08-15-2015, 08:23 | #24271 (permalink) |
Freak Poster Join Date: Jun 2015 Location: PAKISTAN Age: 47
Member: 2418725 Status: Offline Sonork: 100.1679834.ANDROID BOSS. Thanks Meter: 166 | HUAWEI Y360-U61 Read Factory File HUAWEI Y360-U61 Read Factory File Code: Chinese Miracle II [MTK module] v 1.25 Operation : Read Flash [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Read Flash [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001611F56CA422B DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 0EG40 [eMMC] : FLASH_CID : 11010030303447453001611F56CA422B [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : HUAWEI ProdName : Y360-U61 ProdModel : HUAWEI Y360-U61 Device : HWY360-U AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_wt98360.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : global_cust.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / wt98360 / EMMC FW Size : 1374 MiB Scatter saved to : C:\Users\ANROID BOSS\Desktop\MT6582__HUAWEI__HUAWEI Y360-U61__HWY360-U__4.4.2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:06:12 Reconnect Power/Cable! Br ..ANROID BOSS.. |
The Following User Says Thank You to ..ANROID BOSS.. For This Useful Post: |
08-15-2015, 14:51 | #24272 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2444497 Status: Offline Thanks Meter: 26 | Symphony W60 Code: Operation : Format FileSystem [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594815A13B4BFACFD1 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : not found, will read now ... FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:02:29 Reconnect Power/Cable! |
08-15-2015, 15:35 | #24273 (permalink) |
Member: 2444497 Status: Offline Thanks Meter: 26 | Western D110 Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Check data... Can take some time User Code : 1211 Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
The Following User Says Thank You to phone_care For This Useful Post: |
08-15-2015, 16:57 | #24274 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,440 | Lumia 710 language change QC - open extended tab , select 710 , press Check/Info , Restore BL then flash as usual Code: card found: S/N registered to: me Connect phone on selected interface... Checking for device... Qualcomm MMC Storage , rev : 2.31 Drive space : 7 GiB Drive Index : 2 Processing MBR... Processing EBR... Check product info... Current OSBL mode : QUALCOMM Found : Sabre Model : RM-803 , RM-809 Model : Lumia 710 Phone Id set to : 059M3K1_MQO311983 Restoring OSB to DLOAD Product : RM-803 (Lumia 710) Restore BL Ok, OSBL changed to DLOAD! Done Phone disconected! Connect phone on selected interface... Core : v2.10 , WP7x FlashEngine : v7.9 ==== Settings : Reset EFS : Disabled Secure Erase : Disabled ==== Flash Files selected : OSBL : RM803_12w46_prod_generic_nokia_osbl.esco AMSS : RM803_12w46_prod_generic_amss.esco ADSP : RM803_12w46_prod_generic_adsp.esco WP : RM803_12460_prod_494_01_boot.esco UDA : RM803_12w46_prod_generic_user_area_erase.esco Check files done, All files are Ok Dead Mode is Selected Waiting for USB device... --- Press and hold 'Volume Up' button and insert cable! --- Connection opened successfully Establish connection with device... Kick ... OSBL alive Init Ok OSBL info Prt : 1.0 Ver : 1.0.0.4 Bld : 10 Tms : 29.09.2011 / 13:38:56 ==== OSBL ==== Processing : RM803_12w46_prod_generic_nokia_osbl.esco nokia_osbl.mbn.cert , Hash : C72DBA3ABED42215584093FA9DE247381D6062B4 nokia_osbl.mbn , len : 0x000EA228 , Type : Data Will flash 1 regions OSBL flashing done ==== AMSS ==== Processing : RM803_12w46_prod_generic_amss.esco amss.mbn.cert , Hash : C72DBA3ABED42215584093FA9DE247381D6062B4 amss.mbn.enc , len : 0x00FDD690 , Type : Data Will flash 1 regions AMSS flashing done ==== ADSP ==== Processing : RM803_12w46_prod_generic_adsp.esco adsp.mbn.cert , Hash : C72DBA3ABED42215584093FA9DE247381D6062B4 adsp.mbn.enc , len : 0x005562D0 , Type : Data Will flash 1 regions ADSP flashing done ==== WINDOWS PHONE ==== Processing : RM803_12460_prod_494_01_boot.esco boot.img.cert , Hash : C72DBA3ABED42215584093FA9DE247381D6062B4 boot.img , len : 0x17F0FE00 , Type : Data Will flash 25 regions Windows Phone flashing done ==== USER DEFINED AREA ==== Processing : RM803_12w46_prod_generic_user_area_erase.esco user_area_erase.cert , Hash : C72DBA3ABED42215584093FA9DE247381D6062B4 UDA file detected, will erase defined region Using Normal Erase method UDA erase done UDA flashing done Flashing done! Flashing time : 00:03:24 Reboot device Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to :Aishur: For This Useful Post: |
08-15-2015, 17:48 | #24275 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Qmobile Z4 (MT6589) IMEI Permanent Repaired. Qmobile Z4 (MT6589) IMEI Permanent Repaired. Code: Operation : Repair Security [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 49000115303055321961174161804166 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : A00U2 [eMMC] : FLASH_CID : 15010049325530304117611966418061 [eMMC] : FLASH_LEN : 0x0000000747C00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Set IMEI [00] : 3532570500NNNNN Prepare finished. Security check required! Wait for phone... Phone found! [ 17 ] Sync... PostCheck Ok! Repair done! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
08-16-2015, 08:29 | #24277 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,353 | E72, just flashing : Code: IDM initializing, wait... Checking access to Products folder... Folder for RM-530 not exist. Attempt to create Prepare done, collect info [Query] : RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx , 2,58 MB [Query] : rm530_091.003_prd.core.fpsx , 106,88 MB [Query] : rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx , 8,43 MB [Query] : rm530_091.003_U008.000_prd.uda.fpsx , 12,60 MB [Query] : rm530_091.003_20.01_Russian_QW1_prd.rofs2.fpsx , 65,84 MB [Query] : RM530_0584266_091.003_001.vpl , 4,54 KB Files to download : 6 Total size to download : 196,34 MB Downloading now, please, wait... [Download] : RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx [Download] : rm530_091.003_prd.core.fpsx [Download] : rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx [Download] : rm530_091.003_U008.000_prd.uda.fpsx [Download] : rm530_091.003_20.01_Russian_QW1_prd.rofs2.fpsx [Download] : RM530_0584266_091.003_001.vpl Verify files now ..... [Verify Ok] : rm530_091.003_prd.core.fpsx [Verify Ok] : rm530_091.003_20.01_Russian_QW1_prd.rofs2.fpsx [Verify Ok] : rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx [Verify Ok] : rm530_091.003_U008.000_prd.uda.fpsx [Verify Ok] : RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx All done, all files were downloaded! Core : v2.10 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm530_091.003_prd.core.fpsx PPM : rm530_091.003_20.01_Russian_QW1_prd.rofs2.fpsx PPM2 : rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm530_091.003_U008.000_prd.uda.fpsx APE : RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 18E00002B7D7034480DF307C7D53E4D8D3135211 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 660D81A4455F6F7F9B81D5D10F5336B14B50635E ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357895045577170 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357895045577170_CRT.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm530_091.003_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm530_091.003_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 451 blocks TIME : Write time : 00:00:26 MCU Write done ADL: Request programm status NAND status : 00000007 / 00000007 / 00000000 ===Flashing [PPM]=== Erase : Processing rm530_091.003_20.01_Russian_QW1_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm530_091.003_20.01_Russian_QW1_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 265 blocks TIME : Write time : 00:00:16 PPM Write done ADL: Request programm status NAND status : 00000007 / 00000007 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 35 blocks TIME : Write time : 00:00:02 PPM Write done ADL: Request programm status NAND status : 00000007 / 00000007 / 00000000 ===Flashing [CNT]=== Erase : Processing rm530_091.003_U008.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm530_091.003_U008.000_prd.uda.fpsx Total writen 51 blocks TIME : Write time : 00:00:04 CNT Write done ADL: Request programm status NAND status : 00000007 / 00000007 / 00000000 ===Flashing [APE]=== Erase : Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 12 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000007 / 00000007 / 00000000 ADL: Close_Session Content: 000300000000070000000700000000 ADL: Reboot Flashing done! Total flash time : 00:00:55 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E72-2 Software Info: V ICPR82_11w16.3.11 29-03-12 RM-529 (c) Nokia IMEI: 357895045577170 Ape Version: 091.003 Product code: 0584601 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:26 Connect phone on selected interface... |
08-16-2015, 08:57 | #24278 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | QMOBILE E4 FLASHiNG DONE ... Code: Load File File_Info : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V0770.bin FileVersion : 1307QM_0202_V0770 Load File Ok Operation : Flash [ v1.25 ] ======= Flash Files set for flashing : [ MCU ] : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V0770.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 29 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 64DFA7F01B907BC5400F214AAE94B0B8 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 File_Info : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V0770.bin FileVersion : 1307QM_0202_V0770 Flash now Erase region , wait ... Write data , wait ... Write : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V0770.bin Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
08-16-2015, 08:58 | #24279 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Nokia 225DS restart on logo repaired by flashing- Code: Core : v2.10 , MTKx FlashEngine : v8.1 Verify files ... MAUI : RM-1011_ROM_eMP_20.10.11 VIVA : RM-1011_VIVA_eMP_20.10.11 LANG : RM-1011_LANG_PACK_ROM_MH_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_20.10.11_002 JMPT : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_20.10.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 18 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : C145F72B41B9E7F19CC73D8CEA7CF980 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.20.10.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_20.10.11 SecureDecrypt : RM-1011_VIVA_eMP_20.10.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_MH_eMP_20.10.11_002 SecureDecrypt : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_20.10.11_002 SecureDecrypt : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_20.10.11_002 OVRLP : 000069B900000001 PHPID : PEARL.20.10.11.p1 === Backup Enabled Reading RPL backup... Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info : IMEI : 3564780683***** BBUID : C145F72B41B9E7F19CC73D8CEA7CF980 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 356478068*****_MTK_2nd.mtsec === Backup OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_20.10.11 Write : RM-1011_LANG_PACK_ROM_MH_eMP_20.10.11_002 Write : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_20.10.11_002 Write : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_20.10.11_002 Write : RM-1011_VIVA_eMP_20.10.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_20.10.11 [VERIFY] DONE : RM-1011_LANG_PACK_ROM_MH_eMP_20.10.11_002 [VERIFY] DONE : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_20.10.11_002 [VERIFY] DONE : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_20.10.11_002 [VERIFY] DONE : RM-1011_VIVA_eMP_20.10.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:55 Reboot phone Ok Connect phone on selected interface... |
08-16-2015, 09:12 | #24280 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | QMOBILE C10 SPD6531 READ SECUTiTY CODE DONE Code: Operation : Read User Code [ v1.03 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 32 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Check data... Can take some time User Code : 3497 Done! Elapsed: 00:00:07 Reconnect Power/Cable! |
The Following User Says Thank You to Luckey1 For This Useful Post: |
08-16-2015, 09:15 | #24281 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | MMX A99 hang issue solved by Format- Quote:
08-16-2015, 09:46 | #24282 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | QMobile X30 4.4.2 Operation : Flash Code: Chinese Miracle II [MTK module] v 1.25 Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.25 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A483447326111015A9484652299 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : a2G4 [eMMC] : FLASH_CID : 90014A483447326111015A9484652299 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:11 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4050ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:48 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:41 Update RomInfo done Done! Elapsed: 00:04:02 Reconnect Power/Cable! |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
08-16-2015, 10:17 | #24283 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | FLY-A106 Read Unlock Code Done Code: Operation : Read User Code [ v1.03 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 135 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0017 0000 [0] Flash VEN : Winbond , W25Q64 [0] Flash CAP : 00800000 Check data... Can take some time User Code : 147856 Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
The Following User Says Thank You to DUNIYA JAMAL For This Useful Post: |
08-16-2015, 11:28 | #24284 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Qmobile A65 Read Pattern Lock Done Code: Operation : Check / Read Info [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 101 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040301A3754B90D5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040301A3754B90D5 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : A65 ProdModel : QMobile A65 Device : A65 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : A65_MP_130910 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Read PatternLock [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 101 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040301A3754B90D5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040301A3754B90D5 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1323 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 245896 Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
08-16-2015, 12:09 | #24285 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Comilla
Member: 465069 Status: Offline Sonork: 100.1661026 Thanks Meter: 190 | Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc Quote:
