Universalbox Universalbox Official support area |
10-27-2008, 12:37 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Sep 2005 Location: Singapore
Member: 179474 Status: Offline Thanks Meter: 1,660 | Other products i try before....but Code: 18:28:24 D-XXXXXXXXXXXXXXXXX 18:28:24 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:28:24 Initializing... ! 18:28:24 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:28:24 2. Choose the phone model ! 18:28:24 3. Select the desired options ! 18:28:24 4. Please connect the phone either via USB while holding 2-5? ! 18:28:24 - or via a serial cable and double-click on it in the device list 18:28:28 Selected phone: V640 18:28:28 Connecting via Generic EMP USB Flash Device (USB2)? 18:28:28 Device driver version: 2.0.0.4 18:28:28 Device driver date: 9-12-2007 18:28:29 Connecting to the baseband CPU... 18:28:29 Entering baseband CPU service mode... 18:28:29 Detected chipset: DB3150 18:28:29 Boot mode: ROM 18:28:30 Sending loader... 18:28:32 IMEI: 35880101607546 18:28:32 OTP CID: 52 18:28:32 Product type: Retail 18:28:32 Effective color: Blue 18:28:33 Sending loader... E 18:28:37 Error: 0xB79ED6E8 E 18:28:37 Error data: 0xB79ED6E8 - 00000002:0006 E 18:28:37 Error: 0xED615A9B E 18:28:37 Error: 0x7DF6B03C E 18:28:37 Error: 0x59AF7680 E 18:28:38 Failed! ! 18:28:38 To report errors right-click this window Code: 2008/10/27 13:02:51 SIGNED MODE (USING SERVER). 2008/10/27 13:02:56 ChipID:C802,EMP protocol:0401 2008/10/27 13:02:56 BOOTROM MODE DETECTED 2008/10/27 13:02:59 OTP LOCKED:1 CID:52 PAF:1 IMEI:35880101607546 2008/10/27 13:03:00 LDR:2008-05-23 12:08 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A059 2008/10/27 13:03:00 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH 2008/10/27 13:03:03 LDR:2008-05-23 12:07 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A059 2008/10/27 13:03:03 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA 2008/10/27 13:03:04 userlock reset failed, err:5A 2008/10/27 13:03:04 Error while resetting USERCODE. 2008/10/27 13:03:10 can't get ACK 2008/10/27 13:03:10 Elapsed: 18 secs. |
SE K320i 5 LOCKS CLOSED. | AbdulKadir | Universalbox | 7 | 07-01-2009 09:08 |
Se k320 5 locks closed! | completeunlock | Universalbox | 0 | 05-06-2009 16:26 |
SE K810i 5 Locks Close Not CSCA Unlock Credit Loss | rajinder1978 | Universalbox | 2 | 04-30-2009 19:51 |
W850 5 lock closed just Unlock with ub? | bestncheap | Universalbox | 10 | 03-20-2007 23:46 |
W850 5 lock closed just Unlock with ub? | bestncheap | Universalbox | 2 | 03-20-2007 22:22 |
