Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 06-29-2013, 14:03   #1 (permalink)
Member: 770294
how flash nokia 301 rm-839
hi :
because the driver wants !!!
what is a flash box?
Old 06-29-2013, 22:26   #2 (permalink)
Member: 770294
please help me
no one comment?
Old 06-30-2013, 10:20   #3 (permalink)
Member: 969318
Thanks Meter: 82
Originally Posted by mobiljamal View Post
hi :
DO you have rm-839 v02.33 flash file, if you have pls give me...thanks
Old 06-30-2013, 14:39   #4 (permalink)
Member: 770294
yes , i have a flash file
but , i can not flash my phone
Old 07-02-2013, 00:26   #5 (permalink)
Member: 944689
Hello,
You will need
NokiaCareSuiteForStore-2013_20_5_3
and flash files.
Work in offline mode, use option programming>refurbish.
Tested with 301 rm-840, successfully updated to ver 02.51
rm-839,840,841 are supported with that nokia care suite ver.
Old 07-08-2013, 06:25   #6 (permalink)
Member: 123924
Sonork: 100.1576204
Thanks Meter: 25
I need nokia 301 RM-839 02.33 ppm
I need nokia 301 RM-839 02.33 Russian ppm
pls help
thanks
Old 07-08-2013, 07:36   #7 (permalink)
Member: 527534
Sonork: 100.1606510
Thanks Meter: 193
pls help
thanks
Can you provide a product code?
Old 07-08-2013, 16:51   #8 (permalink)
sopla4ever's Avatar
Member: 1793281
Thanks Meter: 167
rm839__02.33.ppm_a3
Old 07-21-2013, 18:12   #9 (permalink)
Member: 123924
Sonork: 100.1576204
Thanks Meter: 25
Thanks sopla4ever Nee arabic ppm
RM-839 02.33
pls help
Old 07-21-2013, 20:36   #10 (permalink)
Cheater -Don't Deal with him-
Member: 452256
Sonork: 100.1651051
Thanks Meter: 587
RM-839 02.33
pls help
use this product code my brother for Arabic 059R1J9
good luck
Old 07-21-2013, 23:11   #11 (permalink)
Member: 1982901
Thanks Meter: 2
Your can Download and find all product code file easyly if you have cyclone ,,,
Old 07-30-2013, 23:22   #12 (permalink)
Member: 1986751
In NCS when I try recovering NCS tells me that the connection is lost. It does not start to flash my device propperly. I do like this:
0. Firmware files are downloaded using NCS Data Package Manager (however, the files I downloaded is for another product code) the NCS is closed.
1. Phone is disconnected and turned ON
2. NCS is started in offline mode and Production Support Tool for Store is opened, programming>recovery
3. File>open product>301 rm-840 (my device is not rm-839 but it should not make any change in the procedure?)
4. 301 is plugged in and the start button is pushed.
Then after a while (the status bar is not moving at all) it says that the connection has been lost
Any ideas of what to do?
Old 08-19-2013, 12:21   #13 (permalink)
Member: 136052
Thanks Meter: 75
I need nokia 301 RM-839 02.33 Turkish ppm
pls help
big thanks
Old 08-20-2013, 01:17   #14 (permalink)
abishekkumar's Avatar
Member: 1761355
Sonork: 0818211
Thanks Meter: 105
Plese Hindi flash file urgent
Old 11-12-2013, 07:51   #15 (permalink)
Registered User
Member: 1855284
Thanks Meter: 5
i need direct download link
Page generated in 0.23330 seconds with 8 queries
