08-06-2018, 04:54 | #51916 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile I8i Remove Gmail id done With cm2 Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000011A3F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
08-06-2018, 05:03 | #51917 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Itel S12 Remove Gmail id done With Cm2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464E36324D420349BDE42A9457 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM26N [eMMC] : FLASH_CID : 150100464E36324D420349BDE42A9457 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0386520D04E2C5BC3AF67BDD35801B05 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
08-06-2018, 05:04 | #51918 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | QMobile W50 Remove Code DOne With cm2 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000147DF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
08-06-2018, 05:22 | #51919 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Huawei Y520-U22 MT6572 Logo Stuck Fix By Flashing With Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 94 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611102FE9312695255 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611102FE9312695255 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F39597F1A25BEC26E7BEC3B078AA INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:41 Reconnect Power/Cable! |
08-06-2018, 06:28 | #51920 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | LG M153 MSM8909(10-17-2017)Latest Ver Read File Done With King Infinity CM2 Card found : A19EC787 , v0137 Infinity-Box LG Service Tool [ LGS ] v1.03 Operation : Read Firmware [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! DevInfo : MSM8909__LG-M153__M15311c__V11c__AOSv6.0.1__LGM153AT-00-V11c-CRK-US-OCT-17-2017-ARB00+0 Reading Flash Content ... [Read Ok] : gpt_main.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : tz.mbn [Read Ok] : rpm.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : sec.dat [Read Ok] : rawdata.img [Read Ok] : persist_lg.img [Read Ok] : calibration.img [Read Ok] : misc.img [Read Ok] : persist.img [Read Ok] : laf.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : fact.img [Read Ok] : system.img [Read Ok] : gpt_backup.bin Android Info saved! Read finished! Configuration : MSM8909 / 6.0.1 / V11c Firmware Size : 3215 MiB Done! Elapsed: 00:03:36 |
08-06-2018, 07:57 | #51921 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I5.5 SPD77xx Logo Hang Fix Only Formate With Infinity CM2 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 102 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001279F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
08-06-2018, 08:52 | #51923 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | JumA JM8 Read Flahs DOne With cm2 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454838434434012FD05B15637D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 4DC8H [eMMC] : FLASH_CID : 700100454838434434012FD05B15637D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0x0386520DE9D8D49CFCE40AB6B5FA4283 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : JumA ProdName : JM8 ProdModel : JM8 Device : JM8 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-m0.mp1-V2.34_long6580.weg.m_P6 [Read Ok] : preloader_long6580_weg_m.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / long6580_weg_m / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1420 MiB Scatter saved to : C:\Users\WARIS GSM\Desktop\MT6580__JumA__JM8__JM8__6.0__alps-mp-m0.mp1-V2.34_long6580.weg.m_P6\ All done! Done! Elapsed: 00:06:43 Reconnect Power/Cable! |
08-06-2018, 08:53 | #51924 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile s2 hang on logo Flash done With Cm2 Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507C2A150BE928B Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507C2A150BE928B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0386520D189575173BBA131A69BC78C4 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : s5250 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3892 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:04:52 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:02 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:26 Reconnect Power/Cable! |
08-06-2018, 08:56 | #51925 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | VGOTEL_Venture_V8 Flash done With cm2 Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 450100444C32303136019D5B794263C3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6102L [eMMC] : FLASH_CID : 450100444C32303136019D5B794263C3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x0386520D8A8E0F46300EBAE63975BF4F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : keytak6580_weg_n , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3981 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:06:32 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:03 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:06:46 Reconnect Power/Cable! |
08-06-2018, 09:54 | #51926 (permalink) |
No Life Poster Join Date: Jan 2015 Location: STATE OF JAMMU & KASHMIR
Member: 2327602 Status: Offline Sonork: 100.1620953 Thanks Meter: 276 | Qmobile power 14 user code format done with scr QMOBILE POWER 14 USER CODE FORMAT DONE WITH SCR FORMAT FILE SYSTEM Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_007 866516102_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following User Says Thank You to shazzmob For This Useful Post: |
08-06-2018, 10:57 | #51927 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 138 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000131DF7000 State : 0x0001 Mount : /cache Size : 0x0000000012C00000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
08-06-2018, 11:39 | #51928 (permalink) |
08-06-2018, 11:56 | #51929 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X32 Power SPD77xx V3 FRP Reset Done With King Infinity CM2 Card found: S/N : A19EC787 , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 5.x] Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 102 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000012ABF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
