Flash Conent now ... Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : R032_QMOBILE_PCB01_gprs_MT6260_S00.R032Q_B500_BT_FM_SC_12864_V008_20140811.bin FileVersion : R032Q_B500_BT_FM_SC_12864_V008_20140811 Saved to : C:\InfinityBox\CM2MTK\Read_out\R032_QMOBILE_PCB01_gprs_MT6260_S00.R032Q_B500_BT_FM_SC_12864_V008_20140811.bin Done! Elapsed: 00:01:12 Reconnect Power/Cable! |
05-03-2015, 10:41 | #22037 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | qmobile e4 flash Code: ======= Flash Files set for flashing : [ MCU ] : E4 QMOBILE ALL LOCK OK WBG1307QM_0202_PCB01_GPRS_MT6250_S00.1307QM_0202_V0735 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 21 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 23163E6DC76CDACA0A48A469B6012FE0 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 File_Info : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V0735.bin FileVersion : 1307QM_0202_V0735 Flash now Erase region , wait ... Write data , wait ... Write : E4 QMOBILE ALL LOCK OK WBG1307QM_0202_PCB01_GPRS_MT6250_S00.1307QM_0202_V0735 Done! |
05-03-2015, 10:42 | #22038 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | qmobile x7 read flash Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 52 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 55878AF4734DDC6A11E749010F7CC367 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E [0] : FLASH_DIE : 00C2 0025 0037 0000 [0] : FLASH_LEN : 0x00800000 SDS : 0x007FE000 , 0x00002000 Reading Flash Conent now ... Read Flash now Read Ok , 8388608 bytes read Check and collect compile info File_Info : FARSIGHTED60A_BU2_11B_PCB01_gprs_MT6260_S00.QMOBILE_X7_SOFTWARE_V15.bin FileVersion : Qmobile_X7_Software_V15 Saved to : C:\InfinityBox\CM2MTK\Read_out\FARSIGHTED60A_BU2_11B_PCB01_gprs_MT6260_S00.QMOBILE_X7_SOFTWARE_V15.bin Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
05-03-2015, 10:46 | #22039 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | qmobile e50 sim access error full logs Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 21 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : 0000 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : BED993F51458E65F705E8FDB5448CCFE BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003FDFFF , LEN : 0x00058000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:21 Reconnect Power/Cable! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 21 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : BED993F51458E65F705E8FDB5448CCFE BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6260 SW : A8_YH_L2412_EUAP_V0.0.5 HW : BESTONE60D_11B_HW IMEI[1] : 135790246811220 IMEI[2] : 135790246811220 Update IMEI[1] to : 351209067687873 Update IMEI[2] to : 351209056768783 Done! Done! Elapsed: 00:01:02 Reconnect Power/Cable! |
05-03-2015, 11:22 | #22040 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Nokia x2-02 flash done. Connect phone on selected interface... Core : v2.07 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm694__11.84.mcusw PPM : rm694__11.84.ppm_m_a CNT : rm694__11.84.image_m_a_059D197 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm694__11.84.mcusw Image : rm694__11.84.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01980000 Erasing, wait ... Erase done, time : 00:00:51 Write , Start : 0x40280000 , Len : 0x01900000 Flashing , wait ... Region flash done, time : 00:00:40 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xB615 ===Flashing [PPM]=== File : rm694__11.84.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:09 Write , Start : 0x41C00000 , Len : 0x00440340 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x40FC ===Flashing [CNT]=== File : rm694__11.84.image_m_a_059D197 Image : package_m_a_059D197.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:00:59 Write , Start : 0x42300000 , Len : 0x00DC0000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x601C Flashing done! Total flash time : 00:03:13 Reboot phone now... Reading Phone Info.... Connected phone - X2-02 Software Info: V 11.84 13-09-12 RM-694 (c) Nokia IMEI: 358958050381703 PPM version : V 11.84 13-09-12 RM-694 (c) Nokia M_A Product code: 059R7S0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 43 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:14 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to ij_cell For This Useful Post: |
05-03-2015, 11:53 | #22041 (permalink) |
Major Poster Join Date: Apr 2012
Member: 1753053 Status: Offline Thanks Meter: 69 | QMobile B85 Read lock Code: Start at : [5/2/2015 / 2:40:46 PM] Operation : Read UserCode [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 11 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 6E5170437803CA60F1CB9C3B3B56332B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Read ExtData Sorting ExtData Reading UserCode Active : No , Code : 6565 Privacy Lock :VV Done! Elapsed: 00:00:27 Reconnect Power/Cable! Finish at : [5/2/2015 / 2:41:14 PM] |
05-03-2015, 12:24 | #22042 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | VOiCE_V440_MTK 6261 READ FLASH FILE DONE Code: Operation : Read Flash [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 26 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : CE72B47E31A72E3E4BF8DC3C4F3F7134 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Reading Flash Conent now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : HONGYU61M_11C_PCB01_gprs_MT6261_S00.C189D1_VOICE_V00_M24E_141014.bin FileVersion : C189D1_VOICE_V00_M24E_141014 Saved to : C:\InfinityBox\CM2MTK\Read_out\HONGYU61M_11C_PCB01_gprs_MT6261_S00.C189D1_VOICE_V00_M24E_141014.bin Done! Elapsed: 00:00:15 |
05-03-2015, 12:29 | #22043 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Lava iris 500 read Fac file Done Code: Operation : Read Flash [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42019573429681FF DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D42019573429681FF [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : iris500 ProdName : iris500 ProdModel : iris500 Device : iris500 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 [Read Ok] : preloader_lava72_sp17w.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / lava72_sp17w / EMMC FW Size : 805 MiB Scatter saved to : C:\Users\AkhtaraLi\Desktop\MT6572__iris500__iris500__iris500__4.4.2__ALPS.KK1.MP7.V1\ All done! Done! Elapsed: 00:03:50 |
05-03-2015, 12:38 | #22044 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | successfully read factory firmware micromaxx a290(canvas knight) Code: Operation : Read Flash [ v1.17 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A483847326404050BA1057A81D9 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A483847326404050BA1057A81D9 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Micromax ProdName : A290 ProdModel : Micromax A290 Device : A290 AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_s4750ae.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6592 / V1.1.2 / s4750ae / EMMC FW Size : 1143 MiB Scatter saved to : L:\MT6592__Micromax__Micromax A290__A290__4.4.2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:04:46 Reconnect Power/Cable! |
05-03-2015, 12:59 | #22045 (permalink) |
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Nokia 201 flash done. Connect phone on selected interface... Core : v2.07 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm799__11.81.mcusw PPM : rm799__11.81.ppm_l1 CNT : rm799__11.81.image_l1_059K5K1 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm799__11.81.mcusw Image : rm799__11.81.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x017C0000 Erasing, wait ... Erase done, time : 00:03:01 Write , Start : 0x40280000 , Len : 0x017C0000 Flashing , wait ... Region flash done, time : 00:00:46 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x8FDE ===Flashing [PPM]=== File : rm799__11.81.ppm_l1 Image : package_l1.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A40000 , Len : 0x00740000 Erasing, wait ... Erase done, time : 00:00:36 Write , Start : 0x41A40000 , Len : 0x00516A2C Flashing , wait ... Region flash done, time : 00:00:08 CRC check passed , 0x3BA7 ===Flashing [CNT]=== File : rm799__11.81.image_l1_059K5K1 Image : package_l1_059K5K1.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42180000 , Len : 0x01CA0000 Erasing, wait ... Erase done, time : 00:03:43 Write , Start : 0x42180000 , Len : 0x00EC0000 Flashing , wait ... Region flash done, time : 00:00:25 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0x95F5 Flashing done! Total flash time : 00:09:01 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 201 Software Info: V 11.81 20-08-12 RM-799 (c) Nokia IMEI: 357273052128743 PPM version : V 11.81 20-08-12 RM-799 (c) Nokia L1 Product code: 059P118 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 43 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:53 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-03-2015, 14:35 | #22046 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile Noir A8 Read Factory File Done Code: Operation : Read Flash [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D0007710395AF0F [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... MT657x Old CPU : Skip Initial Info read [Image Ok] : preloader_gionee77_cu_ics2.bin [Image Ok] : dspbl data erased , will skip it [Image Ok] : MBR [Image Ok] : EBR1 [Image Ok] : lk.bin [Image Ok] : boot.img [Image Ok] : recovery.img [Image Ok] : secro.img [Image Ok] : logo.bin [Image Ok] : system.img [Image Ok] : cache.img [Image Ok] : userdata.img [Image Ok] : fat.img Brand : QMobile ProdName : QMobile ProdModel : A8 Device : QMobile AndroidVer: 4.0.4 MTKxCPU : MT6577 MTKxPRJ : ALPS.ICS2.6577.SP.V1 [ScatCFG] : MT6577 / V1.0.0 / gionee77_cu_ics2 / EMMC FW Size : 447 MiB Scatter saved to : C:\Users\Luckey1\Desktop\MT6577__QMobile__A8__QMobile__4.0.4__ALPS.ICS2.6577.SP.V1\ All done! Done! Elapsed: 00:06:13 Reconnect Power/Cable! |
05-03-2015, 15:44 | #22047 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | successfully read factory firmware iball valvet ips Code: Operation : Read Flash [ v1.17 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3957524D4201183570B6A0C1 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D4201183570B6A0C1 [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : iBall_Andi4P_IPS_Velvet ProdName : iBall_Andi4P_IPS_Velvet ProdModel : iBall_Andi4P_IPS_Velvet Device : bird72_wet_a_jb3 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : 1365C.I580.T1.A2.140409.JB3.V1.WVGA.EN.2P16.COM [Read Ok] : preloader_bird72_wet_a_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / bird72_wet_a_jb3 / EMMC FW Size : 550 MiB Scatter saved to : L:\MT6572__iBall_Andi4P_IPS_Velvet__iBall_Andi4P_IPS_Velvet__bird72_wet_a_jb3__4.2.2__1365C.I580.T1.A2.140409.JB3.V1.WVGA.EN.2P16.COM\ All done! Done! Elapsed: 00:03:08 Reconnect Power/Cable! |
05-03-2015, 16:10 | #22048 (permalink) |
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Nokia c1-01 flash done. Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Core : v2.07 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__06.20.mcusw PPM : rm607__06.20.ppm_c CNT : rm607__06.20_009.image_c_voda_nl_9f7c8 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_2.5_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm607__06.20.mcusw Image : rm607__06.20.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:48 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:35 CRC check passed , 0x3A16 ===Flashing [PPM]=== File : rm607__06.20.ppm_c Image : package_c.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:07 Write , Start : 0x41C00000 , Len : 0x003B8DD8 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0x10F6 ===Flashing [CNT]=== File : rm607__06.20_009.image_c_voda_nl_9f7c8 Image : package_c_voda_nl.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:03 Write , Start : 0x42200000 , Len : 0x00D40000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x2F19 Flashing done! Total flash time : 00:03:05 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 06.20 13-06-12 RM-607 (c) Nokia IMEI: 351662050219346 PPM version : V 06.20 13-06-12 RM-607 (c) Nokia C Product code: 059F5P6 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 41 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:06 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-03-2015, 16:56 | #22049 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile X150 MT6582 V4.4.2 Read Factory File Done By Infinity Code:
The Following 4 Users Say Thank You to kabul For This Useful Post: |
05-03-2015, 17:32 | #22050 (permalink) |
Freak Poster Join Date: Dec 2005 Location: KOLKATA INDIA
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | Samsung E1200Y SIMLOCK DONE Chinese Miracle II [SPD module] v 1.01 Operation : Format File System [ v1.01 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 139 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! |
The Following User Says Thank You to srworld For This Useful Post: |
