12-30-2008, 07:29 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Kolkata,Kathmandu,
Member: 306096 Status: Offline Sonork: 100.1585877 Thanks Meter: 255 | Sucessfully Unlock Konka EC003 COM3 [VCP0] selected module v2.48 Device: Konka-EC003 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: STANDARD_PCB01_GSM_MT6205B_DN.KABEC003FM_EN_FR_ES_ 4_01_918.BIN ver. sw 2: KABEC003FM_EN_FR_ES_4.01.918, 00000000 ffs offset/size: 00380000/00080000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[STANDARD_PCB01_GSM_MT6205B_DN.KABEC003FM_EN_FR_ES_ 4_01_918.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[STANDARD_PCB01_GSM_MT6205B_DN.KABEC003FM_EN_FR_ES_ 4_01_918.BIN]_20081230-121135.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ..... flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: area 0/1 ........... additional parameters detected Ok Special operation Done Write ... flash: 01227E221A2201:18E59F00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 125 sec Remove/Install battery now ! umadineshdas |
The Following 3 Users Say Thank You to umadineshdas For This Useful Post: |
12-30-2008, 17:49 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @umadineshdas Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
03-06-2009, 08:12 | #4 (permalink) | |
Freak Poster Join Date: Jan 2007
Member: 422887 Status: Offline Thanks Meter: 19 | ec003 Quote:
need me pin out please help me i can not connect the phone? | |
03-06-2009, 16:27 | #5 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
infinity box how to unlock beteel EC003 | shivashakthi | Nokia Hardware & Hardware Repair | 0 | 03-13-2009 11:45 |
Help Unlock Konka EC003 | nishue | Infinity-Box | 2 | 12-21-2008 11:02 |
29 Nov 2008: Alcatel-S319, S320, Konka-EC003 models supported | InfinitySupport | Infinity-Box | 36 | 12-12-2008 21:40 |
29 Nov 2008: Alcatel-S319, S320, Konka-EC003 models supported | zinoubinabil | Service Products News & Updates | 0 | 11-29-2008 07:56 |
Cant foud konka EC003 in MModule | .:==di@bila==:. | Infinity-Box | 10 | 11-27-2008 21:05 |
