05-12-2016, 09:25 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | WorldFirst : [SC9830] Andoid 5.x support :) Read Complete FW : Code: Operation : Read FullFlash [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : SCAC40HE Model Brand : archos Model Device: ac40he AndrVersion : 5.1 BaseBand CPU: SP9830AEC_4M_H100 Project Ver : SW09_Archos40 Helium_2015_10_29 Model Ext : Archos 40 Helium [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : nvitem_l.bin [Read Ok] : sharkl_cp1.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : l__WPH_arm7.bin [Read Ok] : PM_arm7_sys.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : wcn_fdl.bin [Read Ok] : SC77xx_CP_modem.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img AndroidInfo created Firmware Size : 1952 MiB Saved to : E:\SP9830AEC_4M_H100_ac40he_5.1_SW09_Archos40_Helium_2015_10_29_Archos_40_Helium\ Done! Elapsed: 00:09:40 Reconnect Power/Cable! That allow you be sure in result - FW will be complete and allow you bring phone back from any SW damage state. FW flashing : Code: Infinity SC Firmware Detected FW Size : 1952 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : archos Device Model : ac40he Device CPU : sp9830aec_4m_h100 Device IntName : SCAC40HE Device Version : 5.1 Device Compile : 29.10.2015 8:18:27 Device Project : SW09_Archos40 Helium_2015_10_29 Device ExtInfo : Archos 40 Helium Operation : Flash [ v1.18 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Update NVM image : nvitem_l.bin Update NVM Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sharkl_cp1.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : l__WPH_arm7.bin Write Data ... Write Data Ok! Write CodeData : PM_arm7_sys.bin Write Data ... Write Data Ok! Write CodeData : logo_480x800.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x800.bin Write Data ... Write Data Ok! Write CodeData : wcn_fdl.bin Write Data ... Write Data Ok! Write CodeData : SC77xx_CP_modem.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Process : Flush Flush Ok! Write FSImage : userdata.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Elapsed: 00:04:23 Reconnect Power/Cable! Code: Operation : Format File System / Reset Settings [ v1.18 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000014D0F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:15 Reconnect Power/Cable! NVM read : Code: Operation : Read NV [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read LTEx NV Read Ok , 0x0006A640 Saved to : C:\InfinityBox\CM2SPD\phdata\backup\CX9830_Archos_SPDNV.spdnv Elapsed: 00:00:21 NVM write : Code: NVM File looks Ok Operation : Write NV [ v1.18 ] Fix BB during write enabled 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! Write NVM Part #1 Ok! Clean DYNV Elapsed: 00:00:15 Reconnect Power/Cable! Repair Security ( flash mode ) : Code: Operation : Repair Security [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Write new security data : IMEI1 : 086124495176393 IMEI2 : 086554429383022 Step #1 Ok Step #2 Ok Write done! Elapsed: 00:00:19 |
The Following 26 Users Say Thank You to JayDi For This Useful Post: |
05-12-2016, 10:11 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,972 | Official software release - http://forum.gsmhosting.com/vbb/f296...-more-2089411/ |
05-12-2016, 12:10 | #6 (permalink) |
Insane Poster Join Date: Nov 2015 Location: Afghanistan, Kabul City
Member: 2491848 Status: Offline Sonork: 100.112222 Thanks Meter: 7 | CM2 Spreadtrum Is Not Working Fine In Windows7 CM2 MTK is working fine in windows 7,8 or etc but CM2 SPD is not working in windows 7 just it works on windows XP in windows xp drivers working correctly but in windows7 not work can you tell me the reason. |
05-12-2016, 12:41 | #7 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
i am using WIN7 from before CM2 come and i also use win7 for cm2 now no problem in anything driver or any other check ur side may be some problem not in win7 or CM2 | |
05-14-2016, 15:18 | #15 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Is it hard to press ctrl+Print screen on keyboard? Team would rather like to spend time on preparing new update instead of wasting time on these little things which can be done in just 1second. Br. Infinity Box Support Team. |
