09-04-2016, 16:21 | #31 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Code: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 42 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Erasig flash now, please wait ... Format finished! Reflash phone with normal FW now! Elapsed: 00:00:30 Reconnect Power/Cable! Finish at : [9/4/2016 / 7:56:10 PM] Code: Phone found! [ 42 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x26 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : NVM Update Current ID : NV_WLTE Current Part : l_fixnv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WLTE Current File : SC9600_sharkl_5modcsfb_volte.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_WLTE_LTE Current File : LTE_DSP.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_WLTE_GGE Current File : SHARKL_DM_DSP.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : WARM_WLTE Current File : SC9600_sharkl_wphy_5mod_volte.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DFS Current File : PM_sharkl_arm7_dfs.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FDL_WCN Current File : fdl1.bin(1) Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : EXEC_KERNEL_IMAGE0.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : OEM Current File : oem.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : PERSIST Current File : persist.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WLTE Current Part : l_runtimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:05:04 Reconnect Power/Cable! Finish at : [9/4/2016 / 8:02:18 PM] Start at : [9/4/2016 / 8:07:08 PM] Operation : Repair Security [ v1.20 ] Code: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 42 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Write new security data : IMEI1 : 911497******* IMEI2 : 911497******* Step #1 Ok Step #2 Ok Write done! Elapsed: 00:00:17 Reconnect Power/Cable! Finish at : [9/4/2016 / 8:07:25 PM] |
09-04-2016, 16:37 | #33 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | NVM, seems, have been successfully re-initialized. Will upload few compatible NVM's, if found in near hour-two. |
09-05-2016, 09:00 | #36 (permalink) |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | now i have 1 question after read from working set nv and write on faulty imei also chenged y this ? i have read nv now i want share it but problem i dont want share it with imei so its possible that remove imei from that nv ? |
