09-06-2015, 08:20 | #25036 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
09-06-2015, 08:21 | #25037 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Voice V120 Flashing Done Code: Operation : Flash [ v1.03 ] ======= Flash Files set for flashing : [ MCU ] : _20141204_174419_FullFlash.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 27 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 ======= Flashing MCU Mapping file ... Mapping done Processing file : _20141204_174419_FullFlash.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Elapsed: 00:01:21 Reconnect Power/Cable! |
The Following User Says Thank You to Luckey1 For This Useful Post: |
09-06-2015, 08:28 | #25038 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile Noir X2 Nand mtk 6571 Internal memory Full Done Code: Operation : Format FileSystem [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
09-06-2015, 10:03 | #25040 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Pakistan TDM
Member: 1330570 Status: Offline Sonork: 100.1611533 Thanks Meter: 408 | VGO Tel V2 lite read factory flash file and formate with CM2MTK Read flash file :- Code: Operation : Read Flash [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1101003030344739301096964EC481B5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 1101003030344739301096964EC481B5 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : G-Mobile ProdName : VENTURE_V2_LITE ProdModel : VENTURE_V2_LITE Device : VENTURE_V2_LITE AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 [Read Ok] : preloader_ckt72_we_72_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / ckt72_we_72_kk / EMMC FW Size : 933 MiB Scatter saved to : C:\Documents and Settings\Administrator\Desktop\MT6572__G-Mobile__VENTURE_V2_LITE__VENTURE_V2_LITE__4.4.2__ALPS.KK1.MP6.V1\ All done! Done! Elapsed: 00:04:33 Reconnect Power/Cable! Formate logs:- Code: Operation : Format FileSystem [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1101003030344739301096964EC481B5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 1101003030344739301096964EC481B5 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 2 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following User Says Thank You to Bazeed_khan17 For This Useful Post: |
09-06-2015, 10:19 | #25041 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | micromaxx a114 read ff format and flash done read ff Code: Operation : Read Flash [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3ED98615F DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3ED98615F [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Micromax ProdName : A114 ProdModel : A114 Device : Micromax_A114 AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.MP.V1.6 [Read Ok] : preloader_s8313a.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / s8313a / EMMC FW Size : 680 MiB Scatter saved to : D:\MT6582__Micromax__A114__Micromax_A114__4.2.2__ALPS.JB5.MP.V1.6\ All done! Done! Elapsed: 00:03:24 Reconnect Power/Cable! format Code: Operation : Format FileSystem [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3ED98615F DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3ED98615F [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! Code: Scatter Load Ok , BaseBand : MT6582 , Project : s8313a , Storage : EMMC Files found : 13 , Set to Flash : 12 Ready to Flash! Operation : Flash [ v1.28 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3ED98615F DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3ED98615F [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s8313a , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000000E3000000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s8313a.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:02:10 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:31 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:01 Reconnect Power/Cable! |
09-06-2015, 10:54 | #25042 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Nokia 206 Code: Core : v2.10 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q8L5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:20 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:33 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:28 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q8L5 Image : package_m2_059Q8L5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:04:30 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:26 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0xA5A8 Flashing done! Total flash time : 00:08:41 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:28 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
09-06-2015, 11:13 | #25043 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | intex aqua y2 remote read pattern lock/read flash file read pattern lock Code: Operation : Read PatternLock [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 101 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 700100533130303034086272677A22A1 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : 40001 [eMMC] : FLASH_CID : 700100533130303034086272677A22A1 [eMMC] : FLASH_LEN : 0x00000000E4000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1323 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 96523 Done! Elapsed: 00:00:21 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 101 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 700100533130303034086272677A22A1 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : 40001 [eMMC] : FLASH_CID : 700100533130303034086272677A22A1 [eMMC] : FLASH_LEN : 0x00000000E4000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Intex ProdName : a101e_ax_kewang_s4018 ProdModel : Aqua Y2 Remote Device : Aqua_Y2_Remote AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : Intex_Aqua_Y2_Remote_V10_Indian_SER [Read Ok] : preloader_a101e_ax_kewang_s4018.b [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / a101e_ax_kewang_s40 / EMMC FW Size : 887 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__Intex__Aqua Y2 Remote__Aqua_Y2_Remote__4.4.2__Intex_Aqua_Y2_Remote_V10_Indian_SER\ All done! Done! Elapsed: 00:04:09 Reconnect Power/Cable! |
09-06-2015, 11:31 | #25044 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 371 | Videocon Z30 Pace Hang On Logo Done Code: Operation : Format File System [ v1.03 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to ishant For This Useful Post: |
09-06-2015, 11:33 | #25045 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 371 | Karboon K76+ Format Done Code: Operation : Format File System [ v1.03 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 33 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 0A Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C2 0025 0038 0000 [0] Flash VEN : Macronix , MX25 [0] Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:59 Reconnect Power/Cable! |
09-06-2015, 12:00 | #25046 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Nokia 110 Code: Core : v2.10 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm827__03.04.mcusw PPM : rm827__03.04.ppm_m2 CNT : rm827__03.04.image_m2_059N2R0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm827__03.04.mcusw Image : rm827__03.04.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:01:59 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:33 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x74A0 ===Flashing [PPM]=== File : rm827__03.04.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:16 Write , Start : 0x41BC0000 , Len : 0x00304AA4 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0xE7C0 ===Flashing [CNT]=== File : rm827__03.04.image_m2_059N2R0 Image : package_m2_059N2R0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:05 Write , Start : 0x421C0000 , Len : 0x00DE0000 Flashing , wait ... Region flash done, time : 00:00:21 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0x6508 Flashing done! Total flash time : 00:04:35 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:05:10 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
09-06-2015, 12:16 | #25047 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Voice V750_Read User Code Time Only 00:12" Successful, Done .:: BY ::. ..::: Chinese Miracle-2 SPD :::.. Code:
The Following 4 Users Say Thank You to kabul For This Useful Post: |
09-06-2015, 12:21 | #25048 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | CLUB M300_Hang on Logo Just Format Time Only 00:14" Successful, Done .:: BY ::. ..::: Chinese Miracle-2 SPD :::.. Code:
09-06-2015, 12:25 | #25049 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile B85_Read User Code Time Only 00:07" Successful, Done .:: BY ::. ..::: Chinese Miracle-2 MTK :::.. Code:
The Following 5 Users Say Thank You to kabul For This Useful Post: |
09-06-2015, 12:43 | #25050 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | QMOBILE A300 wirte bin file Code: Load File File_Info : s7810bp FileVersion : MT6572 Load File Ok Operation : Flash [ v1.28 ] ======= Flash Files set for flashing : [ MCU ] : MTK6572_1409161632.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048602A3C346B02F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048602A3C346B02F [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : QMobile ProdName : A300 ProdModel : QMobile A300 Device : QMobile A300 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.P65 ISPFF ID : 6572 , TARGET ID : 6572 FlashFile is differs from eMMC settings, continue by user request Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MTK6572_1409161632.bin Init Ok , Sending blocks ... Write done , 2988 blocks sent Done! Elapsed: 00:09:05 |
