01-11-2009, 11:13 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Shoaib Electronics
Member: 515273 Status: Offline Sonork: 100.1573940 Thanks Meter: 339 | T161L Sucessfully Unlock......... Today I unlock Huawei T161L sucessfully Thanks Infinity team Here is my logs COM6 [VCP0] selected module v1.60 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090111-150852.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090111-150852.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090111-150854.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090111-150901.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 32 sec Remove/Install battery now ! |
The Following User Says Thank You to dil_PAKISTANI For This Useful Post: |
01-11-2009, 17:16 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
01-11-2009, 18:42 | #3 (permalink) |
Freak Poster Join Date: Apr 2006 Location: UAE
Member: 265104 Status: Offline Sonork: 100.1609402 Thanks Meter: 88 | very old solution............ |
05-28-2009, 20:06 | #4 (permalink) |
Junior Member Join Date: Apr 2007 Location: Pakistan
Member: 484706 Status: Offline Sonork: [email protected] Thanks Meter: 10 | help me plz i am new for this |
05-29-2009, 22:29 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
jazz t161l Successfully Unlocked/repaired Phones By infinity box | honey_bbc2001 | Chinese Models & Cloned Phones | 0 | 07-07-2009 07:23 |
Huawei-T161L successfull unlocked | zeerik | Infinity-Box | 1 | 03-05-2009 14:08 |
JAZZ Hauwei T161L Successfully Unlocked with Infinity Box | Miftahudin | Infinity-Box | 4 | 02-14-2009 09:11 |
Huawei T161L Successfully unlocked | zeerik | Infinity-Box | 2 | 02-03-2009 18:35 |
huawei t161L succesfully unlocked | gsmbac | Infinity-Box | 2 | 11-24-2008 16:48 |
