10-10-2009, 09:54 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | ** J208 phone lock password how can I remove this ???? PING: OK, COM4 - QCDI Software: J208ZHGK1 Regions : HongKong Language: en,zh Release : 2007 November Rev: 1 Hardware: MP 0.901 IMEI: 358807-01-004426-7 BTID: 001E:7D:98604D S/N : R3WPB03852 PRID: SGH-J208 CSID: TGY SWID: ZHGK1 DATE: 2007-11-07 UNID: aaaaaaaaaaaaaaaaaaaaK5D1H13ACM(J200) FLID: K5D1H13ACM(J200) AXID: 1108-000129 Sysinfo Saved as: J208ZHGK1_358807010044267_R3WPB03852_aaaaaaaaaaaaa aaaaaaaK5D1H13ACM(J200)_DFB82FFA_Sys.sec Currently Unsupported Model Unsupported Firmware or SIM not Inserted PING: OK, COM120 - MODEM MMI Reset Ok, Time: 00:00 Can I make full reset *2767*3855# ? Afriad might damage E2p. Might result in limited service? Have made back up e2p/nvm but write e2p tab is not highlighted. If I am to make read flash waht are the correct address to be used? b.r. |
10-11-2009, 13:01 | #5 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | *#06# Show IMEI *#9999# Show Software Version *#0837# Show Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast *#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error *#9998*786# Run, Last UP, Last DOWN *#9998*837# Software Version *#9998*842# Test Vibrator - Flash the screenlight during 10 sec and vibration activated *#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk *#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version *0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1) *0002*?# unknown *0003*?# unknown FOR NEW SGH (R210, T100, A300...) if code is in format *#9998*xxx# try write in this *#0xxx# SGH-600 SGH-2100 *2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0 *2767*2878# Custom EEPROM Reset SGH E700 *2767*688# remove USER CODE and SIMLOCK SGH V200 Unlocking: Power on the phone without SIM card and type these codes: *2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged SGH S500 Unlocking *2767*MVT# (*2767*688#) E2P MVT Reset *#SIMLOCK# (*#7465625#) " E900 software version: *#5002*8376263# " E900 full reset: *2767*3855# try this sir if work regards: lilong lee |
10-11-2009, 13:06 | #6 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | *2767*3855# - Full EEPROM reset(Reset all type of locks)also you'll here sir try i think your problem solve regards: lilong lee |
x760 phone lock password when u turn on the phone i need to remove help | observer123 | Infinity-Box | 4 | 02-04-2010 15:18 |
How Can I remove my password for Samsung S5603 ? | caremobiles | Z3X-Team Products | 5 | 10-03-2009 15:47 |
vodafone 810 phone password. how can remove this ? | hussainafridi | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 3 | 04-04-2009 08:42 |
How Can I Remove this error | Ahsan619 | Sony Ericsson | 1 | 12-23-2008 21:09 |
Asus J208 Phone LOck Code HELP | FullFLASHgSMPH | Various | 0 | 10-12-2006 06:38 |
