04-03-2009, 05:46 | #16 (permalink) | |||
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 39
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | You are the first one which has read all points carefully, I m happy and admire you, coz stanner's already told me 50% peoples dont like to read. . . Q .1: Quote:
You can use _blank_rpl_ at anywhere but this time when i said Finally use SX4. . . you should not use at this time if both backup are restored well. Q .2: Quote:
has ROM ID: 191EC665DFAAF68F and 273F6D55DFAAF68F, * HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 and we need also other orignal fields like 1, 120. . .309 etc to restore this 308 field, therfor i recommend save Full PM backup 0 to 400, write only this full PM and SimLock Area will be restore easily without any problem, otherwise you may need to buy an new rpl to fix this problem. Q .3 Quote:
after restore pm 308, write full modified pm is optional step, if you have already write orignal PM 0-400 then no need to write modified pm. And 0-400 backup is enough no need for 0-512, all bb5 phone has maximum fields 362-365, therefor 0-400 address is enough for reading full pm. B.R., kahsi4gul | |||
The Following 6 Users Say Thank You to kashi4gul For This Useful Post: |
04-03-2009, 10:04 | #17 (permalink) | |
Freak Poster Join Date: May 2006 Location: Paris Age: 42
Member: 277109 Status: Offline Sonork: 100.1590647 Thanks Meter: 83 | Quote:
thank you, kashi4gul! i think i am ready to repair BB5 now, thanks! wbr, wuwei | |
04-04-2009, 16:34 | #19 (permalink) |
Freak Poster Join Date: Feb 2007 Location: @ MY SOUL
Member: 450542 Status: Offline Sonork: 100.1590626 Thanks Meter: 61 | hot imei of n73 i have n73 in imei crpt 123456789? and i miss my rpl backup i have crt backup pm wt can i do and also problem in reading ask file with jaff helppp!!!! PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk47v60.1 20-03-08 RM-133 (c) Nokia. HW version: 7600 PCI version: RFIC version: 17211721 DSP version: scarfe_mc.05wk46v50p2 Retu version: 15 Tahvo version: 22 Production serial number: MPD289806 Product code: 0539295 Module code: 0202855 Basic production code: 0537044 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 71 F5 Master Code: 1370355423 Phone type: RM-133, Software version: 05wk47v60.1, Language Pack: not available User code: 12345 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-133.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0539295 Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-133\ Searching for default location of ini... Checking path: \Products\RM-133\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-133\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! |
04-04-2009, 18:45 | #20 (permalink) | |
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Quote:
B.R., kashi4gul | |
The Following User Says Thank You to kashi4gul For This Useful Post: |
04-05-2009, 16:06 | #24 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 213835 Status: Offline Thanks Meter: 0 | @kashi4gul Thanks for your useful information. I need to erase 5800 xpressMusic. I think the procedure is as follows. Please help me to check. My tool is JAF + USB-cable(I don't have 5800 F-Bus cable) 1. backup full PM(0-400) 2. backup RPL(by CRT tool) 3. start flash the erase file Please tell me which files are needed for 5800 A. BB5Erase_16MBrap.bin B. BB5Erase_32MBrap.bin C. BB5Erase_8MBrap.bin D. BB5Erase_EE_16MBrap.bin E. BB5Erase_EE_32MBrap.bin F. BB5Erase_EE_8MBrap.bin G. BB5Erase_uni_rap.bin H. BB5Erase_UNI_rapido.bin I. Erase_64M_sorinm.fia 4. Flash full firmware 5. write full PM backup 6. write RPL backup The phone should become work states after step 6, right? |
04-05-2009, 19:00 | #26 (permalink) | |
Save your both backup PM 308 and RPL and save also Full Pm 0-400 backup only for newer BB5+ - Erase with UNI_rapido.bin (For MT uni_rap.bin ) - Full Flash - Write/Restore PM 308 backup - Write/Restore RPL backup Write Full Modified PM with SX4 (Optional) And you can not Read or Write RPL backup Via Usb Cable, you must use Fbus cable. B.R., kashi4gul | |
The Following 2 Users Say Thank You to kashi4gul For This Useful Post: |
04-06-2009, 17:58 | #28 (permalink) | |
B.R., kashi4gul | |
BB5 Contact Service, Restart Problem,How To Erase BB5, Restore PM and RPL Backup!!! | digital_park | Universalbox | 1 | 05-19-2009 23:41 |
BB5 Contact Service, Restart Problem,How To Erase BB5, Restore PM and RPL Backup!!! | digital_park | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 05-17-2009 17:41 |
BB5 Contact Service, Restart Problem,How To Erase BB5, Restore PM and RPL Backup!!! | digital_park | Cyclonebox | 1 | 05-17-2009 09:18 |
BB5 Contact Service, Restart Problem,How To Erase BB5, Restore PM and RPL Backup..? | gsm_doc | Nokia Base Band 5 ( BB-5 ) | 0 | 05-02-2009 07:48 |
