Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 02-07-2010, 18:41   #16 (permalink)
Nustian's Avatar
Member: 302566
Sonork: 1579334:100.1.100
Thanks Meter: 42
Use JAF box,I hope your problem will be solved perfectly.
Br:- Awais
Old 02-09-2010, 03:09   #17 (permalink)
Member: 904530
Thanks Meter: 517
use EXT VPP Bat 9V for these phones,
will be much faster and no errors
Old 02-09-2010, 09:27   #18 (permalink)
rehman9's Avatar
Member: 99407
Thanks Meter: 53
take 6300 good cable and tight down with hand
your problem will solved 100%
Old 02-09-2010, 18:32   #19 (permalink)
Member: 303868
Thanks Meter: 62
No help JAF
NO help 6300 cable
Please help me about modified cable with figure
any body help me
Old 02-10-2010, 01:35   #20 (permalink)
Member: 303868
Thanks Meter: 62
Please explain with figure sir
Old 02-10-2010, 01:37   #21 (permalink)
Member: 303868
Thanks Meter: 62
Originally Posted by sonu_to88 View Post
3110c Data BLK error or RX2 error
This modified cable figure is write or wrong
Any body say me this fig is wrong or right
Old 02-10-2010, 12:22   #22 (permalink)
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,284
Thumbs up Here is the perfect solution
Flash with - ver 7.21, cable - 8 pin & USB cable
Rehot - CPU, Power IC , Thavo , Memory Ic , many time
present time set complete dead BUT booting 100% ok .
Set also could not convert in to Normal , Local , or Test mode .
Flashing Result - by different box
Jaf - abort at last i select downgrade also.
Mx KEY - RX2 not responding check BSI , cable & pin
Micro - Data BLK error
UB - Through USB - Detecting USB flash device.
Sir any other cable or box solve this solution Pls help me .
Please digramatically see your language i could not follow it
http://forum.gsmhosting.com/vbb/show...05#post5401105
Old 02-11-2010, 04:28   #23 (permalink)
Member: 303868
Thanks Meter: 62
Originally Posted by Moiz Khan View Post
Sir i find your site but file can not open so please easy step you show please.
I also use 7 pin cable.
i also connect 9v battery with ziner .
+ ve conect vacant pin2 & -ve conect with Grd
but reselt is zero.
what i do please help me
The Following User Says Thank You to sonu_to88 For This Useful Post:
Old 02-13-2010, 08:23   #24 (permalink)
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,284
Arrow ??
but reselt is zero.
If u had downloaded that file, u have to had WinRar installed on ur pc...ok
With the help of it u can open that file.
The Following User Says Thank You to Moiz Khan For This Useful Post:
Old 09-15-2010, 20:36   #25 (permalink)
Member: 1268918
Sonork: 9884416183
simple mx- key used to flash and go to service > Quick fix > click bb5 SW downgrade fix DO THE SELECT THE JOB 100%
Old 09-15-2010, 20:55   #26 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Angry
You know what are you saying
Data blk and Data mismatch both are different error.
Br.
Vijendra Saini.
Old 09-15-2010, 21:03   #27 (permalink)
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Iam using GPG Industries 7pin cable,whenever this error come to me i flash the phone with jaf box(original pkey with jaf interface)with same 7 pin gpg cable,mine problem were solved.
Br.
Vijendra Saini.
The Following User Says Thank You to Vijendra Saini For This Useful Post:
Old 10-28-2010, 15:17   #28 (permalink)
sony_mobiles's Avatar
Member: 731994
Thanks Meter: 297
ub usb cable is 10000% .............ok
THANK U UB
The Following User Says Thank You to sony_mobiles For This Useful Post:
3110 data blk error vinay_sharma HWK 99 08-12-2014 14:10
Nokia 3110c Data blk error logicmobile Nokia Base Band 5 ( BB-5 ) 25 12-04-2011 07:12
3110c data blk error mahesh123 HWK 16 09-04-2010 18:37
3110c data blk error jaysukh HWK 5 11-30-2009 11:16
Bb5 Flashing Data Blk Error kankandeka Nokia Base Band 5 ( BB-5 ) 0 05-18-2008 19:34
Page generated in 0.23188 seconds with 11 queries
