04-09-2010, 04:57 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Why Still Dead here is log. COM4 [VCP0] selected module v3.11 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:FF0F:FFFF status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89887E00040004:89887E00000000 flash: 89887E00040004:89887E00000000 flash: Intel 512MBit non-mux U 64Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 89887E00040004:89887E00000000 flash: 89887E00040004:89887E00000000 flash: Intel 512MBit non-mux U 64Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 total flash region size: 04000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 03C00000 flash: 89887E00040004:89887E00000000 flash: 89887E00040004:89887E00000000 checking area [00000000]: 00080000-03FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 03C00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:03C00000-03FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 89887E00040004:89887E00000000 flash: 89887E00040004:89887E00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 89887E00040004:89887E00000000 flash: 89887E00040004:89887E00000000 Finalization Done Finished, time used: 52 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
04-09-2010, 05:00 | #2 (permalink) | |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
COM4 [VCP0] selected module v3.11 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:FF0F:FFFF status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89887E00040004:89887E00000000 flash: 89887E00040004:89887E00000000 flash: Intel 512MBit non-mux U 64Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 89887E00040004:89887E00000000 flash: 89887E00040004:89887E00000000 flash: Intel 512MBit non-mux U 64Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 total flash region size: 04000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished error: incorrect ffs address range Finished, time used: 1 min 20 sec Remove/Install battery now ! | |
04-10-2010, 12:29 | #6 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Flashed with same Phone readed File-- else search in support whether it is exist. Give us more Info abt phone( Pic etc...) so that we can upload thnx |
The Following User Says Thank You to Riteshgpt60 For This Useful Post: |
04-10-2010, 16:20 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! best way is to find same phone on your local market. if you cant do that- then do search for "E66" on support and try all files on by one |
04-23-2010, 06:29 | #9 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | BENRUI25_GEMINI_PCB01_GPRS_MT6225_S00.BR253_V18_80 __NOKIA-E66_16m_En_Fr_Es_It_Ml_Id_Tr_Farsi_Pt_Ar.B0M BENRUI25_GEMINI_PCB01_GPRS_MT6225_S00.BR253_V18_80 __NOKIA-E66_16m_En_Fr_Es_It_Ml_Id_Tr_Farsi_Pt_Ar.B0M E66_L2SM_PCB01_GPRS_MT6225_S00.E66_L2SM_V00_QVGA_B T_FM__Nokia-E66_16m_En_Ru_Fr_Es_Id_Th_Vn_Tr_Farsi_Pt_Ar.B0M E66_PCB01_GPRS_MT6225_S00.E66_V2_7_4__E66_16m_En_C n.B0M GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.GD6816_H X_DSIM_ST_F10_V14__E66_16m_En_Fr_Es_Pt_It_Ml_Id_Tr _Ar_Persian.B0M MT6225_PCB4.2_SPFD5408_SIV100B_TV.S7260_BKL_07B_T0 7_M0526_ML_A__Nokia-E66_16m_En_Fr_Es_It_Tr_Farsi_Pt_Ar.B0M RATECH25_GEMINI_PCB01_GPRS_MT6225_S00.M500_GQ_MLC_ NOTP_ST_1T01S0324__Nokia-E66_16m_En_Ru_Fr_Es_It_De_Tr_Farsi_Pt_Ar.B0M SZMI25_07B_PCB01_GPRS_MT6225_S00.M66_V1_2_1121_GGW _62025_TOSHIBA__NOKIA-E66_16m_En_Cn_Cn.B0M TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ZZH_Z660 _2_0_3_2__E66_16m_En_Gr_Fr_Es_It_Ml_Id_Tr_Farsi_Pt _Ar.B0M TORSTAR25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI _W09_03__Nokia-5320d-2sim_16m_En_Ru_Fr_Cn_Tr_Ar.B0M UTK25_GEMINI_PCB01_GPRS_MT6225_S00.2688_V1_1__Noki a-E66_16m_En_Ru_Fr_Es_Tr_Farsi_Pt_Ar.B0M i have use these files but still dead. |
04-23-2010, 06:52 | #10 (permalink) | |
04-23-2010, 21:23 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! it might be hardware fault too, please keep this in mind. best way to find same working phone on local market. there is big chance that it will be same version. take its backup and flash to faulty phone noone can say you for sure what was Original software version. You success is in your own hands. keep trying different flash file. |
why still 7210s still contact service | 2timer | Universalbox | 14 | 02-11-2010 02:47 |
why still cost credit unlock dct4? 30 credit gone, phone still locked | snowtown | Universalbox | 4 | 10-09-2009 15:04 |
gd87, why it still dead! | .:bono:. | Panasonic | 0 | 10-06-2006 04:00 |
What happen? why still no firmware for w550i? | sim1 | Cruiser Suite | 4 | 11-18-2005 20:03 |
still dead sl55 - still no help..? | seldomdk | E-Gold Based Phones | 3 | 10-25-2003 18:01 |
