Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 02-16-2012, 20:19   #1 (permalink)
akt007's Avatar
Member: 773986
Thanks Meter: 52
Nokia E5-00 vibrate only after flash
see the flash log
Insert USB Cable to Switched OFF Phone and Power ON
USB BOOT : 60,07 [Rm-632] [2.2.0.0]
CMT ASICID: 000000030000022600010007600C192102031104
EM 1 ID : 00000C35
EM 2 ID : 00000C30
CMT PUBID : 21D000121BD60344F129B817CCAD37BD92413363
CMT MODE : 00
CMT HASH : 916F75217F32081248B15C38DFC8E81B
CMT ROMID : E693EF0DAC22615B
CMT 2ND Bt: RAPUv11_2nd.fg, Ver: 11.16.0
CMT 2ND Bt: SILO OK
CMT RMID0 : 00000000-00000000
CMT MCID0 : FFFF0000-00000000
CMT FLID0 : 00200050-00000031, St OneNAND-4G
CMT FLID1 : 00200050-00000031, St OneNAND-4G
CMT RQALG : XSR 1.6
CMT 2ND Boot OK
CMT ALGO : RAPUv11_XSR17_alg.fg, Ver: 11.16.0
CMT KSIG0 : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C
CMT ALG Boot OK
IMAGE : rm632_081.004_prd.core.fpsx
CMT NAND Erase Area: 0x00020000-0003FFFF
CMT NAND Erase Area: 0x00060000-004DFFFF
CMT NAND Erase Area: 0x008E0000-0E77FFFF
CMT NAND Partition Format
CMT FLASH ERASE OK, Time: 00:02
Written: 10 Certificate(s)
CMT FLASH WRITE OK, Time: 00:00
IMAGE : rm632_081.004_U005.000_prd.uda.fpsx
CMT NAND Erase Area: 0x0E780000-1F13FFFF
CNT FLASH ERASE OK, Time: 00:02
CNT FLASH WRITE OK, Time: 00:06
IMAGE : rm632_081.004_34.01_APAC_QW2_prd.rofs2.fpsx
CMT NAND Erase Area: 0x08980000-0D0FFFFF
PPM FLASH ERASE OK, Time: 00:00
Written: 1 Certificate(s)
PPM FLASH WRITE OK, Time: 00:09
IMAGE : rm632_081.004_C00.01_DEFAULT_prd.rofs3.fpsx
CMT NAND Erase Area: 0x0D100000-0E77FFFF
CUS FLASH ERASE OK, Time: 00:00
CUS FLASH WRITE OK, Time: 00:01
Flashing Completed, Rebooting Mobile
after flash phone only vibrates.....
Old 02-16-2012, 23:10   #2 (permalink)
Member: 815269
ERR: CMT 2ND Boot File not Found
can anyone help to understand what this error is???
it apears every time i try to read or unlock a BB5 with the tornado box! what file is this???
Old 02-16-2012, 23:42   #3 (permalink)
Member: 815269
ERR: CMT 2ND Boot File not Found please help
when i try to read gives me this !!
when i try to unlock is ERR: CMT 2ND Boot File not Found
Old 02-29-2012, 00:05   #4 (permalink)
Member: 470039
Thanks Meter: 3
Try flash with same product code if not flash with latest version.
Old 03-04-2012, 10:19   #5 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
use a good eno file then post here result
Old 05-09-2012, 10:54   #6 (permalink)
Registered User
Member: 1202860
E5-00 flashing
Hello flash via USB cable
Old 06-03-2012, 07:55   #7 (permalink)
Member: 1755873
please help me sir.i have same problem.after full flash phone will be vibrate only.........................
Old 06-03-2012, 20:24   #8 (permalink)
Member: 1701170
Sonork: 123456
Thanks Meter: 86
Try Flash Phone by F-BUS Cable With Last Version
Old 06-20-2012, 20:28   #9 (permalink)
Member: 789390
Thanks Meter: 3
i tried both cable and usb but flashed fully, then vibrates. any solution?
Old 06-20-2012, 20:44   #10 (permalink)
Member: 1039344
Sonork: 100.1612828
Thanks Meter: 9
flash with 91.1 may ur problem solved
Old 06-25-2012, 09:44   #11 (permalink)
Member: 1640620
flah with latest fileeeeeeeeeeeeee
Old 06-25-2012, 09:46   #12 (permalink)
Member: 1640620
first erase full flash then wright latest flash files
Old 06-27-2013, 09:19   #13 (permalink)
Member: 1265217
Sonork: 100.1591325
Thanks Meter: 3
whr is flash file $ nokia E5 RM-632
code - 059H9K4
Old 09-05-2013, 17:14   #14 (permalink)
DineshDias's Avatar
Member: 77943
Thanks Meter: 56
But friends there are sometimes, "vibration only" comes from hardware. However it is wiser to upgrade the firmware first of all.
If flashing goes fine & software program detects the phone after flashing in TEST MODE, but it is still only vibrates, you can check the LCD operating voltages (VAUX1 & VIO) on LCD socket.
If u can not find any of these voltages at the LCD socket, it is time to check L2420(VAUX1 comes through this) & R2423 (VIO comes through this)
Good Luck!!
Old 08-28-2014, 18:54   #15 (permalink)
Member: 1342044
Thanks Meter: 51
nokia E5 boot error how to solve.
1ST BOOT : C0,07 [Rm-632] [2.3.0.3]
EM 1 ID : 00000C35
EM 2 ID : 00000C30
CMT PUBID : 15900101F0DE0344AE298DE3D22559E47BAD47E8
CMT MODE : 00
CMT 1ST Boot OK
Cannot Find KEYS CERT
BAD BOOT
Rebooting Mobile
Page generated in 0.19948 seconds with 10 queries
