Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SST-Dongle
Old 11-04-2006, 01:20   #1 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks Meter: 106
SST v 7.53 - New "Direct Boot " mode enable connection without test-point.
SST v 7.53 is already available for download.
New "Direct Boot " mode enable connection without test-point for X65/X75 SGOLD models.
Please remember to select "Direct Boot " after model and speed selection.
PS. Maximum Connection speed with this boot method should not exceed 460k!
The Following 2 Users Say Thank You to SST-GSM For This Useful Post:
Old 11-04-2006, 02:42   #2 (permalink)
Member: 22588
Thanks Meter: 29
Another time saving feature of SST. Luckily have one for test....thanks sst team!!!
Old 11-04-2006, 02:46   #3 (permalink)
andrew14's Avatar
Member: 78367
Thanks Meter: 11
maybe someday there will be no more tp.............
Old 11-04-2006, 02:56   #4 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 190
Lucky my old dongle is working. After upgrade antirivus I cannot run sst program , always say cannot find " kernel32.dll". I Thing dongle spoiled after reinstall driver many times still not work. Now I know it detect by antivirus program. after deactive program run normal. Thank you for new update.
Old 11-04-2006, 03:46   #5 (permalink)
vertz's Avatar
Member: 173878
Thanks Meter: 295
what antivirus do you use? for me i use nod32 and it works fine. no problem whatsoever.
Old 11-04-2006, 08:15   #6 (permalink)
Member: 40646
Thanks Meter: 2
s75 and s68 dont work
Old 11-04-2006, 08:53   #7 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks Meter: 106
Yes some of the new models may not support this method.
Old 11-04-2006, 11:14   #8 (permalink)
Member: 104066
Thanks Meter: 62
Good Update
Gread Work Thanks SST Team
Old 11-04-2006, 12:55   #9 (permalink)
niketlen's Avatar
Member: 48492
Thanks Meter: 29
SL75 (with software faliure) not working !!! maybe direct boot working with good phone ?
Old 11-04-2006, 16:16   #10 (permalink)
Member: 308774
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
COPYCAT!!!
stolen solution from Griffin Team!
regards: Profiler
Old 11-04-2006, 18:53   #11 (permalink)
gsm-decode's Avatar
Member: 47441
Thanks Meter: 14
COPY CAT ****
You talk like Zuleah man
Old 11-04-2006, 19:16   #12 (permalink)
SST-GSM's Avatar
Member: 38795
Thanks Meter: 106
Models S75, SL75 S68 and EL71 do not support direct boot method as this boot authority bypassing backdoor is too old and already cleared by Benq-Siemens ! Use java midlet("Boot Password" method) for SL75 and test point method for S68 and EL71 instead of it.
The following models are supported by direct boot method:
  • C65,C6v and etc.
  • CX65,CX70,CXI70
  • M65
  • S65
  • SL65
  • SK65
  • C72
  • C75
  • CX75
  • M75
The adviced maximum connection speed using this method is 460800.
After first connection the phone may be connected using "patched boot" method
The Following 3 Users Say Thank You to SST-GSM For This Useful Post:
Old 11-05-2006, 07:19   #13 (permalink)
Allunlockingsource's Avatar
Member: 333439
Sonork: 100.1589101
Thanks Meter: 623
i need sst new verion
Old 11-06-2006, 11:13   #14 (permalink)
Member: 6653
Sonork: 100.1597550
Thanks Meter: 26
http://www.sst-gsm.com/scard/SST7_Setup.exe
The Following 3 Users Say Thank You to sp-lox For This Useful Post:
Old 11-07-2006, 05:16   #15 (permalink)
Member: 31028
Thanks Meter: 56
not working on c72... it gives service mode error.
The Following User Says Thank You to [Rod] For This Useful Post:
can i unlock z-6 without test point. saniamirza MSS Box II 1 03-29-2010 21:06
V3R BOOT 0A.52 Without Test Point = Possible ??? MasterJey Smart-Clip 14 07-06-2007 00:59
SST v 7.53 - New "Direct Boot mirolic SIEM Service Tools 11 11-23-2006 10:36
SST SERVICE TOOLBOX V 7.53 new "Direct Boot" without Test-point SST-GSM Main Sales Section 0 11-06-2006 12:06
Successfully Unlock W900i Without Test Point With Semc 7.6 rajan nishchal SonyEricsson (USB-Smart) 7 04-22-2006 18:00
Page generated in 0.23839 seconds with 10 queries
