![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2001 Location: Europe Age: 44
Member: 4533 Status: Offline Thanks Meter: 13 | After upgrading 6280 from 3.70 to 5.92 phone won`t go to test mode any more! ![]() ![]() ![]() P.S. Phone works OK with 5.92 |
![]() | #3 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2005 Location: Still thinking
Member: 139853 Status: Offline Sonork: 100.1590178 Thanks Meter: 46 | i flash with version 5.92 with ca-53 cabel and it's ok done nothink wronge yes i have fbus cabel but i alway's flash with ca-53 . try downgrand and checkout.but let me know u nothink wronge with ver 5.92. br niki |
![]() | #4 (permalink) | |
Cheater -Don't Deal with him- ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2002 Location: Tunisia Age: 45
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | Quote:
br | |
![]() | #6 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
5k1 will also work with lower firmware versions, so two cables are not required. Odia. | |
![]() | #7 (permalink) |
Member: 139853 Status: Offline Sonork: 100.1590178 Thanks Meter: 46 | es mr.odia is right a little exercise help u to save ur hand set .u need to remove old ewsister with 5k and it's done.or used usb flashing with dku-2 or ca-53. niki |
![]() | #8 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: HO-TEL??
Member: 237455 Status: Offline Thanks Meter: 10 | I had also flashed my 6280 to 5.92. I had done this with an modified f-bus cable with the 5k1 resistor. 7 pin cable and JAF. After the flash it always shows test mode. no more local mode if I use te usb cable I can swich it to local or test. Everything works fine can still flash the mobile and do all the service jobs etc. Maybe its the firmware version that couses the problem. You can't donwngrade to test this ![]() |
![]() | #9 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2002 Location: TURKEY Age: 49
Member: 10448 Status: Offline Thanks Meter: 0 | same problem with me. solution is only ufs nokia 2.0.1 version is working correctly. i was try all other versiyons but with 2.0.1 version flashing was work correctly. B.R. BGT GSM |
6131 from 3.70 to 5.50 | Mikolson | Nokia Base Band 5 ( BB-5 ) | 5 | 11-28-2006 23:28 |
Nokia 6280 dead after flash to 5.92 | beermat999 | Nokia Base Band 5 ( BB-5 ) | 5 | 10-16-2006 00:31 |
6280 upgraded to 5.92 firmware call problems | adrian5800 | Nokia Base Band 5 ( BB-5 ) | 3 | 10-15-2006 20:54 |
Unlock All Sagem ( No Need Test Mode Any More ) | bahtiyar | Main Sales Section | 0 | 05-25-2003 19:55 |
Unlock All Sagem ( No Need Test Mode Any More ) | bahtiyar | Main Sales Section | 0 | 04-27-2003 10:28 |
