06-02-2009, 13:37 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Android developers
Member: 904753 Status: Offline Sonork: 100.1583681 Thanks Meter: 2,677 | Help me any solution without rpl.... RM-171 E50 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 4.41.41 28-06-07 RM-170 (c) Nokia. HW version: 5101 PCI version: RFIC version: Ð 17211721 DSP version: ÐSiperia_PR2_CDSP_14v53_07w23 APE SW Core version: V 07.36.0.0 07-09-2007 RM-171 (c) Nokia APE Variant version: V 07.36.0.0 07-09-2007 RM-171 05 (c) Nokia Retu version: 32 Tahvo version: 52 APE HW version: 256 APE ADSP SW version: 256 APE BT version: HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. Production serial number: SVJ787212 Product code: 0536128 Module code: Basic production code: 0530670 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 351893012099324 IMEI spare to net: 3A 15 98 03 21 90 39 02 IMEI SV to net: 33 15 98 03 21 90 39 02 F9 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-170.ini Saved INI not found, loading INI list... Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ |
06-02-2009, 15:50 | #6 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | just make the rpl backup and certificate backup first, as i can see your IMEI is Ook then do the SelfTest for ST_SIM_LOCK and ST_SECURITY if anyone failed then do write PM without Field 308 and 120 using SX4 if still not solve then full erase your phone and write latest firmware then do restore RPL and certificates, and then again do write FULL PM using SX4, hopefully this will solve your problem. Take Care ENJOY |
06-02-2009, 16:35 | #7 (permalink) | |
Member: 904753 Status: Offline Sonork: 100.1583681 Thanks Meter: 2,677 | Quote:
i do this all But Same Problum.....! Sir I think not any solution. Now I Buy Rpl for this problum Thanx 4 All Helper....! | |
06-02-2009, 22:30 | #10 (permalink) |
Freak Poster Join Date: Sep 2005
Member: 182413 Status: Offline Thanks Meter: 351 | Since PROVIDER diferente from 0000000000000000, then simlock is good. Bad lock is when CONFIG KEY and PROVIDER both are 0000000000000000. In yor case: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 GOOD. |
5130c any solution without rpl ? | unlock & flash | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 12-17-2009 05:16 |
6300 any solution without RPL??? | shahzadthe1 | Nokia Base Band 5 ( BB-5 ) | 9 | 10-11-2009 23:45 |
Help me, any solution for this philips | aswancamel | Infinity-Box | 2 | 07-29-2009 03:49 |
lgkg290 charging problem help me any solution | shani72 | LG Hardware Repair | 0 | 06-08-2009 06:06 |
3230 fast discharging battrey help me any solution | shani72 | Nokia Hardware & Hardware Repair | 3 | 04-08-2009 05:58 |
