![]() | #362 (permalink) |
Junior Member ![]() ![]() Join Date: Jun 2004 Age: 49
Member: 69129 Status: Offline Thanks Meter: 1 | great job, at last the mistery is out there..... i´m trying to test in one 6630, but when i do read phone the message wait comes, but nothing else.... am i doing the correct way? br |
![]() | #366 (permalink) | |
Junior Member ![]() ![]() Join Date: Jul 2006
Member: 306130 Status: Offline Thanks Meter: 0 | Quote:
2. Set proper COM cable (must be, between 1 and 9) 3. Download unlocker, run `install.bat` 4. Open file c:/bb5_unlocker/logs/bb5_unlocker.cfg and write here proper COM port (1-9) 5. Run c:/bb5 unlocker/BB5logunlocker.exe 6. Click READ PHONE 7. Click MAKE LOG, log will be created 8. Enter codes to phone (in /psw/ dir), or 9. Click SP UNLOCK to enter codes via FBUS ******* CONECTION ****** For this program you need Fbus cable like DK5, CA43 or similar conected to ports from COM1 to COM9. First unpack zip fiole and strat install.bat In file "c:\bb5_unlocker\logs\bb5_unlocker.cfg" with any text editor change your COM port setings! ******* USING ******** Program can be started successfully only if is COM port in file "c:\bb5_unlocker\logs\bb5_unlocker.cfg" adjusted properly. READ PHONE: *********** Reading info data from phone and making BACKUP file for that phone( Field 308,1). IMPORTANT DO NOT delete or modify that file because can save your *** if something goes wrong. WR BACKUP: *********** With that function can write backup file with Field 308,1 if exist in BACKUP folder. MAKE LOG: *********** Function for making log file . With that log file BB5_calc.exe calculating codes for unlock. Working with BB5 phones with RAP3G v.2.x (6630,6680,6681,6682,n70,n90). IMPORTANT phone must be without Sim card. SP UNLOCK: *********** Making unlock with codes calculated by BB5_calc.exe. SP UNLOCK PROCEDURE Connect cable to PC and be shure com port is adjusted properly Start BB5logunlocker.exe Connect phone and switch on without Sim card. press button READ PHONE and wait until get the message DONE. If is everything correct you will see info from phone on screen. Pres button make log and wait until get mesage done. Log file is in folder LOGS. Start BB5_calc.exe to make for you PSW file in folder PSW Press button SP UNLOCK and unlock your phone. That is all. If you got unlock codes from your provider and you used all yours 3 attempts to enter code via keypad then do the following: into dir "c:\bb5_unlocker\psw" create a file "aaaaaaaaaaaaaaa_BB5.psw" where is "aaaaaaaaaaaaaaa" enter your phones imei then in that created file enter in the files start "#pw+bbbbbbbbbbbbbbb+c#" where is "bbbbbbbbbbbbbbb" enter your unlock code and where is "c" enter your logs level number (1-7). save the file and use "SP UNLOCK" function | |
![]() | #370 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2001 Age: 41
Member: 4120 Status: Offline Thanks Meter: 70 | if you read the post by dejan he stated that the calculator will do ANY bb5 phone only the logger is limited if you check service manuals u will see that most of the phones are supported the move will just push nokia to change algo and replace or update smartcards asta la vista maybe i am wrong ? in other words if the logger read log then is 100% can be unlocked |
![]() | #371 (permalink) |
Junior Member Join Date: Dec 2006
Member: 419191 Status: Offline Thanks Meter: 0 | this is not very good translation! unlocker is in enclosure It works on cable dku5 we download file unlocker.rar next extract somewhere run install.bat connect cable absolutely dku5 to the computer,port com should be to place between 1 and 9 write suitable of port com the file c:\bb5_unlocker\logs\bb5_unlocker.cfg lunch bb5logunlocker.exe push READ PHONE ,phone sholud be readed push MAKE LOG ,log should be created with codes if operation fail turn off and on phone( 4-5 times or more) push SP UNLOCK for direct unlock or write codes from catalogue \psw\ (accessible from 1 to 7) JMcorp |
![]() | #372 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2002 Location: Spain Age: 54
Member: 12126 Status: Offline Sonork: 1575463 Thanks Meter: 199 | Quote:
bcnboy | |
![]() | #375 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | @Dejan you make the forum moves today. New record of most users connected (3512). Nokia will hear about you today. Nice work, nothing else to tell you. You are Master of Master. I have repect for all (80%) of product suporter here but you are the KING. Hope you will continue to help us in our job. I also hope that you earn money for your hard work. Long life to you !!! |
BB5 unlock 6630,6680,6681,n70,etc.. | atul_799 | Nokia Hardware & Hardware Repair | 4 | 05-13-2007 17:44 |
BB5 6630,6680,6681,n70,etc... SP UNLOCKER!!! | psycho_UK | Nokia Base Band 5 ( BB-5 ) | 3 | 05-13-2007 03:02 |
BB5 6630,6680,6681,n70,etc... SP UNLOCKER!!! | graca | Universalbox | 3 | 05-12-2007 21:01 |
