05-13-2010, 04:38 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | How to unlock samsung b3210 ? here i got a phone locked 3210 it got connected to usb cable as com port 8 to PC any 1 who is experienced with this model be please to share your idea to unlock this phone with hwk thanks advanced. NEIL |
05-13-2010, 04:48 | #2 (permalink) |
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | Phone Must be with Battery and Powered On ! MSL : Active S/N : RVUSC79097 To Make MSL Bypass in USB Mode, Use [Read Codes] at first ! Network Keys Reset Failed I shall report after trying the method in support regards, NEIL Last edited by neilthirumuttam; 05-13-2010 at 04:56. |
The Following User Says Thank You to neilthirumuttam For This Useful Post: |
05-13-2010, 06:09 | #3 (permalink) |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | Solution already avaliable on Support Area. Root / HWK_SW/ How to Unlock USB only phones [B3210,B3310].txt Hope you resolve your problem.!! Munna. |
The Following 4 Users Say Thank You to GsmMunna For This Useful Post: |
05-14-2010, 03:35 | #4 (permalink) |
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | yes done it simply followed the text 100% OK thanks HWK team regards, NEIL |
06-16-2010, 08:31 | #5 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | i have the procedure with usb cable from support but i can't enter phone in usb download mode. phone only power on after press Hold * button power and insert cable read info give this: Quote:
The Following User Says Thank You to denard For This Useful Post: |
06-16-2010, 19:33 | #6 (permalink) |
Freak Poster Join Date: Jan 2006 Location: YEMEN
Member: 226691 Status: Offline Thanks Meter: 22 | do this 1. Switch On Phone and Connect USB Cable. 2. Select ssm1 port in [Interface] ComboBox. 3. Press [Info] button, will see info like this: Phone Must be with Battery and Powered On ! Software: B3210XXII4 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2009 September Rev: 4 CSC Vers: B3210OXAII4 Regions : Austria,France,Germany,Italy,Netherlands,Switzerla nd,UK Language: de,en,es,fr,it,nl,pt,tr Release : 2009 September Rev: 4 Hardware: MP 0.601 IMEI: 358628-03-099690-0 BT Address: c87e75-cb4abb Lock Level: 00 [Not Locked] MSL : Active S/N : RD3SC79975 To Make MSL Bypass in USB Mode, Use [Repair MSL] at first ! (not need to Write E2P or MCU ) Locks: Error 4. Disconnect USB cable, Switch Off Phone. 5. Enter Phone to USB Download Mode (Hold * button and insert Cable) 6. Select ssm0 port in [Interface] ComboBox. 7. Press [Repair MSL] button, software will ask about S/N, make sure is same as see in Info. Not need write any MCU or E2P files. Using MSL S/N: RD3SC79975 USB Boot Ok, McuId: 00050015, Ubl: BC8906B3, 7-1.1 (Vision X115E) Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_usb_s06_t.sre Flash1: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Flash2: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Read Done, St: 0x23FC0000, 262144 byte(s), Time: 00:01, 0 Flashing NOR part... Write Done, 262160 byte(s), Time: 00:01 8. Disconnect USB cable, Switch On Phone. 9. Select ssm1 port in [Interface] ComboBox. 10. Press [Info] button, will see info like this: Phone Must be with Battery and Powered On ! Software: B3210XXII4 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2009 September Rev: 4 CSC Vers: B3210OXAII4 Regions : Austria,France,Germany,Italy,Netherlands,Switzerla nd,UK Language: de,en,es,fr,it,nl,pt,tr Release : 2009 September Rev: 4 Hardware: MP 0.601 IMEI: 358628-03-099690-0 BT Address: c87e75-cb4abb Lock Level: 00 [Not Locked] MSL : Active S/N : RD3SC79975 MSL : Deactivated PCK : 00000000 [#0141*00000000#] NCK : 00000000 [#0111*00000000#] SCK : 00000000 [#0121*00000000#] SPCK: 00000000 [#0133*00000000#] MCK : 15234981 [#0111*15234981#] 11. Now can use Unlock Codes or do any other Operations (Repair IMEI, etc.) Phone not need anymore to [Repair MSL] |
The Following 6 Users Say Thank You to alifahad For This Useful Post: |
10-08-2010, 09:42 | #9 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: kuruman
Member: 646368 Status: Offline Thanks Meter: 113 | Quote:
failed to enter test mode. n.b. i have followed the instructions in support. when in download mode i can do all the operation including read and write. what might be the issue,tried with three diff handsets same issue. can it be improper installation of drivers? in DEVICE MANAGER under ports it reads as SAMSUNG MOBILE USB PORT,and under USB CONTROLLERS it reads as samsung mobile usb device. | |
10-20-2010, 14:23 | #11 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Pakistan Age: 39
Member: 693282 Status: Offline Sonork: 100.1602586 Thanks Meter: 41 | Done Thanks GSM muna i got txt file here i mention all method 1. Switch On Phone and Connect USB Cable. 2. Select ssm1 port in [Interface] ComboBox. 3. Press [Info] button, will see info like this: Phone Must be with Battery and Powered On ! Software: B3210XXII4 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2009 September Rev: 4 CSC Vers: B3210OXAII4 Regions : Austria,France,Germany,Italy,Netherlands,Switzerla nd,UK Language: de,en,es,fr,it,nl,pt,tr Release : 2009 September Rev: 4 Hardware: MP 0.601 IMEI: 358628-03-099690-0 BT Address: c87e75-cb4abb Lock Level: 00 [Not Locked] MSL : Active S/N : RD3SC79975 To Make MSL Bypass in USB Mode, Use [Repair MSL] at first ! (not need to Write E2P or MCU ) Locks: Error 4. Disconnect USB cable, Switch Off Phone. 5. Enter Phone to USB Download Mode (Hold * button and insert Cable) 6. Select ssm0 port in [Interface] ComboBox. 7. Press [Repair MSL] button, software will ask about S/N, make sure is same as see in Info. Not need write any MCU or E2P files. Using MSL S/N: RD3SC79975 USB Boot Ok, McuId: 00050015, Ubl: BC8906B3, 7-1.1 (Vision X115E) Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_usb_s06_t.sre Flash1: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Flash2: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Read Done, St: 0x23FC0000, 262144 byte(s), Time: 00:01, 0 Flashing NOR part... Write Done, 262160 byte(s), Time: 00:01 8. Disconnect USB cable, Switch On Phone. 9. Select ssm1 port in [Interface] ComboBox. 10. Press [Info] button, will see info like this: Phone Must be with Battery and Powered On ! Software: B3210XXII4 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2009 September Rev: 4 CSC Vers: B3210OXAII4 Regions : Austria,France,Germany,Italy,Netherlands,Switzerla nd,UK Language: de,en,es,fr,it,nl,pt,tr Release : 2009 September Rev: 4 Hardware: MP 0.601 IMEI: 358628-03-099690-0 BT Address: c87e75-cb4abb Lock Level: 00 [Not Locked] MSL : Active S/N : RD3SC79975 MSL : Deactivated PCK : 00000000 [#0141*00000000#] NCK : 00000000 [#0111*00000000#] SCK : 00000000 [#0121*00000000#] SPCK: 00000000 [#0133*00000000#] MCK : 15234981 [#0111*15234981#] 11. Now can use Unlock Codes or do any other Operations (Repair IMEI, etc.) Phone not need anymore to [Repair MSL] |
The Following User Says Thank You to malik_moon For This Useful Post: |
02-16-2011, 19:41 | #12 (permalink) |
No Life Poster Join Date: Sep 2005 Location: The Netherlands Antilles Age: 50
Member: 179391 Status: Offline Thanks Meter: 57 | Thanks, Nice job. tested and working 100%. remember to insert wrong simcard before entering the codes. Just whatever is NOT 00000000 one by one till it unlocks |
08-20-2011, 17:38 | #13 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Lahore Pakistan. Age: 38
Member: 1284347 Status: Offline Sonork: 100.1592292 Thanks Meter: 977 | Samsung b3210 unlock done with z3x SAMSUNG B3210 UNLOCK DONE WITH Z3X JUS CONECT USB CABLE PRESS INFO... BUTTON Selected model: B3210 Selected com port: COM43 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: B3210JVIJ3 Langpack: Algeria, Egypt, Iran, Iraq, Kuwait, Morocco, Nigeria, Oman, Pakistan, Saudi Arabia, South Africa, Syria, Tunisia, Turkey IMEI: 35 S/N: RVSSC27447 HW-> MP 0.600 Phone password: 1602 Sum Flash: 1 Flash Prod ID: 089 Flash Device ID: 88b00000 Flash size: 134217728 Bytes Flash sectors: 512 sectors Bluetooth ID: 44f459-ae9eb4 Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE This is sha-1 code - wait for decrypt Calculated code please wait Decrypted time: 105 sec [NCK]:#0111*00000000# [SCK]:#0121*00000000# [SPCK]:#0133*00000000# [MCK]:#0199*18221834# Read info - ok Elapsed time: 134 second, sw ver: 3.5.0025 BR, AM_GSM_CELL...:::AWAIS.AS:::... |
03-19-2012, 06:44 | #14 (permalink) |
No Life Poster Join Date: Dec 2010 Location: ..:: GSM-Forum ::..
Member: 1476028 Status: Offline Sonork: 100.1625985 Thanks Meter: 114 | Success fully Unlocked Samsung B3210 with UFS HWK Success fully Unlocked Samsung B3210 with UFS HWK Thanks Team Good Trick ... Software: B3210DDJA1 Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2010 January Rev: 1 CSC Vers: B3210ODDJA1 Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2010 January Rev: 1 Hardware: MP 0.601 IMEI: 359007-03-299299-7 BT Address: d4e8b2-fa4021 User Lock : 00000000 Lock Level: 00 [Not Locked] MSL : Active S/N : RW4Z995963 MSL : Deactivated PCK : 992318 [#0141*992318#] NCK : 00000000 [#0111*00000000#] SCK : 00000000 [#0121*00000000#] SPCK: 00000000 [#0133*00000000#] MCK : 77548554 [#0199*77548554#] Big Thanks For UFS HWK Team ....! |
03-30-2012, 23:40 | #15 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: SOUTH AFRICA
Member: 1449328 Status: Offline Thanks Meter: 77 | Quote:
100% agree with u this method is tested .. u must repair msl to unlock that cellphone | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
