Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 03-22-2009, 18:00   #1 (permalink)
kashi4gul's Avatar
Member: 460762
Sonork: 100.1592082
Thanks Meter: 3,104
BB5 Contact Service, Restart Problem,How To Erase BB5, Restore PM and RPL Backup!!!
Hi to all,
I saw here many times peoples are having with this "Contact Service or Provider" problem and also unable to Write or Restore the Orignal backup to the Phone.
Stanner's alreday Posted abt it all in his own F.A.Q but i dont know why the peoples does not follow Stanner's Instructions.
I just follow Him (stanner) and learned how to repair BB5 Contact Service/Retailer, how to erase BB5 and Restore PM and RPL Backup!!!
Now we shall more reflect upon this matter;
- How To Remove Contact Service or Provider ?
Firstly we should get Phone Info and see Imei and SL (Sim Lock) Zone are damaged or Not.
Get Phone Info:
In Case when you got Damaged Imei: 123456789012345 and you dont have Orignal RPL Backup then free way is try to solve this problem by downgrading if Imei and SP Data is still damage, then Upgrade it back and you must need to buy an new RPL to fix this problem. Use ASK to RPL Service.
In Case when Phone Imei is oK but Only SL Zone is damaged and you don't have Orignal PM 308 backup then wat to do.
If Courpted SP Data looks like this below:
CONFIG KEY: FFFFFFFFFFFFFFFF
PROVIDER KEY: FFFFFFFFFFFFFFFF
Provider: Unknown provider
And phone is supported for Unlocking, then you can try to Repair it free with any BB5 Unlocker by Unlock Button or with Repair SP Data Option. (It should Repair) Otherewise you may need to New RPL.
And If Courpted SP Data looks like this:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 0000000000000000
Then you must need to buy an New RPL whether Phone is supported with any BB5 Unlocker. We can not Repair it free, Use Ask To Rpl Service.
In Case when you have RPL Backup and have not PM 308, you can only Restore the Phone Imei but you can not Repair the Courpted SP Data like this: PROVIDER KEY: 0000000000000000, Provider: Unknown provide
In Case when you have PM 308 backup and have not RPL, you can Repair SP Data but you can not Repair Phone Imei by only PM 308 backup. Use ASK To RPL Service.
In Case when Phone Imei and SL Zone both are OK but phone is still on Contact Service/Provider.
First take Self Test and check ST Security Test is Passed or Failed?
If Passed then do File System Formate and after that make Factory Setting and see problem is solved or not, if still same then check phone hardware.
And if ST Security Test is Failed then Write PM Field [1] And [309] as stanner said, (or full pm as you wish) by using SX4 Auth Service and after that make Factory Setting. Oftenly Phone can Repair by Downgrading
and Writing RPL.
Then Write PM With SX4 if same then Update back and See problem is Solved or not. (It should work now!) otherwise try to repair it by erasing method.
- How To Remove Restart Problem when Phone Imei is oK but Phone goes to Restart or Shut Off after a while.
In this case first try to solve this problem by only Write Full Modified (Without 308 Field) PM With SX4 Auth.
Use SX4 and when it done Successfully then immediately Write supported full modified PM to the phone and check phone without MMC, problem is fixed or not, if not then Full Flash and after that Write PM with SX4, or try to solve by Downgrading.
Oftenly Restart problem is removed by only do File System Format and Factory Default. (Check phone without MMC)
Otherwise there is only one way is left to Repair it with Software and that is Erase Flash (Rap), to start the Erasing Procedure,
Follow this given below Method:
Before Start Erasing Flash, Save your both backup PM 308 and RPL backup (CRT 308 and CRT BKP)
If you are going to do erase newer BB5 + (Plus) Phone then you must Save also Full PM 0 to 400 Backup, coz you will need it for restore the orignal field 308, this is really fast easy and perfect way to restore the PM 308 Field, otherwise you may need to buy an new RPL.
So be careful. . .
Now we are ready to do erase.
Select UNI_rapido.bin in Mcu Part and click to Flash
and for MT Select uni_rap.bin as MCU.
when phone will fully erased then Phone Imei will be: 12345610654321, SP Area will damaged and
CMT Flash Data will shown: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Now Full flash with any Firmware ver but selected firmware should be not too Old or too New, coz we may need it in another case.
After Flash when phone will turn On, you will get
damaged IMEI: 12345610654321 and Courpted SP Area:
Now first of all you have to Restore the Orignal backup of PM 308, in case when you are unable to restore the PM 308 backup then flash again with same FW when you were take backup.
When it flash successfully then plz stay a min and write it (PM 308) back to the phone, now
Disconnect phone, connect it again and see SL Zone is Repaired or Not.
(It should be repair now), if not then flash again with same FW and restore the PM 308 backup.
But if you have Full PM 0-400 backup then no need to Flash again, just Write it (Full PM 0-400 backup) back to the phone without SX4, when it done successfully then remove cable to the box, replug cable and get info
you will see SP Area is Repaired now, if not then it will be repair after writing RPL backup.
After successfully restore the PM 308 backup phone will on Contact Service/Retailers or full working phone with damaged Imei. In this condition when phone has damaged Imei: 12345610654321 you can write full modified PM (without 308 field) without using SX4, coz phone has not certificate (IMEI), therefor no need to use SX4.
Now we have to Restore RPL backup. If you are using JAF then Click on CRT Tool, now you will see BB5 Certificate Tool Window > tick on Write RPL Option and also mark on Plain RPL box, now Select your RPL backup and click on Write RPL button.
Get info now and see Imei is restored succcessfully or not phone should be on Contact Service/Retailer or fully working. . .
But if you are failed to restore the RPL backup, i mean phone Imei is still damage and phone show only Nokia and then shut Off in case now you Write blank_rpl and Flash again with Latest Firm Ware.
When it (flash process) done successfully then write RPL backup, get Info and see Imei is back or not, it (Imei) should back now, and your Phone will on Contact Service/Retailer, if Not and you got dead phone Please follow again all above erasing method.
Finally use SX4 and Write PM Field [1] and [309] (or full pm as you wish), now we have done all abt Software.
I think That's all. . . abt BB5 Repair with Erasing Method and we have confirmed now, phone has Software Problem or not.
All BB5 Full Modified PM Download Here: http://www.4shared.com/file/94212006...DIFIED_PM.html
All Nokia Latest Flash Files Download from Here: www.blue-nokia.com
_blank_RPL_ and BB5 Erase Files are Attached.
Thanks to Mr.stanner_austin (Chevli)
Best Regard's
kashi4gul
File Type: rar _blank_RPL.rar (159 Bytes, 6027 views)
The Following 283 Users Say Thank You to kashi4gul For This Useful Post:
Old 03-23-2009, 08:16   #2 (permalink)
Member: 949039
Thanks Meter: 46
kashi !!
would we will do above method for nokia 6233. which one is shut of after a while ?
please guide me.
The Following 3 Users Say Thank You to prihir For This Useful Post:
Old 03-23-2009, 08:20   #3 (permalink)
oMeR_Rasheed's Avatar
Member: 466635
Sonork: 100.1614186
Thanks Meter: 482
BUTT BRO I OPEN www.blue-nokia.com BUTT I DON'T KNOW HOW TO DOWNLOAD FILE PLEASE CAN U TELL ME PLEASE
B.R
SHERRY MOBILES
The Following 6 Users Say Thank You to oMeR_Rasheed For This Useful Post:
Old 03-23-2009, 08:23   #4 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
@kashi4gul
AM SUPPORTED U HERE SOME VIDEO OR MANNULS
The Following 60 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 03-23-2009, 08:26   #5 (permalink)
Member: 351924
more screen shot here this link
http://forum.gsmhosting.com/vbb/showthread.php?t=683634
The Following 44 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 03-23-2009, 08:32   #6 (permalink)
kashi4gul's Avatar
Member: 460762
Sonork: 100.1592082
Thanks Meter: 3,104
Originally Posted by prihir View Post
kashi !!
please guide me.
Ofcourse the Erasing Method which i mentioned above is for All BB5
(look your Thanks )
B.R
SHERRY MOBILES
downloading is very easy from www.blue-nokia.com, open site > remove cover by clicking on Close button and then Press Enter and now you will be able for downloading Flash Files.
B.R.,
kashi4gul
The Following 8 Users Say Thank You to kashi4gul For This Useful Post:
Old 03-23-2009, 09:40   #7 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
at both condition to repair perfect need bb5 ask 2 rpl.
because if watchdog timer is on phone will off him self in 10 to 30min.
if watch dog timer is not on you can repair with notp supported any unlocker.
blank rpl is same (npc damage rpl by me) which was discovered by karwas and made by me to damage full npc certificate and name it "bypass security".
last but not least erase file posted by me work only on 32mb flash maxim if flash ic is bigger then it its simply erase nothing.
The Following 19 Users Say Thank You to stanner_austin For This Useful Post:
Old 03-23-2009, 12:42   #8 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
B.R
SHERRY MOBILES
use mozila firefox instead
The Following 3 Users Say Thank You to StRaNgE PeRsOn For This Useful Post:
Old 03-25-2009, 18:01   #9 (permalink)
Member: 456255
Thanks Meter: 4
salaam brother
i have 1 prob i have e 65 on contect retailer i try to solve my prob but allways fail i save my backup rpl & pm than i erase my complet phone with 64 bit than i flash again ..write rpl wite pm with sx4 but allways still same prob ..after write rpl whan i got info its show ok i means SP DATE is good not same in contect retaler .
any other solution plz tel me i m waiting ...............
thanks
The Following 2 Users Say Thank You to buttowais For This Useful Post:
Old 03-26-2009, 07:47   #10 (permalink)
kashi4gul's Avatar
Member: 460762
Sonork: 100.1592082
Thanks Meter: 3,104
Please you read this part:
and Writing RPL.
Originally Posted by buttowais View Post
salaam brother
thanks
B.R.,
kashi4gul
The Following 3 Users Say Thank You to kashi4gul For This Useful Post:
Old 03-29-2009, 12:15   #11 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 138
no backup pm on rpl 100% soliton bb5 unlock exe jast unlock best of luck
online mobile technology[
The Following 2 Users Say Thank You to MR.MAMUN For This Useful Post:
Old 04-01-2009, 09:53   #12 (permalink)
abrahoma's Avatar
Member: 825233
Thanks Meter: 10
n70 contact retailer when use battery ?
i have n70 say contact retailer when i use battery and works normal whith jaf and the information gives me
config key 000000000000 but other data imei and provider are ok
please help me
thanks in advance
The Following 2 Users Say Thank You to abrahoma For This Useful Post:
Old 04-01-2009, 13:45   #13 (permalink)
kashi4gul's Avatar
Member: 460762
Sonork: 100.1592082
Thanks Meter: 3,104
please help me
thanks in advance
i think you did not read my post carefully
anyways read post #10 and follow the instruction's.
B.R.,
kashi4gul
The Following 2 Users Say Thank You to kashi4gul For This Useful Post:
Old 04-02-2009, 21:06   #14 (permalink)
Member: 277109
Sonork: 100.1590647
Thanks Meter: 83
thanks for your clear instruction! and thanks goes to stanner_austin too!
i have one question:
at this point, can i use the blank rpl trick to bypass the SX4? like, write blank rpl, write backup pm [1] and [309], finally write back backup_rpl.
br,
wuwei
The Following 2 Users Say Thank You to wuwei For This Useful Post:
Old 04-02-2009, 21:53   #15 (permalink)
Member: 277109
Sonork: 100.1590647
Thanks Meter: 83
question 2, when you said backup pm 0-400 is better for new bb5+ phone, what does it mean? means:
A. phone's Certificats are not only in area 308
or
B. tool's '308 backup' fonction is not perfect, that doesn't fully backup area 308
So
if it's case A, then when we do, in erase procedure, writing full modified pm (without pm 308), will that modify the phone's Certificats? that's why i may possbily need to write pm backup of [1] and [309]?
if it's case B, then what can i say, lol, which tool is more reliable?
question 3,
do you mean phone will with damaged imei, in either 'Contact Service/Retailers' or 'full working phone'?
and in both cases, i MUST write a full modified PM (without 308 field), in order to continue to next step, am i correct? if PM backup 0-400 is already a full backup PM, why do i have to write another one? what is a fully backup PM, 0-512 or 0-400?
br,
wuwei
BB5 Contact Service, Restart Problem,How To Erase BB5, Restore PM and RPL Backup!!! digital_park Universalbox 1 05-19-2009 23:41
BB5 Contact Service, Restart Problem,How To Erase BB5, Restore PM and RPL Backup!!! digital_park MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 05-17-2009 17:41
BB5 Contact Service, Restart Problem,How To Erase BB5, Restore PM and RPL Backup!!! digital_park Cyclonebox 1 05-17-2009 09:18
BB5 Contact Service, Restart Problem,How To Erase BB5, Restore PM and RPL Backup..? gsm_doc Nokia Base Band 5 ( BB-5 ) 0 05-02-2009 07:48
Page generated in 0.30291 seconds with 10 queries
