10-30-2017, 10:10 | #45901 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile j5 Format Done 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3332387653004209061AE4 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D42005376E41AA309 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xE6C52A7DFC3035CB759339E45C20AEE1 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
10-30-2017, 11:34 | #45902 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X30 Hang Logo Write File Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111015E7AA2B322B1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111015E7AA2B322B1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C255052A6EAE48A2CAFD04E9ACC INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TINNO ProdName : QMobile X30 ProdModel : QMobile X30 Device : QMobile X30 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111015E7AA2B322B1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111015E7AA2B322B1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C255052A6EAE48A2CAFD04E9ACC INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3479 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4050ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:56 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:22 Reconnect Power/Cable! |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
10-30-2017, 11:53 | #45903 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile D3 SPD6531 Logo Stuck Fix Only Formate With Infinity CM2 Card found: S/N : A19EC787 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6531 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post: |
10-30-2017, 11:57 | #45904 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I2 Power SPD77x FRP Reset Done With In Sec By Infinity CM2 Card found: S/N : A19EC787 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000011DEF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
10-30-2017, 12:53 | #45905 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | QMobile k150 format/repair done :) Code: Operation : Format File System / Reset Settings [ v1.25 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 52 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
10-30-2017, 13:03 | #45906 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Mindanao Philippines
Member: 2752651 Status: Offline Thanks Meter: 182 | Oppo Neo 5 1201 16GB Assembled In China, Read Pattern And Read Firmware Done Code: Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100463331324D4206FF909BAB3303 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM213 [eMMC] : FLASH_CID : 150100463331324D4206FF909BAB3303 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xE5C818C39F8F4D22CB1924761AF6DDCB INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok Reading data ... Get Locks ... PatternLock Sequnce : 25874 Done! Elapsed: 00:00:26 Reconnect Power/Cable! Code: Start at : [10/30/2017 / 6:56:49 PM] Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100463331324D4206FF909BAB3303 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM213 [eMMC] : FLASH_CID : 150100463331324D4206FF909BAB3303 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xE5C818C39F8F4D22CB1924761AF6DDCB INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... USBDL : Init HSUSB Ok! Brand : OPPO ProdName : 1201 ProdModel : 1201 Device : 1201 AndroidVer: 5.1 MTKxCPU : MT6582 MTKxPRJ : 1201EX-A_11_A.16_170329 [Read Ok] : preloader_oppo6582_15066.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : EBR3 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / oppo6582_15066 / EMMC Android Info saved HWConfig Info saved FW Size : 2451 MiB Scatter saved to : C:\Users\Meerl\Desktop\OPPO Neo 5 1201 16GB SPFlashtool\OPPO Neo 5 1201 16GB SPFlashtool\MT6582__OPPO__1201__1201__5.1__1201EX-A_11_A.16_170329\ All done! Done! Elapsed: 00:11:12 Reconnect Power/Cable! Finish at : [10/30/2017 / 7:08:02 PM] |
The Following 2 Users Say Thank You to meerl329 For This Useful Post: |
10-30-2017, 13:48 | #45907 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile Noir j5 FullFlash Done Scatter Load Ok , BaseBand : MT6735 , Project : gionee6737t_66_m0 , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : J5 Device CPU : MT6737T Device IntName : J5 Device Version : 6.0 Device Compile : 05-09-16 9:03:50 AM Device Project : WBL7365QM_0204_T5562 Device ExtInfo : J5 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333238A66400420F2597E0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D420064A6E097A30F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xE6C52A7D1DA3699D3BB313D0B23644B8 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6735 , Project : gionee6737t_66_m0 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3787 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000004D80000 Erase : 0x0000000006B00000-0x000000039C280000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0016 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:11:24 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:11:45 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
10-30-2017, 14:12 | #45908 (permalink) | |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile s3 read pattern lock done with king infinity cm2 QMOBILE S3 READ PATTERN LOCK DONE WITH KING INFINITY CM2 Quote:
If You Like My Post Press Thanks Br ShahiD | |
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post: |
10-30-2017, 14:13 | #45909 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Karbonn AURA 4G SPD9830 Frp done and Read flash also done Code: Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : sp9832a_2h11_4mvoltesea Model Brand : Karbonn Model Device: sp9832a_2h11_volte AndrVersion : 6.0 BaseBand CPU: SP9832A_2H11_VOLTE CompileDate : 10-03-2017 AM 6:33:21 Project Ver : UTLAura_Power_4Gv1006_10032017 Model Ext : Karbonn Aura Power 4G ExtraInfo : HWInfo exists!!! This phone have DYNAMIC HW settings!!! Elapsed: 00:00:29 Reconnect Power/Cable! Code: Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000011B7F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : sp9832a_2h11_4mvoltesea Model Brand : Karbonn Model Device: sp9832a_2h11_volte AndrVersion : 6.0 BaseBand CPU: SP9832A_2H11_VOLTE Project Ver : UTLAura_Power_4Gv1006_10032017 Model Ext : Karbonn Aura Power 4G [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : nvitem_l.bin [Read Ok] : sharkl_cp1.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : l__WPH_arm7.bin [Read Ok] : PM_arm7_sys.bin [Read Ok] : logo_720x1280.bin [Read Ok] : fblogo_720x1280.bin [Read Ok] : wcn_fdl.bin [Read Ok] : AA_MARLIN.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : udc_config.bin [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2642 MiB Saved to : C:\Users\SAMobiles\Desktop\SP9832A_2H11_VOLTE_sp9832a_2h11_volte_6.0_UTLAura_Power_4Gv1006_10032017_Karbonn_Aura_Power_4G\ Done! Elapsed: 00:11:00 Reconnect Power/Cable! |
The Following User Says Thank You to princesaddam For This Useful Post: |
10-30-2017, 14:17 | #45910 (permalink) | |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x4 pro read password done with king infinity cm2 QMOBILE X4 PRO READ PASSWORD DONE WITH KING INFINITY CM2 Quote:
The Following 3 Users Say Thank You to A.G.Shahid For This Useful Post: |
10-30-2017, 14:20 | #45911 (permalink) | |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x700 pro reset frp lock done with king infinity cm2 QMOBILE X700 PRO RESET FRP LOCK DONE WITH KING INFINITY CM2 Quote:
10-30-2017, 14:34 | #45912 (permalink) | |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x2 hang on logo done with king infinity cm2 QMOBILE X2 HANG ON LOGO DONE WITH KING INFINITY CM2 Quote:
10-30-2017, 14:38 | #45913 (permalink) | |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x32 reset frp done with king infinity cm2 QMOBILE X32 RESET FRP DONE WITH KING INFINITY CM2 Quote:
10-30-2017, 15:21 | #45914 (permalink) |
Freak Poster Join Date: Feb 2017 Location: INDIA
Member: 2682035 Status: Offline Thanks Meter: 22 | Micromax e313 frp remove by great cm2 in one click Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 7001005631303030385018ADBA3F131F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80001 [eMMC] : FLASH_CID : 7001005631303030385018ADBA3F131F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 [eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB] DEV RID : 0x278ABE87AED9990FFC8AEE350BD08459 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following User Says Thank You to nihang For This Useful Post: |
10-30-2017, 17:26 | #45915 (permalink) | |
Member: 2682035 Status: Offline Thanks Meter: 22 | Quote:
Sent from my Redmi 3S using Tapatalk | |
