Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 08-07-2005, 19:07   #1 (permalink)
Member: 99524
To Solder or not to solder
Hey guys, just tried setting up my HWK in my UFS-3 box as in the picture featured in the installation line, however the software did not connect it. I only place it loose on the pins, is it required to solder the pins or could i have a faulty hwk?
Any suggestions or advice would be greatly appreciated.
Regards,
Billy.
Old 08-07-2005, 19:12   #2 (permalink)
daiphil's Avatar
Member: 56899
Thanks Meter: 3
solder.
Well I just connected mine onto the pins, and it shows up in the software no prob. some say it needs to be soldered and some say no.
UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1
UFS_USB V2.6 (c) SarasSoft 2005. S/n: *****
HID: 98******002700**
HWK: A1.02-TEST
Licence: True
Old 08-07-2005, 20:05   #3 (permalink)
Member: 136598
Thanks Meter: 3
try slightly bending the pins so it creates a tight fit
Old 08-08-2005, 06:02   #4 (permalink)
Member: 90865
Regards,
Billy.
But have you installed UFS suite? The older software won't see the HWK, you need to run the KFZ or SAMs 1.4s version as they reset the HWK and the signon banner appears.
Also, you say loosely placed, you need to push the connector right down on the 16 pin header to ensure contact is made, and to ensure it doesn't short out on the box of the UFS3.
WolfMan
Old 08-30-2005, 14:31   #5 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
if you are scared to solder a few *very large* pins, i think you are in the wrong line of business mate...
maybe try flower aranging. very safe and NO SOLDERING REQUIRED...
Old 12-08-2005, 13:07   #6 (permalink)
Member: 40578
Hwk
Hi,
I need help my HWK says:
UFS_USB V2.6 (c) SarasSoft 2005. S/n: 19039
HWK: Self Destructed
Licence: True
Selected Device, not Compatible with Software
Old 12-09-2005, 09:52   #7 (permalink)
Member: 172261
Thanks Meter: 364
replace with your reseller
Old 05-20-2006, 23:34   #8 (permalink)
Member: 163755
Thanks Meter: 126
Originally Posted by Farzina Manji
Hi,
Licence: True
Good day
Have u repair your HWK
I have the sem pb any help for my
Djouaka
Waiting
Old 05-20-2006, 23:42   #9 (permalink)
Member: 226496
Thanks Meter: 11
you should NOT have to solder. That is rediculous. Have reseller replace it.
Old 05-21-2006, 22:29   #10 (permalink)
Member: 163755
Thanks Meter: 126
Ufs3 Divice Not Recognice
Good day Sir
I did not solder it
Now when conet it ask of activetion string,when put i put the activetion
UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 0
UFS_USB V2.6 (c) SarasSoft 2005.S/n: 40149
Licence: False
Licence Update Failed
Any help
Waiting
Djouaka
do you want to pay or not to use next update!!!!!! plz vote amralkareem Infinity-Box 107 10-08-2008 17:36
To Flash or not to flash ?? My GX10i Cools Sharp 0 03-26-2005 17:35
to buy or not to buy ... distefano VygisToolbox 10 03-16-2005 08:32
To ME45i or not to? SuperDAF x1x to x45/x50 1 04-07-2004 17:43
Page generated in 0.58045 seconds with 9 queries
