11-04-2007, 08:19 | #16 (permalink) | |||||
Insane Poster Join Date: Aug 2006
Member: 329883 Status: Offline Thanks Meter: 2 | Quote:
I m not able to install and u r talking about update clint Quote:
On one pc where i download this HWK_Suite_Setup_v02.06.000 it\s working fine but on other 2 pc it's not working for me and giveing me same error. Call to RegDBQueryKey failed. for the first time i m unable to solve my problem and handsup I m much much upset had waist a lot of time to solve this problem but no success. Plz supporter help me to solve this problem. Thanx | |||||
11-04-2007, 09:13 | #17 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 55
Member: 102467 Status: Offline Thanks Meter: 24 | 1 unistall all hwk suite 2 install hwksuite v2.06.00 exe (excutable) not the main setup 3 update u hwk with client 4 install hwksuite v2.06.00 (main setup) 5 install again hwksuite v2.06.0 (excutable)exe u show repare or remove 6 repare and all its ok |
11-04-2007, 12:06 | #18 (permalink) |
Junior Member Join Date: Apr 2005 Age: 44
Member: 134068 Status: Offline Thanks Meter: 0 | i have the same problem.suite works perfect to my main pc that its conected to internet but when i go to install suite to my laptop i have the same problem that you are speaking about.i cant instal the suite in my laptop BIG PROBLEM!!!!!!!!!!!!!!!! |
11-04-2007, 13:22 | #20 (permalink) | |
Freak Poster Join Date: Apr 2007 Location: دبي
Member: 491611 Status: Offline Sonork: 100.1641562 Thanks Meter: 41 | Quote:
well done for you mate. I got same error of all the poster...what's wrong with our computer. I did the same procedures. Please advise thank you! | |
11-04-2007, 13:58 | #21 (permalink) |
Member: 491611 Status: Offline Sonork: 100.1641562 Thanks Meter: 41 | Well done, Installing HWK setup. Clearly no need to uninstall what you have installed hwk versions. 1 just connect the box 2 launch the hwk support setup suite 2.06.0000000 3 continue if you wish to upadte hwk upgrade..done 4 launch the setup suite 2.06.00 last options modify repair remove. then select repair done. Launching DCTxBB% in the window. thats it... thanks to renz77 I saw his post... and all the posters thank you I made it now myself |
11-11-2007, 17:44 | #24 (permalink) |
Member: 491611 Status: Offline Sonork: 100.1641562 Thanks Meter: 41 | Pleased Advise me OR anayone can give a guide for flashing SAMSUNG PHONES IN HWK flasher interface? mostly in Trident phones I appriciate someone can post the reply, THANK you! |
11-11-2007, 19:51 | #25 (permalink) |
Freak Poster Join Date: Jan 2006 Location: South Africa
Member: 227454 Status: Offline Thanks Meter: 48 | How did i solve this problem of TWO PCs, Please read carefully, First uninstall all the previous versions, Then Run the HWK support suite with attached Box after completion of install run Run HWK client let it again upgrade your HWK bcs i think it copies a files from the server to your Computer every time u upgrade don't worry it will upgrade your HWK again with the other computer & necessary file will be copied on your Hard disk to run the main setup when u finish with upgrade. Just run main setup everything will go smoothly. |
11-11-2007, 20:33 | #26 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: Romania Brasov Age: 46
Member: 25136 Status: Offline Sonork: 1591036 Thanks Meter: 54 | Quote:
Unpack in sarasoft smsung directori format epp and NAND wit the code flash phone with out batery And if it necesary format again epp with code *2767*3855# | |
11-26-2007, 09:46 | #28 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Solution To Install Hwk_setup V2.0.6.0 here is the solution and i hope it will help to all who are not able to install v2.0.6.0 1) install 2.0.5. upto 2.0.5.007 all updates one by one 2) Extract Attached file and run setup.bat file from it then run re.reg file( THanks goes to Dengel for his work) 3) Restart Your Computer. 4) Install v2.0.6.0 it will show u error saying something that dengle prefetch is installed but no problem press OOk and setup will continue. 5) After installing and when u run DCTxBB5 & SAM, if u get error not authorized copy use original installer, then run setup v2.0.6.0 again and do repair. Everything will be Ook, hopefully Take Care ENJOY |
11-26-2007, 11:19 | #30 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Yes, this really is poor from HWK team, i mean they know there was troubles with users installing last versions, and now this time round it is not any better, still, windows will probably get the blame for it.... |
The Following User Says Thank You to .:GSM International:. For This Useful Post: |
installation HWK_Suite_Setup_v02.06.000 erorr | Miftahudin | HWK | 4 | 01-11-2008 11:26 |
Tested and 100% solution to install new HWK_Suite_Setup_v02.06.000.exe | Unlocker AL | HWK | 23 | 12-21-2007 01:54 |
HWK_Suite_Setup_v02.06.000 Installation Error | Aazib jhon | HWK | 4 | 11-30-2007 02:40 |
UNKNOWN ERROR WITH HWK_Suite_Setup_v02.06.000 | outlandier | HWK | 3 | 11-30-2007 00:43 |
100% HOW TO INSTALL HWK_Suite_Setup_v02.06.000 | HZZORY4GSM | HWK | 2 | 11-21-2007 08:24 |
