05-13-2015, 14:37 | #22276 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Gfive ft01 6531 Code: Chinese Miracle II [SPD module] v 1.01 Operation : Read FullFlash [ v1.01 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 111 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Read Flash Content Read Ok , collect info ExtInfo : CGC30_XWY06 0.0.7 Project : SC6531_PDA HWInfo : SC6531_PDA Compile : 11-17-2014 11:50:28 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_CGC30_XWY06__0.0.7_11172014115028.bin Done! Elapsed: 00:01:07 Reconnect Power/Cable! |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
05-13-2015, 14:59 | #22277 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Nokia X flashing done- Code: Core : v2.07 , NXP FlashEngine : v4.8 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_1.2.4.3_059T985_IMEA_IN_variant.img Ok, Set : RM980_1.2.4.3_boot.img Ok, Set : RM980_1.2.4.3_cache.img Ok, Set : RM980_1.2.4.3_emmc_appsboot.mbn Ok, Set : RM980_1.2.4.3_emmc_appsboothd.mbn Ok, Set : RM980_1.2.4.3_fat.bin Ok, Set : RM980_1.2.4.3_oemsbl.mbn Ok, Set : RM980_1.2.4.3_oemsblhd.mbn Ok, Set : RM980_1.2.4.3_persist.img Ok, Set : RM980_1.2.4.3_preload.img Ok, Set : RM980_1.2.4.3_qcsbl.mbn Ok, Set : RM980_1.2.4.3_qcsblhd_cfgdata.mbn Ok, Set : RM980_1.2.4.3_recovery.img Ok, Set : RM980_1.2.4.3_system.img Ok, Set : RM980_1.2.4.3_udisk.bin Ok, Set : RM980_1.2.4.3_userdata.img File HW revision is : HW Revision V1 Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 32C4BA84 Processing : RM980_1.2.4.3_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_1.2.4.3_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_1.2.4.3_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_1.2.4.3_059T985_IMEA_IN_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:05:09 Reboot phone Ok Connect phone on selected interface... |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
05-13-2015, 15:13 | #22278 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Nokia 305 flash done. Connect phone on selected interface... Core : v2.07 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm767__05.93.mcusw PPM : BCF97DB3_rm767__05.93.ppm_mag CNT : FB963F63_rm767__05.93.image_mag_059L916_318_01 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm767__05.93.mcusw Image : rm767__05.93.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x000C0000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x000C0000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40120000 , Len : 0x01C20000 Erasing, wait ... Erase done, time : 00:00:59 Write , Start : 0x40120000 , Len : 0x01C04000 Flashing , wait ... Region flash done, time : 00:00:44 Processing Region 5/5 Erase , Start : 0x43EE0000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x3F21 ===Flashing [PPM]=== File : BCF97DB3_rm767__05.93.ppm_mag Image : package_mag.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41D40000 , Len : 0x00800000 Erasing, wait ... Erase done, time : 00:00:13 Write , Start : 0x41D40000 , Len : 0x005E0B7C Flashing , wait ... Region flash done, time : 00:00:07 CRC check passed , 0x0D78 ===Flashing [CNT]=== File : FB963F63_rm767__05.93.image_mag_059L916_318_01 Image : rm767__05.93.image_mag_059L916_318_01.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42540000 , Len : 0x019A0000 Erasing, wait ... Erase done, time : 00:01:12 Write , Start : 0x42540000 , Len : 0x00E20000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43F00000 , Len : 0x00080000 Erasing, wait ... Erase done, time : 00:00:01 No write data, skip CRC check passed , 0x2E3C Flashing done! Total flash time : 00:03:42 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 306 Software Info: V 05.93 09-11-12 RM-767 (c) Nokia IMEI: 354576054441473 PPM version : V 05.93 09-11-12 RM-767 (c) Nokia MAG Product code: 059P9T9 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 43 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:34 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-13-2015, 16:40 | #22279 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Nokia 303 Flashing Done Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm763__14.87.mcusw PPM : rm763__14.87.ppm_ma3 CNT : rm763__14.87.image_ma3_059J1F2 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: EC650000FFFB3C4008D00F6DA7209E0180C0C6C5 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : ACE39760399CD7A3FE439DCC52111C24D435D533 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 353672051515988 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\Best\Backup\Cert\353672051515988_CRT.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm763__14.87.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm763__14.87.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ISA+EXTDRV] Total writen 291 blocks TIME : Write time : 00:00:04 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm763__14.87.ppm_ma3 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm763__14.87.ppm_ma3 Total writen 53 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm763__14.87.image_ma3_059J1F2 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing rm763__14.87.image_ma3_059J1F2 Total writen 370 blocks TIME : Write time : 00:00:06 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:16 Reboot phone now... |
05-13-2015, 16:44 | #22280 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | RM-924 Flashing Done Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm924__06.09.mcusw PPM : rm924__06.09.ppm_ma3 CNT : rm924__06.09.image_ma3_059R9P0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 357897053086706 IMEI 2 : 357897053086714 PCcode : 059R9K7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\Best\Backup\Cert\357897053086706_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm924__06.09.mcusw Image : rm924__06.09.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01A40000 Erasing, wait ... Erase done, time : 00:00:53 Write , Start : 0x40280000 , Len : 0x01A40000 Flashing , wait ... Region flash done, time : 00:00:34 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip [Minor Error] : CRC returned by phone is wrong! [CHK] : 0100E361 ===Flashing [PPM]=== File : rm924__06.09.ppm_ma3 Image : package_ma3.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41CC0000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:11 Write , Start : 0x41CC0000 , Len : 0x003EFB64 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0x44C0 ===Flashing [CNT]=== File : rm924__06.09.image_ma3_059R9P0 Image : package_ma3_059R9P0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:00:58 Write , Start : 0x42300000 , Len : 0x00C60000 Flashing , wait ... Region flash done, time : 00:00:15 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xDD16 Flashing done! Total flash time : 00:03:05 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 210 Software Info: V 06.09 14-10-13 RM-924 (c) Nokia IMEI: 357897053086706 PPM version : V 06.09 14-10-13 RM-924 (c) Nokia MA3 Product code: 059R9K7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:05:14 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-13-2015, 16:47 | #22281 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Qmobile A300 Full Info,NVRM & Read Full Factory File Done Code: Operation : Read Flash [ v1.20 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3E7EF417D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3E7EF417D [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : A300 ProdModel : QMobile A300 Device : QMobile A300 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.P65 [Read Ok] : preloader_s7810bp.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / s7810bp / EMMC FW Size : 1062 MiB Scatter saved to : C:\Users\Fahad Irfan\Desktop\Qmobile A300\MT6572__QMobile__QMobile A300__QMobile A300__4.2.2__ALPS.JB3.MP.V1.P65\ All done! Done! Elapsed: 00:05:12 Reconnect Power/Cable! Operation : Read NVRAM [ v1.20 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3E7EF417D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3E7EF417D [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Read Ok, MT6572_eMMC.spnv saved Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
05-13-2015, 19:02 | #22282 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Qmobile X1 Read Pattern Lock Done Code: Operation : Read PatternLock [ v1.20 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D42004AEAB21EA13D DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D42004AEAB21EA13D [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 520 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 125478963 Done! Elapsed: 00:00:25 Reconnect Power/Cable! Operation : Check / Read Info [ v1.20 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 254 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3958524D42004AEAB21EA13D DA Stat : v4.2 on BBID : 0x8B DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x10000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D42004AEAB21EA13D [eMMC] : FLASH_LEN : 0x0000000070000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : X1 ProdModel : QMobile X1 Device : QMobileX1 AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : X1_MP_141206 Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
05-13-2015, 23:01 | #22283 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6592 Factory FW read : Code: Operation : Read Flash [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040506A11EA48107 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040506A11EA48107 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Micromax ProdName : A290 ProdModel : Micromax A290 Device : A290 AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_s4750ae.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6592 / V1.1.2 / s4750ae / EMMC FW Size : 1060 MiB Scatter saved to : E:\MT6592__Micromax__Micromax A290__A290__4.4.2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:06:08 Reconnect Power/Cable! Code: Scatter Load Ok , BaseBand : MT6592 , Project : s4750ae , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.21 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040506A11EA48107 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040506A11EA48107 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : s4750ae , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x00000001CEE00000 Flash Pre-Erase Done, time used : 00:00:12 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4750ae.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:52 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:33 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:51 Reconnect Power/Cable! |
05-14-2015, 06:03 | #22284 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,218 | Western D60 MTK Code: Operation : Read Flash [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 20 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 43B6BCD6EA8240AEE96A94C1FF159D0E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Reading Flash Conent now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : FISE60D_11B_PCB01_gprs_MT6260_S00.MAUI_11B_W13_08_MP_V1_F19.bin FileVersion : MAUI.11B.W13.08.MP.V1.F19 Saved to : C:\InfinityBox\CM2MTK\Read_out\FISE60D_11B_PCB01_gprs_MT6260_S00.MAUI_11B_W13_08_MP_V1_F19.bin Done! Elapsed: 00:00:26 Reconnect Power/Cable! Operation : Read UserCode [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 20 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 43B6BCD6EA8240AEE96A94C1FF159D0E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 1155 PLock|MobTrack : Not active Done! Elapsed: 00:00:06 Reconnect Power/Cable! |
05-14-2015, 08:34 | #22285 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | successfully blink repair rage thunder+ format logs Code: Operation : Format File System [ v1.01 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:31 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.01 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : rage Model Name : thunder+ Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32__rage-thunder+.bin Done! Elapsed: 00:01:24 Reconnect Power/Cable! |
The Following User Says Thank You to rehmani For This Useful Post: |
05-14-2015, 08:53 | #22286 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | nokia 620 successfully flash Code: ==== Settings : Reset EFS : Enabled Secure Erase : Disabled ==== Flash Files selected : AMSS : RM889_13w10_prod_generic_amss.esco WP : RM889_13100_prod_201_05_boot.esco UDA : RM889_13w10_prod_generic_user_area_erase.esco Check files done, All files are Ok Dead Mode is Selected Waiting for USB device... --- Press and hold 'Volume Up' button and insert cable! --- Connection opened successfully Establish connection with device... Kick ... OSBL alive Init Ok OSBL info Prt : 1.1 Ver : 1.0.0.0 Bld : 1 Tms : 22.02.2012 / 09:37:26 ==== AMSS ==== Processing : RM889_13w10_prod_generic_amss.esco amss.mbn.cert , Hash : B131DA19CE3B6B5F965AE2F2947199519A5F3279 amss.mbn.enc , len : 0x01245690 , Type : Data Will flash 1 regions AMSS flashing done ==== WINDOWS PHONE ==== Processing : RM889_13100_prod_201_05_boot.esco boot.img.cert , Hash : B131DA19CE3B6B5F965AE2F2947199519A5F3279 boot.img , len : 0x182ACE00 , Type : Data Will flash 26 regions Windows Phone flashing done ==== USER DEFINED AREA ==== Processing : RM889_13w10_prod_generic_user_area_erase.esco user_area_erase.cert , Hash : B131DA19CE3B6B5F965AE2F2947199519A5F3279 UDA file detected, will erase defined region Using Normal Erase method UDA erase done UDA flashing done Flashing done! Flashing time : 00:02:44 Restore EFS from GC ... Restore Done Reboot device Ok Phone disconected! Connect phone on selected interface... |
05-14-2015, 08:56 | #22287 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Rajasthan (Kota)
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | plz add this 32mb flash file isuzu i1 model here is the logs Start at : [5/14/2015 / 1:08:49 PM] Operation : Read User Code [ v1.00 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash CAP : 02000000 Check data... Can take some time Error while prepare! Please, send FlashDump + log to support! ========================= Start ========================= 5/14/2015 / 1:22:04 PM ================================================== ======= SPD6531_02000000_ - Download - 4shared readed file |
05-14-2015, 13:00 | #22289 (permalink) |
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Nokia 210 flash done. Connect phone on selected interface... Core : v2.07 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm925__04.12.mcusw PPM : rm925__04.12.ppm_t CNT : rm925__04.12.image_t_059S8T1 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm925__04.12.mcusw Image : rm925__04.12.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01A40000 Erasing, wait ... Erase done, time : 00:00:52 Write , Start : 0x40280000 , Len : 0x01A40000 Flashing , wait ... Region flash done, time : 00:01:01 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xDDFF ===Flashing [PPM]=== File : rm925__04.12.ppm_t Image : package_t.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41CC0000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:10 Write , Start : 0x41CC0000 , Len : 0x0055E70C Flashing , wait ... Region flash done, time : 00:00:07 CRC check passed , 0xC889 ===Flashing [CNT]=== File : rm925__04.12.image_t_059S8T1 Image : package_t_059S8T1.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:01:00 Write , Start : 0x42300000 , Len : 0x00AC0000 Flashing , wait ... Region flash done, time : 00:00:14 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xF83C Flashing done! Total flash time : 00:03:34 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 210 Software Info: V 04.12 21-05-13 RM-925 (c) Nokia IMEI: 355513052004804 PPM version : V 04.12 21-05-13 RM-925 (c) Nokia T Product code: 059T6N7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:38 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-14-2015, 13:19 | #22290 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | gionee p6 read firmware and format done read firmware Code: Operation : Read Flash [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513758534142014235E686B163 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 150100513758534142014235E686B163 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : GiONEE ProdName : GiONEE ProdModel : P6 Device : P6 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_gionee82_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : spdata.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / gionee82_cwet_kk / EMMC FW Size : 1324 MiB Scatter saved to : L:\MT6582__GiONEE__P6__P6__4.4.2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:06:24 Reconnect Power/Cable! format done Code: Operation : Format FileSystem [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513758534142014235E686B163 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 150100513758534142014235E686B163 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 6 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
