09-26-2006, 10:24 | #107 (permalink) |
No Life Poster Join Date: Jun 2005 Location: India ( Punjab ) / China Age: 38
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | uninstall all other nokia tools like pc suite cable drivers etc etc you have installed on ur pc yoh have to uninstall from add/remove programm in ur pc Cpanel also DK2DRVS.isu, DK2WIN32.DLL, DK2WN95.386, Remove from ur pc manualy with search Hope help you WBR Mr999 |
09-26-2006, 18:52 | #109 (permalink) | |
Junior Member Join Date: May 2006
Member: 280280 Status: Offline Thanks Meter: 0 | Quote:
i'm unable to download these two files showing error message bandwidth exceeded Nokia_Connectivity_Cable_Driver_6_80_5_1_eng_uk.ms i Download Here crack_dongle_phoenix_2006.exe Download Here crack_dongle_phoenix_all_.exe Download Here | |
09-26-2006, 19:12 | #110 (permalink) |
Major Poster Join Date: Sep 2006
Member: 348541 Status: Offline Thanks Meter: 0 | MR FRIEND MR999 FIRST OF ALL, THANKES FOR THIS MAGNIFICANT WORK .. PLEASE I INSTALL PHOENIX 2006 SUCCESSFULLY, BUT I CAN'T FLASH MY PHONE ( NOKIA 7610 ) FROM 1 WEEK AGO .. The following procedures i follow :- 1- I OPEN PHOENIX 2006 2- CONNECT MY PHONE WITH COMPUTER BY THE ORIGINAL RECEIVED CABLE FROM NOKIA ( DKU-2 ) AND IT INSTALLED SUCCESSFULLY .. 3- OPEN MANAGE CONNECTION AND ADD USB AND THEN PRESS APPLAY 4- GO TO OPEN PRODUCTS AND CHOOSE NOKIA 7610 ( RH - 51 ) 5- GO TO SW-UPDATE BUT IT GIVES ME NO INFORMATION PLEASE HELP ME MY FRIEND AND THANKES AGAIN |
09-27-2006, 03:02 | #111 (permalink) | |||
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | Quote:
The 37 GB transfer limit per day which means that your traffic allowance will vary a bit from month to month. E.g. you will be allowed to use 1147 GB transfer in a 31 day month but only 1073 GB in a month of 29 days. i think u understand...now evrything ok You can download Quote:
WBR Mr999 | |||
09-27-2006, 20:10 | #112 (permalink) | |
Junior Member Join Date: Aug 2006
Member: 340481 Status: Offline Thanks Meter: 0 | Quote:
Have the same problem..Tried to install Diego 3.07 and get: "The wizard was interrupted before Diego could be completely installed..." Should I run the crack at some point before, during or after the installation? Any other suggestions...? Thanks | |
09-28-2006, 07:09 | #114 (permalink) | |
Member: 348541 Status: Offline Thanks Meter: 0 | Quote:
I do scan product but face the same problem, Plz MR999 give me soluation | |
09-29-2006, 00:20 | #115 (permalink) |
Junior Member Join Date: Feb 2003
Member: 21184 Status: Offline Thanks Meter: 0 | Hi, managed to install Diego, Phoenix 153, connected N70, phone installed ok. Setup Usb connection. Scan the Product, it finds ok V5.0616.2.0.3. Click on Test Mode, phone reboots into test mode. Run the Keyboard test, recognises key presses on phone. When I finished the test and click on Normal mode, phone reboots but gives a message of (Pic) Would that be classed as a problem for Flashing. I did try with Phoenix 136 a few weeks back and got the dreaded adlserver mode after phone had rebooted to procede with the flashing, usb communication break down for some reason. |
09-29-2006, 14:41 | #118 (permalink) |
Junior Member Join Date: Sep 2006
Member: 360024 Status: Offline Thanks Meter: 0 | what is the difference when i open these products rm-38 rm-78 and go to flashing there is firmware update and there is no option for select image ppm files .... but when open n80 n70 and many other products and go to flashing there is sw update and can select image and ppm .iam using phoneix phoenix_service_sw_2006_20_14_153 |
09-29-2006, 16:13 | #119 (permalink) |
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | Nokia 3250 flashed ok without any problem ....its my personel phone i get files from my friend coz its huge 200 Mb data package...... phone ok and work fine i will post photo 2mrw now at home WBR Mr999 |
09-29-2006, 18:03 | #120 (permalink) | |
Member: 358722 Status: Offline Thanks Meter: 0 | How did you??? Quote:
Escuseme, but wath version did you installed on your n90??? and where did you got it??? And now i got a message from phoenix at the beginning of the flashing, syas taht there was an error, "Server sent an exception" Please could someone help me!!!!!! Thanks in advantage | |
Best way to install Phoenix 2006 without any dongle | cprasad7 | Nokia Base Band 5 ( BB-5 ) | 10 | 07-31-2007 11:00 |
FLASH BB5 Phone WITHOUT ANY DONGLE | zhuzh | Nokia Base Band 5 ( BB-5 ) | 2 | 09-11-2006 11:53 |
Pmb6850 for free work without dongle | asmax1 | Infineon C16X M51 & ARM7 M52 BASED | 3 | 07-18-2004 17:24 |
Free DCT4 calculator working without dongle | gsmsupport.net | Nokia Multimedia | 33 | 05-19-2003 21:14 |
