09-01-2015, 09:36 | #24781 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Qmobile X6 memory full error Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
09-01-2015, 09:38 | #24782 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | pentech p7040p unlock by imei Code: Device: Pantech-P7040P How to enter unlock code: - Power-On phone with wrong sim-card, you will be asked for a code Checking data, wait... Device: Pantech-P7040P imei: 013134000151268 Code: 37140773 |
09-01-2015, 09:39 | #24783 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | nokia 108 write flash Code: Verify files ... MAUI : RM-944_ROM_eMP_12.06.11 VIVA : RM-944_VIVA_eMP_12.06.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 JMPT : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 36 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 28859C0D2A95643D653100082C77AE6A BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.10.04.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_12.06.11 SecureDecrypt : RM-944_VIVA_eMP_12.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 OVRLP : 000069B900000001 PHPID : Bree.10.04.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001B000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_12.06.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 Write : RM-944_VIVA_eMP_12.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_12.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_12.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:04 Reboot phone Ok Connect phone on selected interface... |
09-01-2015, 09:40 | #24784 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Nokia 220 write flash Code: Verify files ... MAUI : RM-944_ROM_eMP_12.06.11 VIVA : RM-944_VIVA_eMP_12.06.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 JMPT : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 11 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 5BA23754F6E967118ED490D8999941EA BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.11.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_12.06.11 SecureDecrypt : RM-944_VIVA_eMP_12.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 OVRLP : 000069B900000001 PHPID : Bree.11.01.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001B000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_12.06.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 Write : RM-944_VIVA_eMP_12.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_12.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_12.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_12.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_12.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:00 Reboot phone Ok Connect phone on selected interface... Core : v2.09 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm949__09.05.mcusw PPM : rm949__09.05.ppm_m2 CNT : rm949__09.05.image_m2_059S5K6 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : 50A904093018EAB4 IF Resp Data : 50A9070100030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : QUARK_1340.100_M1S1 QUARK EEP config Ok FLASHID : 20004000 , [ MuxOneNAND ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 356698051095827 IMEI 2 : 356698051095835 Phone Product Code : 059S5K6 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356698051095827_XG618_CRT.rpl ===Flashing [MCU]=== Processing file : rm949__09.05.mcusw Region count : 8 00 : [ PSI ] : psi_flash_unsigned.fls 01 : [ BCore ] : slb_signed.fls 02 : [ Code ] : main_toc_signed.fls 03 : [ Code ] : rm949__09.05.mcusw_signed_mcusw.fls 04 : [ Code ] : swap_signed.fls 05 : [ Cust ] : dynsw.fls 06 : [ Code ] : aeneas_signed.fls 07 : [ Code ] : fota_signed.fls Parse done , flashing now Flash : 00 : psi_flash_unsigned.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x00090000 , Len : 0x00020000 Erase now... Erase done Region Start : 0x00090000 , Data Len : 0x00010FB0 Region Load done Write done psi_flash_unsigned.fls image flash done Flash : 01 : slb_signed.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60000000 , Len : 0x00040000 Erase now... Erase done Region Start : 0x60000000 , Data Len : 0x00040000 Region Load done Write done slb_signed.fls image flash done Flash : 02 : main_toc_signed.fls Sending Sec-Pack SecInfo Area : 0x0002 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60040000 , Len : 0x00000400 Erase now... Erase done Region Start : 0x60040000 , Data Len : 0x00000400 Region Load done Write done main_toc_signed.fls image flash done Flash : 03 : rm949__09.05.mcusw_signed_mcusw.fls Sending Sec-Pack SecInfo Area : 0x0003 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000 Erase now... Erase done Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000 Erase now... Erase done Region Start : 0x62E00000 , Data Len : 0x00F41950 Region Load done Write done rm949__09.05.mcusw_signed_mcusw.fls image flash done Flash : 04 : swap_signed.fls Sending Sec-Pack SecInfo Area : 0x0004 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000 Erase now... Erase done Region Start : 0x80000000 , Data Len : 0x00C2D2E4 Region Load done Write done swap_signed.fls image flash done Flash : 05 : dynsw.fls Sending Sec-Pack SecInfo Area : 0x0005 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62080000 , Len : 0x00100000 Erase now... Erase done Region Start : 0x62080000 , Data Len : 0x00044000 Region Load done Write done dynsw.fls image flash done Flash : 06 : aeneas_signed.fls Sending Sec-Pack SecInfo Area : 0x0006 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000 Erase now... Erase done Region Start : 0x63F79C00 , Data Len : 0x00046870 Region Load done Write done aeneas_signed.fls image flash done Flash : 07 : fota_signed.fls Sending Sec-Pack SecInfo Area : 0x0007 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC Erase now... Erase done Region Start : 0x61F00004 , Data Len : 0x00149AC8 Region Load done Write done fota_signed.fls image flash done ===Flashing [PPM]=== Processing file : rm949__09.05.ppm_m2 Region count : 1 00 : [ Cust ] : package_m2.ppm_ebl_psi.fls Parse done , flashing now Flash : 00 : package_m2.ppm_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000 Erase now... Erase done Region Start : 0x80F00000 , Data Len : 0x00537450 Region Load done Write done package_m2.ppm_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm949__09.05.image_m2_059S5K6 Region count : 1 00 : [ Cust ] : package_m2_059S5K6.image.fls Parse done , flashing now Flash : 00 : package_m2_059S5K6.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000 Erase now... Erase done Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000 Erase now... Erase done Region Start : 0xA1000000 , Data Len : 0x01DB4200 Region Load done Write done package_m2_059S5K6.image.fls image flash done Flashing done! Total flash time : 00:00:13 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 208 Dual SIM Software Info: V 09.05 12-12-13 RM-949 (c) Nokia IMEI: 356698051095827 PPM version : V 09.05 12-12-13 RM-949 (c) Nokia M2 Product code: 059S5K6 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D |
09-01-2015, 09:40 | #24785 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Nokia 301 write flash Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm839__09.04.mcusw PPM : rm839__09.04.ppm_e3 CNT : rm839__09.04.image_e3_059R1C4 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : 50A9040920007274 IF Resp Data : 50A9070100030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : QUARK_1337.500_M1S1 QUARK EEP config Ok FLASHID : 20004000 , [ MuxOneNAND ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 357885053471523 IMEI 2 : 357885053471531 Phone Product Code : 059T111 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357885053471523_XG618_CRT.rpl ===Flashing [MCU]=== Processing file : rm839__09.04.mcusw Region count : 8 00 : [ PSI ] : psi_flash_unsigned.fls 01 : [ BCore ] : slb_signed.fls 02 : [ Code ] : main_toc_signed.fls 03 : [ Code ] : rm839__09.04.mcusw_signed_mcusw.fls 04 : [ Code ] : swap_signed.fls 05 : [ Cust ] : dynsw.fls 06 : [ Code ] : aeneas_signed.fls 07 : [ Code ] : fota_signed.fls Parse done , flashing now Flash : 00 : psi_flash_unsigned.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x00090000 , Len : 0x00020000 Erase now... Erase done Region Start : 0x00090000 , Data Len : 0x00010FB0 Region Load done Write done psi_flash_unsigned.fls image flash done Flash : 01 : slb_signed.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60000000 , Len : 0x00040000 Erase now... Erase done Region Start : 0x60000000 , Data Len : 0x00040000 Region Load done Write done slb_signed.fls image flash done Flash : 02 : main_toc_signed.fls Sending Sec-Pack SecInfo Area : 0x0002 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60040000 , Len : 0x00000400 Erase now... Erase done Region Start : 0x60040000 , Data Len : 0x00000400 Region Load done Write done main_toc_signed.fls image flash done Flash : 03 : rm839__09.04.mcusw_signed_mcusw.fls Sending Sec-Pack SecInfo Area : 0x0003 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000 Erase now... Erase done Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000 Erase now... Erase done Region Start : 0x62E00000 , Data Len : 0x00F0D4CC Region Load done Write done rm839__09.04.mcusw_signed_mcusw.fls image flash done Flash : 04 : swap_signed.fls Sending Sec-Pack SecInfo Area : 0x0004 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000 Erase now... Erase done Region Start : 0x80000000 , Data Len : 0x00C2BCD0 Region Load done Write done swap_signed.fls image flash done Flash : 05 : dynsw.fls Sending Sec-Pack SecInfo Area : 0x0005 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62080000 , Len : 0x00100000 Erase now... Erase done Region Start : 0x62080000 , Data Len : 0x00044000 Region Load done Write done dynsw.fls image flash done Flash : 06 : aeneas_signed.fls Sending Sec-Pack SecInfo Area : 0x0006 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000 Erase now... Erase done Region Start : 0x63F79C00 , Data Len : 0x00046870 Region Load done Write done aeneas_signed.fls image flash done Flash : 07 : fota_signed.fls Sending Sec-Pack SecInfo Area : 0x0007 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC Erase now... Erase done Region Start : 0x61F00004 , Data Len : 0x00149890 Region Load done Write done fota_signed.fls image flash done ===Flashing [PPM]=== Processing file : rm839__09.04.ppm_e3 Region count : 1 00 : [ Cust ] : package_e3.ppm_ebl_psi.fls Parse done , flashing now Flash : 00 : package_e3.ppm_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000 Erase now... Erase done Region Start : 0x80F00000 , Data Len : 0x0074946C Region Load done Write done package_e3.ppm_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm839__09.04.image_e3_059R1C4 Region count : 1 00 : [ Cust ] : package_e3_059R1C4.image.fls Parse done , flashing now Flash : 00 : package_e3_059R1C4.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000 Erase now... Erase done Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000 Erase now... Erase done Region Start : 0xA1000000 , Data Len : 0x01B46200 Region Load done Write done package_e3_059R1C4.image.fls image flash done Flashing done! Total flash time : 00:00:12 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 301 Dual SIM Software Info: V 09.04 03-12-13 RM-839 (c) Nokia IMEI: 357885053471523 PPM version : V 09.04 03-12-13 RM-839 (c) Nokia E3 Product code: 059T111 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... ===== WARNING ===== Battery voltage is NOT enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:00:57 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
09-01-2015, 09:41 | #24786 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | nokia 500 write flash Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm934_14.0.5.mcusw.fls PPM : rm934_14.0.5_059S9V4_m1.rofs.fls CNT : rm934_14.0.5_059S9V4_m1.image.fls Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 221 [XMM2210 QIMING] IF uCHIPID : 19421409828465D8 IF Resp Data : 194200021C030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : 1_1345.300_MKEYSKEY QIMING EEP config Ok FLASHID : 52F00000 , [ NOR ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358355055740621 IMEI 2 : 358355055740639 Phone Product Code : 059S9V4 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358355055740621_XG221_CRT.rpl ===Flashing [MCU]=== Processing file : rm934_14.0.5.mcusw.fls Region count : 2 00 : [ PSI ] : rm934_14.0.5.mcusw.fls.fls 01 : [ Code ] : rm934_14.0.5.mcusw.fls.fls Parse done , flashing now Flash : 00 : rm934_14.0.5.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40000000 , Len : 0x00020000 Erase done Region Start : 0x40000000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done rm934_14.0.5.mcusw.fls.fls image flash done Flash : 01 : rm934_14.0.5.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40040000 , Len : 0x00020000 Erase done Erase area 0x01 , Start 0x40060000 , Len : 0x00160000 Erase done Erase area 0x02 , Start 0x40340000 , Len : 0x02540000 Erase done Erase area 0x03 , Start 0x47E00000 , Len : 0x00040000 Erase done Region Start : 0x40040000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40060000 , Data Len : 0x00160000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40340000 , Data Len : 0x02076490 Region Load done Wait for phone write all data ... Write done rm934_14.0.5.mcusw.fls.fls image flash done ===Flashing [PPM]=== Processing file : rm934_14.0.5_059S9V4_m1.rofs.fls Region count : 1 00 : [ Cust ] : rofs_ebl_psi.fls Parse done , flashing now Flash : 00 : rofs_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x42880000 , Len : 0x00F80000 Erase done Region Start : 0x42880000 , Data Len : 0x005EF1C4 Region Load done Wait for phone write all data ... Write done rofs_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm934_14.0.5_059S9V4_m1.image.fls Region count : 1 00 : [ Cust ] : rm934_14.0.5_059S9V4_m1.image.fls.image.fls Parse done , flashing now Flash : 00 : rm934_14.0.5_059S9V4_m1.image.fls.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x43800000 , Len : 0x04600000 Erase done Erase area 0x01 , Start 0x47E40000 , Len : 0x000E0000 Erase done Region Start : 0x43800000 , Data Len : 0x02800000 Region Load done Wait for phone write all data ... Write done rm934_14.0.5_059S9V4_m1.image.fls.image.fls image flash done Flashing done! Total flash time : 00:02:08 Reboot phone now... Reading Phone Info.... Connected phone - 500 Software Info: V 14.0.5 21-04-14 RM-934 (c) Nokia IMEI: 358355055740621 PPM version : 4116c9d7c1b4decc0c6e915eeb34a15af40a6172 Product code: 059S9V4 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:02:41 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
09-01-2015, 09:42 | #24787 (permalink) |
Freak Poster Join Date: Oct 2007 Location: GOA
Member: 600436 Status: Offline Thanks Meter: 219 | infinity chineese miracle 2 succesefuuly mt6572 Card found: S/N 8E6E:0129 Chinese Miracle II [MTK module] v 1.27 Operation : Read Flash [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D4201DFA6C8C2215F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D4201DFA6C8C2215F [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : XOLO ProdName : A600 ProdModel : A600 Device : A600 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_lava72_sp05w.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / lava72_sp05w / EMMC FW Size : 678 MiB Scatter saved to : C:\Documents and Settings\Administrator\My Documents\MT6572__XOLO__A600__A600__4.2.2__ALPS.JB 3.MP.V1\ All done! Done! Elapsed: 00:03:33 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : lava72_sp05w , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.27 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D4201DFA6C8C2215F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D4201DFA6C8C2215F [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : lava72_sp05w , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000000E4E80000 Flash Pre-Erase Done, time used : 00:00:11 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lava72_sp05w.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:01:00 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:27 Update RomInfo done Done! Elapsed: 00:01:58 Reconnect Power/Cable! Operation : Format FileSystem [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D4201DFA6C8C2215F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D4201DFA6C8C2215F [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 3 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
09-01-2015, 09:42 | #24788 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Nokia 501 write flash Code: Selected FlashSettings : Manual File [Ok] : rm902_14.0.5.mcusw.fpsx File [Ok] : rm902_14.0.3_059R2T6_m1_245_03_439532.rofs.fpsx File [Ok] : rm902_14.0.3_059R2T6_m1_245_03_439532.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049B22609A6CA6832CAECC900 ASIC ID_E : 00000C2016100040 PUBLIC ID : 8C2098B6A06A9E4449B22609A6CA6832CAECC900 XGCHIP ID : 8C2098B6A06A9E44 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 358139055563328 IMEI [2] : 358139055563336 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358139055563328_XG223_CRT.rpl PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E === SW Version Check === - > UPGRADE === SW Version Check === === Flashing MCU === Processing file : rm902_14.0.5.mcusw.fpsx Erasing... Writing... Total blocks : 82 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 81 blocks were writen === Flashing PPM === Processing file : rm902_14.0.3_059R2T6_m1_245_03_439532.rofs.fpsx Erasing... Writing... Total blocks : 13 Writing RKH CRT [PPM] File processed Ok, 13 blocks were writen === Flashing CNT === Processing file : rm902_14.0.3_059R2T6_m1_245_03_439532.image.fpsx Erasing... Writing... Total blocks : 59 File processed Ok, 59 blocks were writen Flashing done , total time : 00:01:02 Reboot phone to service mode... Reading Phone Info.... Connected phone - 501 Software Info: V 14.0.5 21-04-14 RM-902 (c) Nokia IMEI: 358139055563328 PPM version : 3e47f674686281ebf509878b0ace161de7e77f78 Product code: 059T234 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D |
09-01-2015, 09:42 | #24789 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Nokia 502 write flash Code: Selected FlashSettings : Manual File [Ok] : rm921_14.0.6.mcusw.fpsx File [Ok] : rm921_14.0.2_059S4B4_m1_2032_02_452463.rofs.fpsx File [Ok] : rm921_14.0.2_059S4B4_m1_2032_02_452463.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C2016100040498A29899AA148B24C395255 ASIC ID_E : 00000C2016100040 PUBLIC ID : F773C3293704A45C498A29899AA148B24C395255 XGCHIP ID : F773C3293704A45C ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok Connect phone on selected interface... Core : v2.09 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual File [Ok] : rm921_14.0.6.mcusw.fpsx File [Ok] : rm921_14.0.2_059S4B4_m1_2032_02_452463.rofs.fpsx File [Ok] : rm921_14.0.2_059S4B4_m1_2032_02_452463.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot not done , unable continue Connect phone on selected interface... Core : v2.09 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual File [Ok] : rm921_14.0.6.mcusw.fpsx File [Ok] : rm921_14.0.2_059S4B4_m1_2032_02_452463.rofs.fpsx File [Ok] : rm921_14.0.2_059S4B4_m1_2032_02_452463.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C2016100040498A29899AA148B24C395255 ASIC ID_E : 00000C2016100040 PUBLIC ID : F773C3293704A45C498A29899AA148B24C395255 XGCHIP ID : F773C3293704A45C ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 351741061199505 IMEI [2] : 351741061199513 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351741061199505_XG223_CRT.rpl PAPUBkeys : 7EC22006F565793C24924878FBAB9CA6CBE42C35 === SW Version Check === - > UPGRADE === SW Version Check === === Flashing MCU === Processing file : rm921_14.0.6.mcusw.fpsx Erasing... Writing... Total blocks : 82 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : 7EC22006F565793C24924878FBAB9CA6CBE42C35] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 81 blocks were writen === Flashing PPM === Processing file : rm921_14.0.2_059S4B4_m1_2032_02_452463.rofs.fpsx Erasing... Writing... Total blocks : 13 Writing RKH CRT [PPM] File processed Ok, 13 blocks were writen === Flashing CNT === Processing file : rm921_14.0.2_059S4B4_m1_2032_02_452463.image.fpsx Erasing... Writing... Total blocks : 51 File processed Ok, 51 blocks were writen Flashing done , total time : 00:00:57 Reboot phone to service mode... Reading Phone Info.... Connected phone - 502 Software Info: V 14.0.6 10-07-14 RM-921 (c) Nokia IMEI: 351741061199505 PPM version : 39ca71fbc2cbcf327bf4554c40472b4e97f23326 Product code: 059V3Z4 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
09-01-2015, 09:59 | #24790 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile Noir i5 Flashing Done :) Code: Operation : Flash [ v1.27 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040505A1B5885109 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040505A1B5885109 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s4700 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000000E5600000 Flash Pre-Erase Done, time used : 00:00:13 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4700.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Done! Elapsed: 00:07:30 Reconnect Power/Cable! Finish at : [01-Sep-2015 / 12:49:58 PM] |
09-01-2015, 10:16 | #24791 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | World First Intex Cloud 3g Candy Pattern Read Done World first Intex Cloud 3g Candy Read pattern Done Nv Done Copy pasters Still behind Us |
09-01-2015, 11:47 | #24792 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | QMOBILE I5i file read Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040501A168B9917D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A168B9917D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : QMobile i5i ProdModel : QMobile i5i Device : QMobile i5i AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_s4300ap.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / s4300ap / EMMC FW Size : 1192 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6582__QMobile__QMobile i5i__QMobile i5i__4.4.2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:05:23 |
09-01-2015, 11:48 | #24793 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Samsung i8552 file read Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393051E1CC2B98A03B DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 11010030303447393051E1CC2B98A03B [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Skip HSUSB init Brand : samsung ProdName : delos3gzc ProdModel : GT-I8552 Device : delos3gchn AndroidVer: 4.1.2 MTKxCPU : MSM8225Q MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_hzcenon72_wet_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / hzcenon72_wet_jb3 / EMMC FW Size : 788 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MSM8225Q__samsung__GT-I8552__delos3gchn__4.1.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:25:42 |
09-01-2015, 11:49 | #24794 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | G FIVE G10 mini file read Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 71 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447583898339871A3 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447583898339871A3 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : alps ProdName : G10_mini ProdModel : GFIVE G10 mini Device : G10_mini AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 [Read Ok] : preloader_vanzo72_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / vanzo72_cwet_kk / EMMC FW Size : 777 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__alps__GFIVE G10 mini__G10_mini__4.4.2__ALPS.KK1.MP7.V1\ All done! Done! Elapsed: 00:04:01 |
09-01-2015, 12:05 | #24795 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lava kkt9+ read firmware and format done read firmware Code: Operation : Read FullFlash [ v1.03 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : lava Model Name : kkt9+ Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32__lava-kkt9+.bin Done! Elapsed: 00:02:29 Reconnect Power/Cable! Code: Operation : Format File System [ v1.03 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 0A Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 O üBoot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following User Says Thank You to rehmani For This Useful Post: |
