Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 12-01-2005, 15:35   #1 (permalink)
Member: 203514
N70 System Error and Freeze
Hi,
I'm having trouble with my N70.
A few minutes after booting up I get the message - "System Error". The phone then freezes.
Any suggestions?
Thanks in advance.
Old 12-01-2005, 18:02   #2 (permalink)
Administrator
..::Neo::..'s Avatar
Member: 14178
Thanks Meter: 8,889
formating do the job most of the time
Old 12-05-2005, 01:59   #3 (permalink)
FX1
Member: 96593
Thanks Meter: 13
Yes format phone
use same trick like 6600 will fix problem.
I had 2 prototype Nokia phones not released yet
3250 and E60 they have same problem and I fix this.
regards
bounty
Old 01-11-2006, 15:05   #4 (permalink)
kingofhearts's Avatar
Member: 8710
Sonork: 1576303
Thanks Meter: 197
Just flash your phone from phoenix via any connection with new version i.e. 3.05 and restore factory defaults it'll be work fine.
WBR
Haseeb
Old 12-08-2006, 16:33   #5 (permalink)
Member: 55963
n 70 system error
6600 code dosent work *#7370# 1000% works try it
Old 12-09-2006, 08:40   #6 (permalink)
desmond2727's Avatar
Member: 58704
Sonork: 100.1618753
Thanks Meter: 43
i hv same problem my set is new when on it after few second phone then freezes.i hv flash the latest vesion alr but still same got other solution to fix it.....
Old 12-14-2006, 17:30   #7 (permalink)
Y2ksalman's Avatar
Member: 194511
Sonork: 03335548581
Thanks Meter: 1,607
not work with formatting and also with flashing wat have to do some one can tell us v r awaiting for this solution
Salman Ahmed
Old 12-15-2006, 11:30   #8 (permalink)
Member: 127664
k
first check for virus
then format ur phone
then format ur card to
and the update phone software version
it will be fine i to facked same problem in n70
remove ur card while u update ur firmware
Old 08-29-2013, 15:30   #9 (permalink)
Member: 1335538
my nokia n70 gallary problem
A2 Initializating file system error !! Cant customize !! Help plz Dany Universalbox 2 03-29-2010 12:35
n70 system error mobicare_1 Nokia Base Band 5 ( BB-5 ) 2 06-24-2009 20:42
N70 System Error and Freeze simple79 Nokia Multimedia 7 12-14-2006 17:20
n70 system error problem johntan Nokia Base Band 5 ( BB-5 ) 0 08-12-2006 06:37
System Error - Nokia N70 nshkw Nokia Multimedia 10 04-07-2006 18:56
Page generated in 0.17058 seconds with 9 queries
