05-28-2011, 10:49 | #2131 (permalink) |
No Life Poster Join Date: May 2007 Location: Islamic city of Marawi
Member: 502507 Status: Offline Sonork: 100.1648947 Thanks Meter: 154 | MSL Active MSL Active SIMLOCK STATUS: 0000 MCC-MNC: 001-01 GSM Test Equipment MASTER KEY: 87304680 NET 00000000, 00000000 SUB 00000000, 00000000 SP 00000000, 00000000 CP 00000000, 00000000 SIM 00000000, 00000000 ACT 00000000, 00000000 PLK 00000000, 00000000 SLOCK Reset, Ok Unlock Done |
05-28-2011, 10:58 | #2132 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 37
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | 1800 If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader.10.19, Mode: CC BAUD_R: 921600 FL_ID : EC007A22, Samsung Unknown 64Mb MCU FLASH BUNDLE: rm653_006.200 Flash File: hw_b2_rm653_r06.200.fls Erase Area: 0x00800000 - 0x00A0FFFE, Erased: 00:19 Write Area: 0x00800000 - 0x00A0FFFE, Written: 00:34 Erase Area: 0x00C60000 - 0x00EAFFFE, Erased: 00:00 Write Area: 0x00C60000 - 0x00E6A0BE, Written: 00:34 Erase Area: 0x00FFC000 - 0x00FFFFFE, Erased: 00:01 Write Area: 0x00FFC000 - 0x00FFC03E, Written: 00:00 Warning, Checksum Mismatch: CF7C > 27EA PPM FLASH BUNDLE: rm653_006.20ia Flash File: hw_b2_rm653_006.20ia.fls Erase Area: 0x00210000 - 0x0045FFFE, Erased: 00:21 Write Area: 0x00210000 - 0x004038FE, Written: 00:32 Warning, Checksum Mismatch: C0D0 > E049 CNT FLASH BUNDLE: rm6530_nai06.20ia Flash File: hw_b2_rm6530_nai06.20ia.fls Erase Area: 0x00EB0000 - 0x00F7FFFE, Erased: 00:00 Write Area: 0x00EB0000 - 0x00F04AFE, Written: 00:05 Warning, Checksum Mismatch: AB19 > 1EF0 Flashing Done: 02:37 ShutDown Done |
05-28-2011, 12:00 | #2133 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Neverland
Member: 1005489 Status: Offline Thanks Meter: 105 | KP502 unlock If used non Auto-Ignition cable, press Power-On button IF_SBL: SGOLD3, Ok IF_EBL: Dec-11-2008..1.1, Mode: BB BAUD_R: 921600 FL_ID : AD00BA00, Hynix H8BSCS0SI0 2048+64Mb IMEI: xxxxxxxxxxxxxxxx FLAG: 1 0 1 NCK : 7654 9977 NSCK: 2181 9554 SPCK: 7338 2687 CCK : 8012 7531 SIM : 8607 8341 Use 2945#*71001# to Enter Sim Unlock Menu EEP Backup Saved as KP502_EEPBACKUP_354052-03-009415-8.bif CAL Backup Saved as KP502_CALBACKUP_354052-03-009415-8.bif Unlock Done, 00:10 (IMEI Enabled) |
05-28-2011, 13:25 | #2134 (permalink) |
No Life Poster Join Date: Nov 2007 Location: UK
Member: 629391 Status: Offline Thanks Meter: 397 | s5230 unlocked Connect Phone to RJ-45 Without Battery ! NAND_ID: Samsung K522H1HACA [BA] COMM_BR: 921600 Baud FLAG: 00000001 PROV: 23410 PROV: 234-10 O2, UK MAST: 73840408 [UNFREEZE] NET : 38169471 [#SIMLOCK*NET*38169471#] |
05-28-2011, 14:11 | #2135 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1396458 Status: Offline Sonork: 100.1591210 Thanks Meter: 29 | x2-00 flashing done Insert USB Cable to Switched OFF Phone and Power ON USB BOOT : 56,06 [Rm-618] [2.2.0.0] CMT ASICID: 000000000000000022000509200C0000 EM 1 ID : 00005361 CMT PUBID : BE092CFF093485A120D39CFDD98E27EA8F665CB2 CMT MODE : 00 CMT HASH : 1B0D74C532CA1C6133940C740E8C786E CMT ROMID : DE56D582BDDE7A3A CMT 2ND Bt: BCM21351_usb2nd.fg, Ver: 11.16.0 CMT RMID0 : 00000000-00000000 CMT MCID0 : FFFF0000-00000000 CMT FLID0 : 00200030-00000131, St OneNAND-1G CMT FLID1 : 00200030-00000131, St OneNAND-1G CMT RQALG : XSR 1.6 CMT 2ND Boot OK CMT ALGO : BCM21351_XSR16_usbalg.fg, Ver: 11.16.0 CMT KSIG0 : E9700989029D9E899915F781B1582048E042A738 CMT ALG Boot OK IMAGE : rm618__08.17.mcusw CMT NAND Erase Area: 0x00000000-0001FFFF CMT NAND Erase Area: 0x00020000-000203FF CMT NAND Erase Area: 0x00060000-011BFFFF CMT NAND Erase Area: 0x011C0000-01CFFFFF CMT NAND Erase Area: 0x02500000-028FFFFF CMT NAND Partition Format CMT NAND Partition Format CMT FLASH ERASE OK, Time: 00:00 Written: 11 Certificate(s) CMT FLASH WRITE OK, Time: 00:33 IMAGE : rm618__08.17.image_d_0595058_007 CMT NAND Erase Area: 0x02900000-0753FFFF CMT NAND Partition Format CNT FLASH ERASE OK, Time: 00:01 CNT FLASH WRITE OK, Time: 00:22 IMAGE : rm618__08.17.ppm_d CMT NAND Erase Area: 0x01D00000-024FFFFF PPM FLASH ERASE OK, Time: 00:00 PPM FLASH WRITE OK, Time: 00:08 Flashing Completed, Rebooting Mobile |
05-28-2011, 15:18 | #2136 (permalink) |
Member: 629391 Status: Offline Thanks Meter: 397 | c3300k unlocked Connect Cable to Switched Off Mobile (with battery) Software: C3300KBUJG4 Hardware: MP 0.802 Regions : Vodafone Language: de,el,en,es,fr,hr,hu,it,nl,pt,sl,sv,tr Release : 2010 July Rev: 4 MSL Active S/N : RP6Z968120 IMEI: 353340-04-xxxxxxxx BTID: 101D:C0:18B095 MSL Active SIMLOCK STATUS: 0001 MCC-MNC: MASTER KEY: 57194970 NET 07169810, <BADSET> SUB 00000000, 00000000 SP 00000000, 00000000 CP 00000000, 00000000 SIM 00000000, 00000000 ACT 00000000, 00000000 PLK 00000000, 00000000 Unlock KeyString: #SIMLOCK*NET*07169810# |
05-28-2011, 15:53 | #2137 (permalink) |
No Life Poster Join Date: May 2011 Location: india
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Samsung D780 Done Code: MCU File: D780XDHD2_Master.cla CRC32: 94983363 TFS File: D780XDHD2_Master.tfs CRC32: FDD4A445 CFG File: D780XDHD2_Master.cfg 208952 byte(s) MCU File: D780XDHD2_Slave.cla CRC32: 309442AB TFS File: D780XDHD2_Slave.tfs CRC32: B4293435 CFG File: D780XDHD2_Slave.cfg 465 byte(s) MCU Id: 3541, PNX5230/31 Preloader Ok, 460800 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] NAND Format Complete, Time: 00:11 File CRC: 0x94983363 MCU Write Done, 26813808 byte(s), Time: 11:36 File CRC: 0xFDD4A445 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 164 Max_Files : 2712 Files_Count: 2712/2712 TFS Unmounted TFS Write Done, 56573754 byte(s), Time: 28:50 --- SLAVE --- FLASH Id: EC5222, Samsung K5L6532ATM BaudRate: 460800 Baud MCU Write Done, 5483724 byte(s), Time: 02:30 TFS Version: TFS4.0_CORONA_01 Directories: 4 Max_Files : 1 Files_Count: 1/1 TFS Unmounted TFS Write Done, 8192 byte(s), Time: 00:10 Software: D780XDHD2 Hardware: MP 0.400 Regions : Czech,Hungary,Poland,Slovakia Language: cs,de,en,fr,hu,it,pl,sk(hr) Release : 2008 April Rev: 2 MSL Active S/N : RW7S237053 IMEI: 358227-02-068013-5 BTID: 0023:D7:317735 MSL Active SIMLOCK STATUS: 0000 MCC-MNC: 000-000 MASTER KEY: 74057950 NET 00000000, 00000000 SUB 00000000, 00000000 SP 00000000, 00000000 CP 00000000, 00000000 SIM 00000000, 00000000 ACT 00000000, 00000000 PLK 00000000, 00000000 --- SLAVE INFO --- Software: D780XCHE1 Hardware: MP 0.400 Regions : Portugal,Spain Language: de,el,en,es,fr,it,pt,tr Release : 2008 May Rev: 1 MSL Active S/N : RW7S237053 IMEI: 358228-02-068013-3 MSL Active SIMLOCK STATUS: 0000 MCC-MNC: 000-000 MASTER KEY: 00000000 NET 00000000, 00000000 SUB 00000000, 00000000 SP 00000000, 00000000 CP 00000000, 00000000 SIM 00000000, 00000000 ACT 00000000, 00000000 PLK <UN_SET>, <UN_SET> MSL Active MSL Active SIMLOCK STATUS: 0000 MCC-MNC: 000-000 MASTER KEY: 74057950 NET 00000000, 00000000 SUB 00000000, 00000000 SP 00000000, 00000000 CP 00000000, 00000000 SIM 00000000, 00000000 ACT 00000000, 00000000 PLK 00000000, 00000000 MASTER SLOCK Reset, Ok MASTER Unlock Done |
05-28-2011, 16:01 | #2138 (permalink) |
Member: 1005489 Status: Offline Thanks Meter: 105 | KF300 unlock If used non Auto-Ignition cable, press Power-On button Boot Ok, FL_ID : 89 88 7E [INTEL] 10 BaudRate Set to: 921600 IMEI: 3xxxxxxxxxxxxxxxxxxxx Read [05000000-0503FFFF] Done, 00:02 Cal. Data Saved as KF300_CAL_3527xxxxxxxxxxxx-9_2852011_165856.bif Unlock Done, 00:08 Last edited by satch1234; 05-28-2011 at 16:07. |
05-28-2011, 16:06 | #2139 (permalink) |
Member: 1005489 Status: Offline Thanks Meter: 105 | kp130 unlock If used non Auto-Ignition cable, press Power-On button Boot Ok, FL_ID : 01 21 00 [SPANSION] 0E BaudRate Set to: 921600 IMEI: 352xxxxxxxxxxxxxx Read [01000000-01007FFF] Done, 00:00 Cal. Data Saved as KP130_CAL_352xxxxxxxxxxxxx_2852011_170515.bif Unlock Done, 00:01 |
05-28-2011, 17:37 | #2140 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Central America
Member: 746276 Status: Offline Sonork: 100.1609752 Thanks Meter: 675 | Nokia 2690 user lock disabled. 1ST BOOT : C0,07 [] [2.2.0.0] CMT ASICID: 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 CMT PUBID : 1C700010CB1C035629C8270A72E4B8D9D8859107 CMT MODE : 00 CMT HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROMID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898982-00008A31, Int NU48F512 CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1 CMT KSIG0 : C6B9354E81AC464DED33FC7B90295086150F4539 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK PASUBTOC : PA_SL3 Rebooting Mobile MCU SW : V 10.61 23-07-10 RM-635 (c) Nokia PPM SW : V 10.61 23-07-10 RM-635 (c) Nokia UAL Product : Nokia 2690 Prd.Code: 059B747 Bpr.Code: 059C5Z2 Prod.Sn : DTG812836 HW Vers : 1002 EM VILMA: 16 EM BETTY: 22 RFIC Ver: 06560601 DSP Vers: ICPR72_10w06 LCD Type: SUEZ CAM Prim: NI00IIIIRR030C213402_003002 IMEI : 354307-04-423239-6 SL Serv : SIMLOCK SERVER SL Conf : 999-99-00017382363 SL Prof : 8000000000000000 SL Count: 00 00 SL Data Read Failed Bad SL Structure BC: 0E Provider: Not Found Set Full Factory Defaults ... Set Full Factory Defaults Ok, Time: 00:04 Set Security 12345 ... Set Security Ok, Time: 00:00 |
05-29-2011, 07:27 | #2141 (permalink) |
Member: 502507 Status: Offline Sonork: 100.1648947 Thanks Meter: 154 | t349 flashing MCU File: T349UVIC7.cla CRC32: DAC56B56 TFS File: T349UVIC7.tfs CRC32: 0DB09171 CFG File: T349UVIC7.cfg 154174 byte(s) MCU Id: 3721, PNX6511 Preloader Ok, 460800 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] NAND Format Complete, Time: 00:11 File CRC: 0xDAC56B56 MCU Write Done, 26536232 byte(s), Time: 11:34 File CRC: 0x0DB09171 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 129 Max_Files : 2107 Files_Count: 2107/2107 TFS Unmounted TFS Write Done, 24109418 byte(s), Time: 16:41 |
05-29-2011, 11:25 | #2142 (permalink) | |
Freak Poster Join Date: Feb 2011
Member: 1508914 Status: Offline Thanks Meter: 21 | C1 Rm-607 Infenion flashed Successfully via USB: Quote:
05-29-2011, 11:30 | #2143 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: AVJ (KOLKATA)
Member: 759058 Status: Offline Sonork: 1597286 Thanks Meter: 58 | nokia C1-01(RM-607) successfully flashed by HWK Quote:
05-29-2011, 11:45 | #2144 (permalink) |
Member: 502507 Status: Offline Sonork: 100.1648947 Thanks Meter: 154 | j700 flash done MCU File: J700DXHC2.cla CRC32: 9F043D20 TFS File: J700DXHC2.tfs CRC32: E6FB5158 CFG File: J700DXHC2.cfg 76589 byte(s) MCU Id: 3721, PNX6511 Preloader Ok, 460800 Baud Flashloader Ok FLASH Id: 00EC2206000100000014, Samsung KAP29VG00M [NAND 256M] NAND Format Complete, Time: 00:10 File CRC: 0x9F043D20 MCU Write Done, 26449616 byte(s), Time: 11:31 File CRC: 0xE6FB5158 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 113 Max_Files : 1000 Files_Count: 1000/1000 TFS Unmounted TFS Write Done, 15592119 byte(s), Time: 08:09 |
05-29-2011, 13:20 | #2145 (permalink) |
Major Poster Join Date: Nov 2008 Location: Monaghan,Ireland
Member: 898120 Status: Offline Sonork: 123456781 Thanks Meter: 5 | c1-02 changed language in seconds Insert USB Cable to Switched OFF Phone and Power ON IF_USB: XGOLD213 IF_SBL: XGOLD213, Ok IF_EBL: Quantum_Bootloader_10.37_M1S1.10.37, Mode: CC FL_ID : 89008289, Intel 38F50xxLOY3 512Mb PPM FLASH BUNDLE: rm643__03.40.ppm_e Flash File: package_e.ppm_ebl_psi.fls Erase Area: 0x41C00000 - 0x421FFFFE...Erasing Erase Area: 0x41C00000 - 0x421FFFFE, Erased: 00:21 Write Area: 0x41C00000 - 0x41F9108A...Writing Write Area: 0x41C00000 - 0x41F9108A, Written: 00:04 Flashing Done: 00:30 ShutDown Done All Done, Time: 00:37 |
Successfully unlocked/repaired phones by Infinity-Box | Infinity-Box | Infinity-Box | 76188 | 06-04-2024 11:21 |
MXBOX - Successfully Unlocked/repaired/flashed Phones By MXBOX | kabirhossain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3969 | 10-05-2016 05:13 |
jazz t161l Successfully Unlocked/repaired Phones By infinity box | honey_bbc2001 | Chinese Models & Cloned Phones | 0 | 07-07-2009 07:23 |
