02-04-2009, 05:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | unlock ok Huawei-T158 thanks infinty Device: Huawei-T158 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T158_eeprom-static_20090203-145821.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T158_eeprom-security_20090203-145822.B1E.bin reading eeprom-complete... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T158_eeprom-complete_20090203-145829.B1E.bin reading additional data... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T158_lock-area_20090203-145848.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 66 sec Remove/Install battery now ! |
02-04-2009, 17:20 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Huawei t158 unlock ok on vygis | el-safwa | VygisToolbox | 2 | 12-19-2014 16:51 |
huawei t158 unlock success | Satyam321 | Infinity-Box | 33 | 09-29-2009 07:36 |
kp100 and huawei T158 unlock ok... | ZIYAAD STRYKER | Infinity-Box | 0 | 02-14-2009 05:41 |
HUAWEI T158 - need unlock procedure plz | khem | SAGEM JTAG UNLOCKER | 4 | 06-22-2008 18:57 |
